Question about Metz 45 CL-1 Flash
Contact polarity i Have a Metz 202 flash with no power suply and want to build one could someone tell me what the polarity is on the three contacts starting with the half round end then the square ones Thankyou Rob
    New Friend:
  • 22 Answers
Hi elepant,
I haven't seen a 202, but if it's the same as the later 45 series, then looking into the bottom of the flash, the top pin at the round end is positive, the left one half way down is the negative for 7.2V NiCDs and the bottom right one, lowest down in the square corner, is the negative for 9V alkaline batteries. I've used NiCds and NIMH batteries with no problems,connected to the alkaline pins, it's just a tapping on the power supply transformer to compensate for the NiCDs having a lower voltage. There's also a 0.2 ohm resistor inside some of the Metz 45 models, in series with the NiCd negative line, probably to limit the initial current. I've had no problems at all over 24 years, with using NICds or NIMH on the alkaline connections, in an alkaline battery holder.
Posted on Feb 28, 2009
Does anybody in the EURO zone repair Metz CT-4 flash guns as if you go outside that area you can be liable for Customs Charges. I Think.
Hello again William
There is service in the UK. There is no Customs charges because duty will already have been made when new. Make sure you mark package 'Return to Maker for REPAIR'.
Metz Contact Us
Jan 14, 2016 | Metz Cameras
Metz 58 af-2 spares
Contact atdleeatnetzerodotcom
Feb 03, 2014 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
Metz flash sony nex camera
Sony NEX 6 has an ATG/Sony's Multi-Interface-Shoe.
Let's hope the Metz 58AF-2 Flash is made for Sony/Minolta, which has an old Minolta's hotshoe.
Contact Sony for the adapter.
Or just buy the Promaster Sony Multi-Ineterface Shoe Adapter, it less than Sony's.
Dec 29, 2012 | Metz MZ58321C 58 AF-2 Digital Flash for...
Dont Work
hi you probly have some battery in that flash,
or its could be your lamp if its seal if its thes case theres
no others way to buy anew one
sorry its the only thing i can tell you
because i do not know this brand
good luck
Mar 05, 2010 | Metz 44 AF-4N TTL Flash
METZ 45 CT 5 S O S
Check the polarity of the batteries.
With the batteries removed you will be able to see small
+ and - alongside each of the six connectors. Make sure the +
of the battery connects with the + connector. Similarly check the -
connections. With the batteries inserted (but without the plastic cap being fitted) you should see the ends of the batteries. Three positive ends (all in a row) and three negative ends.
If one, or more, has been inserted with the polarity reversed it will stop the flash from working.
It can also cause the handle to overheat.
May 02, 2009 | Metz mecablitz 45 CL-4 TTL Flash
AC Power Supply for Metz 45 ct5
Hi daf4,
I have a circuit diagram for the 45CT-5 and the flash unit as well. The voltage is 360V DC, which goes straight across the flash tube. The top pin is positive, when the notch in the socket is on the right hand side, i.e. towards the back of the flash.
I'm also looking for a circuit diagram for a 45CL-4, if you know anyone who has one.
Feb 07, 2009 | Metz mecablitz 45 CL-4 TTL Flash
Cannot fire off cameta
If the Metz 44 is older then 3 years, than it's an software problem. I Had the same with the Metz 44AF-C and my EOS 30D. The same metz works well with mij Rebel (300D)
Jun 08, 2008 | Metz 44 AF-4 for Canon TTL Flash
Contacts voltage
Originally the 45CT1 had high trigger voltage. In the production period Metz improved it to a much lower voltage release circuit. Metz homepage ( holds the information, from which serial number on have 45-CT1s low trigger voltage. However, even the high trigger voltage was lower than 200 volts, thus safe for your Fuji.
May 03, 2008 | Metz 45 CL-1 Flash
Can a metz cl45 external flash gun be used on the 9600? Thanks Steve
Without knowing what a 9600 is I cannot be sure, but the cl45 has a flsh connection cord to be conected to your cameras X sync port. This means the camera will only trigger the flash and the flash unit does all the calculations on its own (ie it does not work as a dedicated flash unit in this mode). You may be able to get a hot shoe connector to get some of teh cameras functions controlling the flash unit, but the amount of control the camera can send to the flash unit will depend on how old the flash unit is and whether it has these functions to start with.
Contact Metz direct and ask them. Thier site is located here:
Good luck.
Note: I had an old one of these years ago (pre Digital) and it was a great flash unit.
Apr 09, 2008 | Cameras
Metz 45 CL-1 Flash Logo
202 people viewed this question
Top Metz Cameras Experts
Level 1 Expert
Are you a Metz Camera Expert? Answer questions, earn points and help others
