Question about Whirlpool GY396 Electric Kitchen Range
Whirlpool Accubake Duo System electric range fault coes E4 F3
I get this fault code after 20+ min of oven use of just top range. The fault code changes to E0 F3 after few more minutes. Does any one has any idea what is wrong?
  • 4 Answers
F3 code correlates to oven temperature. Either the oven temperature sensor is malfunctioning or the over-limit switch is open. This is usually the result of using the self-clean mode and the over-limit switch gets stuck open. It has to be replaced...not too bad of a job if you have some mechanical/electrical knowledge. Ask parts supplier for a schematic so location can be visualized (inside top cavity on oven wall with a couple of wires. Also, Sears carries parts for these ovens. Hope this helps.
Posted on Mar 12, 2009
Error code F1 F3 F6
KitchenAid Fault Codes - AppliancePartsPros.com
www.appliancepartspros.com/repair-help/kitchenaid-fault-codes.html
Jump to Kitchen Aid Range / Stove / Oven Fault Codes - Failure Code, Fault CodeDescription, Solution ... F1 - E6, Latch signal mismatch error ... F3 - E0, Oventemperature ... electronic control will display F6 ...
Jan 27, 2016 | Kitchen Ranges
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
What dose F3 code mean
Amana Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Amana-Appliance-Fault-Codes.aspx
Fault codes for Amana ovens, range, stoves including dual convection wall overs and 'big ovens'. ... F3-1 - Oven Temperature Sensor/Circuit Failure - Check wire connections and ... what does it mean when the oven turns off and f3 shows ... My Amanaagds902ww gas range flashes "Door" when attempting to light the oven.
Amana Gas oven Fault Code F3 - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges-cooktops/143114-amana-g...
Nov 17, 2010 - 2 posts - ‎1 author
Have a Fault Code F3 display on oven when trying to set oven ON. Researched ... Yes, your F3 code would indicate a sensor circuit problem, Jenn-Air Electric Range Code F3
Mar 15, 2011
Range keeps giving error codes E0/F3 and E4/F3 and the ...
Nov 22, 2010
Replaced Sensor Still Getting F3 Error
Sep 20, 2008
F3 Error code on whirlpool Range
Sep 10, 2007
More results from forum.appliancepartspros.com
Amana Fault Codes - Appliance Help O
Dec 25, 2015 | Amana Kitchen Ranges
KitchenAid KHMS155LSS when press "bake potato" button,start flashing error F3
Question: Error Code - Oven - F3 Error Code - F3 E0 Answer Product Symptom:
Error Code/Message - Oven - F3 Error Code - F3 E0
Control displaying F3 E0:
There may be a problem with the Oven Temperature Sensor, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
Jul 31, 2014 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
Thanks
May 26, 2010 | Ovens
F2e0 error on stove
Turn off the breaker and wait for 5 minutes. the follow this 3 steps:
--> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours. It fixed mine.
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
Whirlpool RF196LX Smooth Top Range
Oct 21, 2007 | Kitchen Ranges
Whirlpool GY396 Electric Kitchen Range Logo
1,472 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
