Question about Orange Crush 30R Reverb Guitar Amplifier
Have an orange amp wont go on is there a fuse inside that can burn out thanks
  • 203 Answers
Yes a few fuses i think. plus capacitors and many other things that could blow or burn out.
best thing to do would be get it checked by a technician or find yourself a service manual for it.
Posted on Feb 27, 2009
My fender cybertwin amplifier wont switch on where is the power fuse..
remove the amp. section from the cabinet. you should see a fuse inside near to the main switch.
Nov 22, 2014 | Fender Music
How can you tell if a fuse is blown on a XR 8600 power amp by peavey?
The fuse is probably placed near the power cable entrance in the power amp.
Pick it up from it's placing dock and look for the wire inside. If the wire is whole, the fuze is fine, however, if the wire inside the fuze is missing or burned, the fuze needs to be replaced.
Jan 27, 2013 | Peavey Xr 8600 8 Channel Powered Mixer
Orange crush 20 watt amp wont power up, fuse is good
I have had switches fail. The type they use are common to fail. You can try snapping it on and off a few times real quick to see if it will start working, otherwise you can buy them in bulk from Digikey for a reasonable price- or steal one off a coffee maker.
With it unplugged, just flatten the tabs and push it out the back panel. Short the two wires and plug it in- the amp should turn on.
Mar 31, 2012 | Orange Crush 15r 15w Reverb Guitar...
Dinasaur dg 10 guitar amp no output.suspect xfmr.power comes on i got 120 volts ac at the fuse.I need a schematic
Transformer failures are RARE... check the rectifier and filter components. For diagram you probably will have to go to Orange... they may be very stingy giving it out as well.
Jul 03, 2011 | Orange Amps Orange TH30H Guitar Amp Head
Hi, my amp just died, i turned it on than the led lighted um and died, now i wont turn on ...
UNPLUG THE AMP
First you need to check any visible fuses either in the plug or on the back of the amp.
If you have an electrical testing screwdriver or meter you can test the fuse. If this sounds like gobbledegook (daft talk) then stop and take it to the dealer where you bought it.
If you can remove the fuse or fuses then replace them if it is obvious they have blown - dark and kinda burnt looking.
If replacing the fuses doesn't fix it - STOP.
Valve amps are serious bits of electrical hardware - they are not for home repairs - take it to a GOOD dealer / repair shop that deals with valve amp - nowhere else should play with it. When they have it sorted you can have the valves re-biased/changed to adjust the amp for the sound you want - yes the valves can change it.
Hope this helps - don't mess with it - even when turned OFF valve amps can give you a shock!!
Keep on Rockin'
Feb 18, 2011 | Orange Amps Orange Amplifiers AD Series...
I recently purchased an Orange AD5 amp. It came to me dead so the store I bought it from told me to try to change the fuses for this amp is becoming rare and hard to get. I replaced both fuses with the...
Check for burned components, broken wires or cracked insulation on wires. Inspect the tube sockets and circuit boards for carbon tracks. Next, check the power supply rectifiers for shorts.
If you don't find anything, pull out all of the tubes (be sure to document where each tube goes!) and see if the fuses still blow. If they don't, one of the tubes has an internal short. (If the fuses blew only after warm-up, it would be an overload on a tube rather than a short through the tube.)
If this was a solid-state amplifier, I'd suggest checking the audio output driver transistors - this is the most common fuse-blowing failure in those.
Feb 13, 2011 | Orange Amps Orange Amplifiers AD Series...
I was playing my Orange Crush 20LDX that I just bought today and when I first plugged it in I could smell burning but I thought it wasn't that serious. After a while of playing, the amp still had power...
Since this is a brand new amp right out of the box, I would recommend returning it immediately to the dealer you bought it from. If it can't be repaired under warranty they might replace it with a new one.
Dec 18, 2010 | Orange Amps Orange Amplifiers Crush PiX...
Unfortunately, the correct action here is to return the unit for a replacement one. Any attempt to repair this will void the warranty. Since you just purchased this today, the store should not give you any trouble and just exchange the unit. If you need to, insist on an exchange rather than waste time on a warranty repair.
Good luck,
Dan
Hye. When i switch the on button, the power indicator didnt turn on. Is it because of the tubes or the transformer?
Most likely you blew a bus fuse. Can't say you should open it up and replace it though because there are lethal voltages inside of your amp that could hurt or kill you. You can find replacement bus fuses at radio shack. just make sure you get the same rated fuse. 500mA 125v or something like that in small writing on the metal part of the tiny glass cylinder.
Dec 11, 2010 | Orange Amps Orange Amplifiers TT15C Tiny...
Orange Crush 30R Reverb Guitar Amplifier Logo
485 people viewed this question
Top Orange Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you an Orange Music Expert? Answer questions, earn points and help others
