Question about HP Pavilion (PN153AAR) PC Desktop
My computer starts up fine no beeps all lights and fans all run fine when i start it up. But it dont show anything on the moniter. It is not the video card. I put a new video card in it thinking that might be the problem. The cpu is not burnt no pins missing or broken. Im not sure if it is the cpu or maybe the mother board but I think one of them are bad or shot. I am not sure how to know or how to check to see if either one is bad can anyone tell me how?
  • 2 more comments
  • annietenn Feb 27, 2009
    hm. ok. thanks. I might see if i can find a computer store that will do that for free. or see if i can find someone to do it for me.
    i am good with computers i work on them alot. it is not the power supply thats good. hm i can try to put the cpu in another comp. i have another amd board to. thanks
  • Georgia B
    Georgia B May 11, 2010
    Have you tried a different monitor?
  • Thomas F. Schneider May 11, 2010
    Most shops, I believe, do it by substitution. They put a known good CPU into the board and if that works they know the board s goosd and the CPU is bad. You can also do it the other way around. OPut the CPU in a known good board. Can you get into the BIOS setup screen?
  • 2,692 Answers
Fix Ya?
Posted on Feb 27, 2009
    Problem Solver:
  • 14 Answers
Not a clearcut answer unless you are experienced at bench testing. I will say that nine times out of ten it is the motherboard and not the cpu. If you had another system that would accepts your cpu, you could install that and check but you absolutely should not try this if you are not experienced and know how to do this properly. You also should check the motherboard for burnt areas as well.
There is a slight chance it is the power supply. A bad power supply can sometimes give enough power for the fan and lights but still be bad.
No beeps toshiba x200
IF neither your external Monitor or Laptop LCD screen are inactive, this generally relates to the Video Section on the mainboard a being compromised. The best solution is a bench test done by a technical professional to locate the excact cause.
Jan 07, 2014 | Toshiba Satellite X200-AA3 Notebook
What causes red led on starting?
Remove Power Cord then press and hold the power button for 30 seconds, then put the cord back in and try to start it.
When you press the Power Button are you hearing the fans run, the disk drive running, the cd drive click and the light on it comes on for a second or two?
Anything shows up on the LCD Screen?
If you press the power button and absolutely nothing is happening then you most likely have a bad power supply.
If you press the power button and you start hearing beep sounds or blinking lights in a continuous pattern (ex. 1 long followed by 2 short) then you have a motherboard issue. Those beep sounds and blinking lights tells the technician what is going on with the computer.
Mar 23, 2012 | Dell Dimension 4600 PC Desktop
My computer won't boot up and the orange light just stays on. The moniter is working, the fans in the power supply is working. I was fine yestyerday. I put in hibernate and tried to cut back on today...
Remove the RAM and install it again and will work if still not work then change remove RAM again and start your will give beep sound...if it will not give beep sound then understand your machine's mother board is faulty......
Sep 09, 2011 | E-Machines eMachines Desktop PC
When turned on the computer power light comes on and the fan but nothing else.. Moniter shows no signal, no beep or anything from computer... just sit there with fan running... What can I try toget...
Sounds like the memory is faulty. If there theres more than 1 memory module just try one at a time until you find the faulty 1. If only 1 in there replace it the speed of memory should be written on the old one. Cheers from Scott pls dont forget to vote
Jul 10, 2010 | eMachines T5048 PC Desktop
Computer will not come on loud sound from pavillion repeats it self. The fans will spin and the blue light on pavillion comes on. moniter screen will not come on the power light is on
On some computers, when you turn it on, the fan starts to run at 100% of its speed, i.e., very noisily.
Then, when it is detected that the computer is functioning, and _not_ over-heating, the fan will slow down, and quiet down.
So, what is the nature of the "loud sound" ?
Continuous? Beeps, in some pattern?
Take the computer to a qualified technician, for better trouble-shooting.
Jun 09, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
No signal to monitor. No beeps at start up. Fans running. New video card installed (after issue began) monitor & cord are working fine (have checked both with other computer)
There might be a problem with your RAM you may check your RAM and clean it with a cotton cloth and fix it again or change your RAM and see
Or the problem can also be with your moniter
May 14, 2010 | E-Machines eMachines Desktop PC
Have everything running on computer no signal on moniter or beeps
well if it wont display anything that means the chipset has been damaged somehow my hp pavilion did the same thing and i had to buy a new graphics card try opening up the computer and have a look if you see heat sinks in a square without a fan that will be the chipset smell it if it smells like burnt plastic it needs replacing
Mar 12, 2010 | Acer Aspire T180 PC Desktop
Dell dimension 8400 beeps 6 times monitor dosen't turn on
Below is a link to the beep and light codes for a Dimension 8400. Check your codes and reply back if you need further assistance.
Jun 03, 2009 | Dell Dimension 8400 PC Desktop
No signal shows on monitor
When a computer beeps on start up there is a crucial input output piece of hardware no working. If you have any experience with computers check to make sure everything is conected right. I inclued a link for support for your computer. Larry
Mar 06, 2009 | Computers & Internet
D850GB power problem
The reason that your AGP card fans are on and your drives are on is simple because those devices have power.
If the fan on the processor isn't working, then look for the wire that rut ns out of the fan and into the motherboard. Make sure that's plugged in. If it's not, then plug it in, but if it isn't this most likely means that your Heat Sink/Fan is broken. I woulnd't start your computer if the fan isn't working because your processor might overheat. One thing, if it doesn't beep, that means that it's not posting, which means start up tests are failing. Right now it seems like your processer is the problem right now, but I would take it to a repair center just to be sure.
Jul 26, 2008 | Intel Desktop Board D850GB Motherboard
HP Pavilion (PN153AAR) PC Desktop Logo
77 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
