Question about Hitachi 46F500 46" Rear Projection HDTV-Ready Television
Hey own a 2003 hitachi model #46f500. love it a lot,but has a tint of red on screen. when dark movies are on gets real dark. when its day light on tv it looks great. info please
  • 21 Answers
It sounds like the CRT tubes are weak which will not practical to replace them.
But try to clean the dust on tube first and if it doesn;t help do this...
Caution!
Risk of electric shock, focus block carries 4 kilo votls, do at your own risk or DO NOT do it at all.
Just try to adjust the screen voltage adjustment to brighten the 3 tubes from focus block, to do this you have to open the back then let the TV run for abut 10 minutes beofre adjusting, each tube has its own screen voltage adjustment, read the label make sure not to tuch the focus adjusment, do not crank up too much make it very slow or your TV will show retrace lines or it will shutdown.
good luck.
Posted on Mar 11, 2009
My Hitachi 46F500 TV will not adjust either manually or in magic focus mode......it has green lines across top of screen and some red tinting in the picture ......is this a gun issue or mirror in need of...
Replacing the lamp will do the job. It is the lamp that is faulty not the gun or the mirror.
It will cost just a few box to get a new lamp.
Take care and good luck
Oct 10, 2010 | Hitachi 46F500 46" Rear Projection...
Pictures very dark, Brightness all the way up. Contrast does not adjust
I have the same problem. I was able to temorarily fix the issue by taking the back cover off and blowing all of the dust out. But this only worked for two days. Now the problem is back. Did you fix the issue with your tv? Thanks.
May 28, 2009 | Hitachi 46F500 46" Rear Projection...
I have a Hitachi 57 " rear projection TV, the screen is dark
Unfortunately it sounds like your CRT's ( picture tubes ) are getting weak. You have 3- red, green and blue. It would not be in your best interest to repair it because of the cost of the crt's and if we can still buy them. A lot of analog parts such as those are very hard to locate and is getting worse by the day.
Apr 16, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Have a green tint over 90% ot the center of the screen
I had the same problem with my 60V500A about a year ago. The screen got a red tint in the center and the image was fuzzy in that area. A new lamp didn't solve the problem. I did some checking and found out that the original light engine used in this model had a cooling issue that could cause the light engine to overheat and distort the LCD panels. My warranty had run out more than a year before this happened so I figured I was screwed since the light engine was so expensive. I decided to call Hitachi tech support and see if I could get a discount on the cost of a new light engine since the cooling problem was a known issue for this model TV. I calmly explained to them that I was aware of the cooling issue in the light engine and that I felt like a $4000 TV should last more than two or three years. Tech support gave me the phone number for my local authorized Hitachi service center and I gave them a call. Once the technician confirmed that it was the light engine that was the problem Hitachi sent him a replacement light engine at no cost to me. I was WAY past my warranty period so I still had to pay for the labor to replace the light engine. $300 for labor was a lot cheaper than buying a new light engine or tossing the TV and buying a new one. I have to say that Hitachi earned my respect for admitting there was a problem and doing what was needed to correct the problem more than a year after my warranty had expired.
Feb 20, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
My wife let the Wii remote and broke the front plexi-glass.
You can find a new Hitachi replacement protective screen and screen assembly for a model # 46F500 from a major Hitachi distributor at the following links:
Hitachi 46F500 Replacement Part Screen Assembly
Hitachi 46F500 Replacement Part Protective Screen / Ultra Shield
Feb 03, 2009 | Hitachi 46F500 46" Rear Projection...
Red tint on screen
Good Day,
Try resetting the TV by unplugging from wall outlet for 3 to5 minutes then plug back in. If no fixya take front grill off and panel and adjust the screen controls, turn color off adjust for Black & White Picture. Good Luck, big IRISH.
Sep 13, 2008 | Hitachi 53UWX10B 53" Rear Projection...
HITACHI ultrascan hd tv....
toni, you`ll need a tv tech for this problem, spark gaps need to be cleaned, crt sockets need to be cleaned and crt pins on all 3 crt`s need to be sanded, this is a common issue with this model set, good luck, BMW Rider
Dec 17, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Picture is dark
Pull the back off and tap on the deflection board. Does it get brighter? If so, you have a bad connection and or cold solder joint.
Dec 07, 2007 | Hitachi 46F500 46" Rear Projection...
Pictue is dark as hell
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Oct 27, 2007 | Hitachi 65F59 65" HDTV
Hitachi 55" LCD projector tv
Pixiling problem--replace light engine
need your tv model # to get part #......T
Oct 16, 2007 | Hitachi 46F500 46" Rear Projection...
Hitachi 46F500 46" Rear Projection HDTV-Ready Television Logo
153 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
