Question about Maytag MEW6630D Stainless Steel Electric Double Oven
Maytag mew6630dds top oven light won't go out
Oven light stays on after closing door. Oven light button doesn't turn off light. Cannot get it to turn off. If replacement part is needed, I can repair myself.
SOURCE: Maytag oven will not light
Having same problem.  Broils works.  Oven set to 350 then registers 100.  No gas no heat.  does anyone know the fix?
Posted on May 15, 2008
reg501
  • 413 Answers
SOURCE: Oven stop working
In many cases, even if the igniter is glowing, the resistance may not be low enough to turn on the gas valve. The igniter has probably gone bad. ($50.00 to $90.00 for igniter)
Posted on May 31, 2008
  • 116 Answers
SOURCE: Maytag Electric Oven
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}The error codes suggest that you may be having problems withyour oven temperature sensor (that metal tubing sticking out the back of theoven). You should check that there is no physical damage to the sensor or thatthe connectors are still intact. but after 14yrs - i think its the sensor thatneeds to be changed
Try repairclinic.com - item 1364 about $37
Posted on Sep 04, 2008
EllaWatson25
  • 725 Answers
SOURCE: My Maytag electric oven will not heat beyond a
Your temperature control has gone out and this is simple repair!!
Posted on Oct 20, 2009
  • 1891 Answers
SOURCE: I have a maytag electic flat top oven and I get a
this Fault code F 9 is door latch supervisory .. you need to ck door circuit or replace clock assembly . also called the e r c ) .. this will in most services turn out to be the clock . the clock tells the latch what to do and its doing it . but i would ck the latch first .this part is much less costley .. m.m.
Posted on Nov 20, 2009
Oven door on lock
is the light oven on??? can you see the switch/button that the door would hit against to turn light off?? if so depress button so the lifht goes off, and start a clean cycle.This should make the lock mechanism engage fully. then cancel cycle and should fully disengage lock/latch (you need to depress light switch to trick unit into thinkin the door is closed)
Mar 08, 2008 | Kenmore 30169 Electric Single Oven
Oven door won't stay closed, light on
If the door opens past the 90 degree level position, it means you need new door hinges.
Mar 06, 2013 | Thermador SM272 Electric Double Oven
My JenAir oven door doesn't close fully
most likely you have bad door hinges if the door doesn't close correctly,i don't know if you know this but alot of parts are no loner available for this model,it must be old,the only thing you can get for the door is the hinges and that's it,you'll need the rest of the model number to get the right hinges you're missing the last two letters,you can go here put your model number in to look up parts.
https://www.searspartsdirect.com/model-number/JMW8527CAB/1266/0125300.html
go to door and look at part 16 the hinge,hope this helps you out,when you open the door,if it sags down lower to the ground the hinges are bad,when open it should be at a 90 degree angle
Feb 01, 2018 | Jenn-Air JMW8527C Electric Double Oven
Both oven doors do not close properly. lights stay on & can't heat properly with doors not closing tight. is there an adjustment for these doors?
We have similar Jen Air double oven and with the same problem but only on the lower oven. The doors are interchangeable and the top door fits fine but the lower door will not close completely at the top. It does turn out the light but has never cooked properly. I checked with several appliance repair shops and the hinges are not adjustable, but since one door closes and our other doesn't it is not a hinge problem, just a defective design.
We let this go too long and are out of warranty so I doubt Jennair is going to do anything. I hope someone post a solution but it is clearly not problem with the henges but with the receptacle they go into.
Jan 04, 2011 | Jenn-Air WW27430P Stainless Steel Electric...
Oven stays on
The oven won't come at all.
Jun 05, 2010 | Maytag Ovens
My Wolrd Pool Double Oven Door will not close all
same problem, I tried to adjust the level and tip the oven back, but that didn't work either.
Two options exist, change the hinges, or close the door with a hammer handle between the door and oven. Place the handle down low by hinge, then push the door closed very firmly to pull the hinge outward a bit.
Jan 03, 2010 | Kenmore Ovens
5 year old Jenn Air double oven
the door switch contacts are stuck closed causing the oven to stay on.if you can access the door switch try to wd-40 on it.if that doesnt help you need a door switch.
Aug 16, 2007 | Jenn-Air JMW9527C Stainless Steel Electric...
Maytag MEW6630D Stainless Steel Electric Double Oven Logo
81 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
