Question about Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
Filter What type of sensing unit does the Frigidaire model phs38ejsb use to know that the air filter needs replacing?
    President:
  • Electrolux Master
  • 2,651 Answers
No sensor, strictly a timer based indicator, what ever its preset to from the factory, is when it will "flash" or "indicate" replace, it really doenst mointor it any further, the water dispensor filter works on same premis
Posted on Mar 04, 2009
What causes compressor to work fine then shut down and not come back on for an extended amount of time?
Sometimes these AC's need to be removed and given a damm good cleaning with a spray hose, and any filters replaced. Clean the internal fan(s).
This can sometimes fix overharting of the compressor or misleading air temp sensing..
Jul 08, 2015 | Frigidaire FRA296ST2 Air Conditioner
Frigidaire AC window unit, model fam185r2a (18,500 BTU) only cools for a few minutes before it cycles off and just fan blows. Then a few min later cool air cycles back on. Is this a thermostat issue?
The window units normally have a sensor thats attached to the front of the indoor coil. This controls the thermostat. I usually pull this sensor away from the coil because it stops cooling before the room is cool. It is attached to the cold coil so it senses the coil temp, not the room temp. You can normally see it when you remove the air filter. Don't break it! It may be a wire or small copper tube
Jun 10, 2015 | Frigidaire Heating & Cooling
How to plug up sensing element
Thank you for your post, Inez!
I understand you would like to know how to plug up the sensing element inside of your Frigidaire air conditioner. In order to further assist you may I have your model number? You can locate your serial tag (which lists your model number) on the side of your air conditioner. With that information I can further assist you. -Matt
May 16, 2015 | Frigidaire Heating & Cooling
How do I change the air filter
Hello friend, thanks for your post!
In order to change the air filter in your Frigidaire refrigerator you would need to pull the filter out of its housing. Would you be able to provide me with your model number please? Normally you can locate your serial tag (which lists your model number) on the inside right hand wall of your refrigerator. With that I can verify the type of air filter and even provide you with the part number and price of a new replacement filter. I look forward to further assisting you. -Matt
Oct 06, 2014 | Frigidaire Refrigerators
A/C unit does not blow cold air
Good Morning Friend,
I understand your Frigidaire air conditioner, model# FAA055P7A1, is not blowing cold air. I also see that you have had it in storage and it has not been run for 5 seasons. Please note that the "Cool " circuit has an automatic 3 minute time delayed start if the unit is turned off and on quickly. This prevents overheating of the compressor and possible circuit breaker tripping. The fan will continue to run during this time.
First, make sure you have cleaned the filter by following these instructions:
• Push the vent handle to the Vent Closed position (where applicable).
• Open the front panel.
• Grasp the filter by the center and pull up and out.
• Wash the filter using liquid dishwashing detergent and warm water. Rinse filter thoroughly. Gently shake excess water from the filter. Be sure filter is thoroughly dry before replacing.
• Or, instead of washing you may vacuum the filter clean.
Secondly, make sure the temperature sensing element, located behind the air filter, is not touching a cold coil. If it is straighten it away from the coil.
Lastly, try resetting your air conditioner to a lower temperature.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire Heating & Cooling
Why is Unit not cooling?
I understand your Frigidaire air conditioner, model# FAS296R2A, is not cooling. I also see that, both the filter and condenser are clean. First, try setting the temperature lower. Secondly, the compressor could have shut off by changing modes. Set to the "COOL" setting and wait about 3 minutes for the compressor to restart. Lastly, check the temperature sensing element, located behind the air filter, to make sure it is not touching a cold coil. If it is, straighten the sensor away from the coil. I hope this is helpful.
-Best Regards-
WP
Jun 21, 2014 | Frigidaire FAS296R2A Air Conditioner
The unit is only 4 months old. bought from lowes in warsaw in.they dont have a repair or cant replace it out of stock, contaced custermer services . she gave two fridgidair repaire places ,they dont...
Sears sells fridgidair parts. Go to sears .com under there appliance parts. You should Find the part you need. You might want to check to make sure the sensing bulb for the Thermostat is in front of the cooling coil just behind your air filter. If it not located properly It can't properly sense the air temp. And may not shut down .
Aug 28, 2011 | Frigidaire FRA256ST2 WallWindow Air...
Just wondering if this unit has a filter or filters that need to be changed?? (Frigidaire 70)
Yes, your unit has an air filter, that should be removed and cleaned at least once every two weeks, while in operation, The filter is located behind the louvers on the front of the unit. To access and remove it, remove the water bucket and just inside the bucket holder at the top of the opening, you will see a tab type of handle. This handle is part of the filter frame. Pull that down and out and the filter will come with it. Back flush the filter with clear warm water. Dry it thoroughly, before reinstalling it in the unit. Never operate the dehumidifier without the filter installed.
To assist you further, in case you have misplaced your Owner's Manual, I have included a link to the Manual for your model. You can download and print the manual for future reference.
http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020266a0180en.pdf
Hope this helped you. Please let me know. Thanks.
Jun 25, 2011 | Frigidaire FDF70S Dehumidifier
Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
75 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
