Question about Gateway (tabletpc)
Gateway Tablet PC battery problem
I am having a problem with my gateway tablet pc holding power. It is not the cord, I have tried other people's cords and it still has the same problem.
It works when I hold the cord in to the port so I think it may have something to do with the port.
  • Anonymous Mar 31, 2014
    when the charger cord is inserted it moves and the tablet will not charge
  • 80 Answers
Yes the port on the motherboard is messed up!
thanks
erik
Posted on Feb 27, 2009
Kocaso M750B Android 4.0 OS 7" Capacitive Touch Tablet PC came with wrong power cord
I don't have a fix, but I feel a scam since I just got mine today from No More Rack & mine cord doesn't fit either.
Apr 02, 2013 | Kocaso M750B Android 4.0 OS 7" Capacitive...
Coby tablet mid7015 not charging
Either the power cord, battery, or motherboard is dead.
Bring it to where you bought it and test it with a new power cord. If that doesn't fix the problem then have them fix it.
May 19, 2012 | Coby Kyros 716829701508 Tablet PC
My tablet wont charge unless turned on but battery is so low it wont turn on so cant charge it up.heeeeeelllllpppp
You Power Cord must be bad. If you cannot get on the laptop by using just the power cord, then the power cord is bad and needs to be replaced. Also it sounds like you've been operating off your battery since the power cord is bad, but now the battery is dead because the bad power cord was not charging it.
Get a new AC Adapter and Power Cord. Or it could be that the pin where you plug the power cord into the table is damaged or broken.
May 15, 2012 | Archos 101 Internet Tablet 16GB 10.1"...
Gateway M1300 tablet pc will not charge in the
Question 1: Will the tablet operate on the docking station (or power cord) without the battery in place?
If not, the power circuit on the tablet motherboard is broken.
Question 2: If you plug in the power cord into the tablet, is the connection "loose"?
Check the other tablet to see if it is the same loosness at the tablet power connector.
If it is loose, the power receptical in the tablet can be soldered back onto the motherboard.
Recommend taking it into a shop to re-solder.
If under warranty, get it repaired.
If not under warranty, your choice if you want to use it they way it is.
Hope this helps...
Sep 03, 2009 | Gateway m1300-3004372 Tablet PC
Where can i download sofware of gateway
For your tablet to function again, you'll need the WACOM tablet driver which is NOT provided by Gateway, since they do not manufacture the tablet themselves.
You'll need the following drivers from the GATEWAY site to fix your button issue:
9524572.exe - Gateway M275 Button driver, version 5.01.2600.2156
and from the WACOM site you'll need the Tablet PC driver.
-Go to www.Wacom.com
-Select your location and language on the right
-On the next page, choose downloads from the top navigation bar
-In Step 1 scroll down and pick Tablet PC
-In Step 2 choose your operating system
-Follow the download instructions provided on the site from there
Jan 17, 2009 | Gateway M275 Tablet PC
My Gateway m275 tablet will not charge or power up even with it plugged in
At least a 50% chance the power pin inside the computer has been damaged. Taking apart a laptop and getting it back together correctly is a tough job . . . .The part (the power pin) is not that expensive ($ 5-10) but the labor is expensive. If you don;t feel up to the task, have it fixed by a professional and after it''s fixed get a CRD (Cable Retention Device) to keep from damaging the pin a second time.
Jul 28, 2008 | Gateway M275 Tablet PC
Gateway M275 will not botot
try removing the battery and then booting without the battery attached
Jun 27, 2007 | Gateway M275 Tablet PC
Need touchscreen drivers for Gateway M1200. Hi there I recently bougth a Gateway M 1200 Tablet PC. Unfortunatly I did not get any operating system or drivers and has not been able to use my touchscreen. ...
I just bought one of these used, It had a fresh intall of windows XP tablet. When I got it the touch screen would not work. I have tried dowloading the drivers. I download Motion dashboard for this model. When I open it is says" Dashboard can not be run on this computer" I dont know what to do??
Dec 17, 2006 | Gateway M1200-3004265 Tablet PC
Gateway (tabletpc) Logo
171 people viewed this question
Top Gateway Tablets & eReaders Experts
ashburton
Ricky Ostrom
Ricky Ostrom
vojvodabudva
Are you a Gateway Tablet and eReader Expert? Answer questions, earn points and help others
