My washer would only wash about 5 seconds an cut off,ERR also appears on the led screen.
Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front, screws beneath; if you find a pipe there with a cap -this is for draining water. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp (or unscrew) that connects the trap assembly to the pump and clean it out.
If helped pl say so.
SOURCE: Frigidaire Affinity ATF7000 - E20 error code
Thanks to the different postings on the net about a E20 error code I took apart my washer’s drain system ATF7000 to find. A pare of little girls underpants, one hair band, one plastic green gem, a golf ball sized wad of wrappers/stickers/???, and almost two dollars in coins. All caught up in the plastic strainer located inside the black rubber boot found on the bottom of the tub leading into the drain pump.
Here is how I did it: After emptying the washer of sloppy contents, I sucked as much of the water out with a shop-vac. I then turned the washer onto it’s left side gently using a couple of towels as a cushion (unplugging the washer and hoses first). From the bottom and back panel you can access the drain hose/pump/coin catch. With a pair of pliers you can remove the clamp holding smaller end of the rubber coin catch to the tub, with a Phillips screw driver you can remove the larger clamp of the rubber coin catch to the tub. From the back panel you again use your pliers to remove the clamp to the drain line, and finally with a Philips screw driver remove the two screws holding the pump to the bottom of the washer. Oh yah, do not forget to unplug the wire from the pump. Now pull the pump out with the black rubber boot still attached. Mark the orientation of the pump to the boot with a sharpie pen, and remove the last clamp. Now look inside the black rubber boot and gently remove the plastic basket inside, there you will find the treasures that just wasted the last hour of your time. Now reveres those steps, reinsert the half washed clothes, and enjoy your new machine.
Thanks again to everyone that has posted before me, otherwise I wouldn’t have known were to even start looking. I hope this helps someone.
SOURCE: frigidaire affinity indicates 'err' light - nothing else
Dear Abhkss
ngfam at you service,
Sounds like you need service for electronic parts!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
SOURCE: Frigidaire Affinity ATF7000ESI - won't spin
I just had this problem with my Frigidaire Affinity ATF7000EE0.
When the machine seems to work fine (as it will wash but just won't kick into a spin cycle) it is most likely the door lock/switch assembly. In addition to the actual door lock solenoid and door closed switch, the assembly contains a secondary lock in the form of a wax motor and an auxiliary switch. This wax motor and switch activates during the spin cycle. When the wax motor goes bad the secondary lock does not activate therefore the spin cycle switch does not activate, which in turn disables the spin cycle. Even though you can hear your door lock kick in and the door is locked it is most likely the secondary lock in this switch assembly. Start by replacing it first.
Unplug the washer unless you want to get shocked! Take out the two screws at the back of the washer that holds on the washer top and remove the top by sliding towards the back of the machine and lift up. You can go to the front of the machine and reach down inside to the door lock while removing the two screws that hold it in from the outside front of the machine. Once the lock is removed there should be enough wire slack to get the lock up above the tub before you go and try to unplug any connections. Make sure and make notes as to where your connections go on the switch. Simply unplug the old switch and plug your new lock assembly in, remount it, and put the top back on. You should be good to go.
One note, don't panic if you select spin cycle and it doesn't start spinning immediately. Wax motors actuate very slow and smoothly. It could take up to a minute for the lock and switch mechanism to get into place before the spin will start.
Have a great day!
SOURCE: I have a frigidaire affinity front loader washer
There is an auxiliary switch in the door lock and switch assembly that
is activated at the end of the wash cycle for the machine to advance to the spin cycle.
This is a safety feature to prevent the door from opening during the spin cycle and the machine will not spin unless the switch is activated. The machine works except advancing to the spin cycle and this signifies
that the auxiliary switch cannot be activated and the door lock and
switch assembly is faulty. Replaced the door lock and switch assembly
(part #131763202) to address the issue.
Disconnect power to the
machine. Open the washer door then look for the retaining hoop securing
the door seal around the lip of the door opening. Stretch the retainer
spring of the door seal retaining hoop then remove it.
Carefully
peel off part of the door seal from the lip of the door opening near the
door lock and switch assembly. Remove enough of the door seal to gain
access to the door lock and switch assembly.
Remove the screws
securing the door lock and switch assembly to the front panel. Once the
screws are removed, lift the door lock and switch assembly then pull it
away from the front panel.
Take the door lock and switch assembly
out of the machine. Disconnect the electrical connections then
connect it to the new door lock and switch assembly.
Put the new
door lock and switch assembly back into position in the front panel and
secure it with the securing screws.
Properly put the eased part
of the door seal back over the lip of the door opening then secure it
with the retaining hoop.
