Question about Starbucks Saeco Italia Digital Barista Coffee Machine
My Italia wont pump water for the shot.
My Saeco Italia runs through the brew cycle normally ... grinds beans transfers them to the brew unit, mechanically moves over to press the shot and then won't pump water. The water pumps through the wand just fine but not into the brew unit. any suggestions?
I had the same issue. I even took the unit apart (which I DON'T recommend). What fixed my issue was a "deep" cleaning. I ran full strength CLR into the unit by filling the water tank with only CLR and running the wand until CLR came out. Then I turned the unit off over night. I also cleaned the white "nipple" where the water transfers from the machine to the brewing station. I did this while the unit was apart, but would suggest using full strength CLR on a q-tip and let it sit overnight as well. I then flushed the machine VERY well - and now it works like a champ.
Good Luck.
Posted on Dec 04, 2011
  • 29 Answers
Http://www.starbucks.com/customer/faq_qanda.asp?name=brewequip
this link has alot of troubleshooting ideas, and at the bottom of the page u can download the manual
Posted on Feb 27, 2009
Saeco odea does not brew coffee, all the water goes in the drip pan
Hello, the water in drip pan is clea water ot coffee water?(brown). Take a pucture inside machine with no brew unit inside.
Aug 27, 2017 | Saeco Coffee Makers & Espresso Machines
Saeco incanto water doesnt cycle
can you hear the unit working and the pump activating in the unit if you can most of the time units get clogs in the nozzle heads if you use a pin or needle to clean out the nozzle head it will restore the water flow so that the water is able to come back out the nozzle. This is mostly due to when people use the finest setting to grind the bean and dont realize that coffee beans contain oil and what happens when you mix oil and water and very small grind it forms clogs in small areas if you are not hearing the pump run then you most likely are not supplying the unit with the proper amount of power to run the pump. If you have any further questions message me back.
Thank you
Rick
Dec 28, 2011 | Saeco Incanto Classic Espresso Machine
I put beans in where the grinds should go. help!?
Hi
Open the door and remove the drip tray. Then remove the brew unit and empty the beans. Make sure that you get all the beans. Check the brew unit thoroughly. Then put everything back. Try the pre ground button but don't put anything in the brew unit then push the medium coffee button. That will run the machine through a brew cycle and if it works OK then you set to go.
Dec 30, 2009 | Saeco Incanto Classic Espresso Machine
Hello- I have a Saeco Italia machine, about 4
Try this press the pre ground button then the coffee brew button, if water flows from the spout then the grinder chute is blocked, if no water flows then the brew unit is screen blocked.
If grinder, then remove the brew unit and check the chute from the grinder.
Sep 27, 2009 | Coffee Makers & Espresso Machines
Saeco italia has front red light explanation
This red light is to indicate if the water tank needs filling, if the bean hopper needs filling, or if the brew unit is not in the unit (after cleaning) or not in the correct position.
Dec 28, 2008 | Saeco Easy Espresso Machine
Saeco Italia SUP021 YR - Red light #29 on solid
Not clear on "Empty bean container/full grounds drawer) - not empty/not full. " But I gather that coffee is not being dispensed. Most Likely the grinder needs cleaning + brew group needs cleaning ( filter ). Do you get water/steam?
Jun 10, 2008 | Starbucks Saeco Italia Digital Barista...
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
369 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
