Question about Kenmore 62802 Electric Dryer
Show me how the belt should be run - Kenmore 62802 Electric Dryer
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Please post your COMPLETE model number so I can confirm. All dryer belts are not routed the same way...
  • Kenmore Master
  • 8,220 Answers
Stick the idler in the floorboard, even with the motor pulley and have the idler wheel facing to the left of that motor pulley. Insert the non twisted belt into the idler between the cheapass metal idler pulley mount(have yer woman hold that drum up, make her proud to assist) and now yank back on the idler good nuff to get that belt looped over that motor pully. Then let that idler go so the tenshun on dat boy cause dat belt to stay all propah on dat pulley. Replace that front panel. show me how the belt should be run - 05cc3f4.jpg
Belt config
Posted on Mar 10, 2009
How do i replace belt on ariens
The best method is remember pulleys with flat sides run on the outside of the belt and "V" shaped pulleys run inside the belt. The owner's manual should show belt routing or go to www.ariens.com and download a parts list. This should help you determine the belt path.
Oct 19, 2014 | Ariens 42" Riding Lawn Mower Blade ...
I have it all set up..programmed a work out...it starts to work..but the tread itself that you walk on wont run..what do I do?
From the User manual....here
http://servicedocuments.com/pdfs/_0005_SOLE/_0005_SOLE_01_Treadmills/003_OwnersManuals/2010_2011_SOLE/F63_F65_OM_810.pdf
'1.If the belt moves, but stops after a short time and
thedisplay shows "LS", run calibration. (on next page)
2.If you press start and the belt never moves, then
the display shows LS, contact service.
Sep 14, 2014 | Sole Fitness F63 Treadmill
When do I change my belts on a 2005 Altima
It's time to change any belts when the belts show wear or is showing hair line cracks or seems to be slipping and squeaking because of stretching.or wear. Make sure you look at the part of the belt that runs on the pulleys.
Sep 09, 2014 | 2005 Nissan Altima
Replace alternater belts
The 3.5 engine uses a serpentine belt which runs everything.
You would release the tension on the tensioner pulley and remove the belt. There should be a diagram on the hood or radiator support showing the belt routing. If not, be sure and draw a diagram before you remove the old belt.
Jul 14, 2014 | 2006 Buick Rendezvous
What's the belt routing on a 250 line 6 engine 1975 maverick.
wow a running maverick.. a true blast from the pass.
here you'd get lookers. , what's that mister?
i run a 68 car and get that all the time...fun.
this is just a v belt engine, its real simple.
all the pulleys line up.
was yours missing. my guess, is you are fixing a beater with parts missing, right>? (my craft now is that, but retired.)
70Mav
what are the options, A/C , power steering? air pump?
the FSM online, ALL data , dont show routing , there is no need,
its a V belt. so is no routing.
one photo shows.
6-250 with A/C
and the guy is setting tension with the 2 slot 2 belt altenator pulley
he is at the Alternator adjustment bolt.
say splace socket here, top front alt.
do post what is under hood, and say what is missing
accessory-wise and belt wize
The P/S photos shows adjusting the P/S bolt head top left corner. of pump.
May 15, 2014 | Cars & Trucks
Timing belt runs ruff. when it gets hot it stops
The ruff noise you have on the timing belt shows the belt quality,which is better to change the belt with a recommended by the manufacturer,for better results and more protection and safety.
Sep 14, 2012 | 1999 Mercury Villager
My Nordictrack X9i treadmill console says it is operating at speed, however the track is not moving. Occasionally the belt will move for just a moment then it stops.
do you hear the motor running but the belt is not? if it is the belt need tightened or the drive belt may have broken. remove the motor hood to inspect
Aug 23, 2012 | NordicTrack Exercise & Fitness
Our hotpoint WMA50 is draining but the drum is not turning
Can you hear the motor running if you can all that is needed is a new belt. But if you can not hear the motor running then the motors carbon brushes need replacing. http://www.youtube.com/watch?v=HELgV4KOsT0&feature=channel this shows the carbon brushes on a hotpoint. http://www.youtube.com/watch?v=X1yY_6vKK8g&feature=channel This shows how to change belt. hope this helped.
Dec 28, 2010 | Hotpoint Washing Machines
Serpentine belt
depending on the shop a serpintine belt replacement on your vehicle will run about $50 - $100 in labor alone. the belt uses the power of the engine to run accessory systems like your air conditioning, powersteering. and vital systems like running the alternator to charge your battery and turn the water pump to circulate coolant/antifreeze in the cooling system. typically on a corrolla a belt will last roughly 50,000 miles before it starts showing signs or wear which are cracking and squealing, if you dont replace it the cracks will get worse over time until the belt eventually breaks. which to be honest takes a very long time.
Nov 11, 2009 | 1998 Toyota Corolla
Replace serpentine belt for 2005 chevrolet equinox
There should be a belt diagram sticker on the core support cover on top of your radiator showing you the routing of this belt
May 27, 2009 | 2005 Chevrolet Equinox
Kenmore 62802 Electric Dryer Logo
137 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
