Question about Kenmore Washing Machines
My wash machine keeps filling unless i manually change the cycle
    Scholar:
  • 106 Answers
Does your machine fill with water even if the machine is off? In this case your inlet valve at top of machine is defective & can be easily replaced (will tell u where to get spares, if your dealer cannot) by yourself.
If water does not stop, after filling machine at a low level(is this a front loader?) and is flowing away - check your exit pipe, it has to have a certain height (approx 3 feet) up before going down to your drain pipe. RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Try these sites.
Posted on Feb 27, 2009
Set a cycle, it will go around and around until manually turn the off button.... Nothing working, fills up, but does not spin.
Sounds like your circuit board has a problem. go to www.repairclinic.com. Look up washing machines and enter your model number, then a list of parts show up, they have a trouble shooting column. They have videos and the parts you will need.
Mar 10, 2015 | Asko W600
My tawx400rq1 washing machine won't go to rinse cycle...the water just fills to a certain level and keeps running while draining at the same time, keeping the level the same. Manual changing the cycle...
your water level switch has gone defective making the machine think it hasn't filled yet replace the unit and it will work again it`s round and has a small tube/hose attached to the bottom and a number of wires to the top , make certain you note where the wires go back most any appliance service place will have a switch for you,,good luck
Feb 28, 2011 | Washing Machines
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Washer won't cycle past fill, keeps returning to fill cycle
That could be excess detergent causing the control to do extra washes to get rid of detected Suds. On these washers it is critical to use HE detergent and the right amount. Most often directions on detergent boxes are useless. This washer has a 3 phase motor with an inverter to change the current from 120 to 200 volts dc. If you continue to use wrong amounts of detergent the inline fuse will eventually blow from the motor overheating trying to correct overdose of detergent. Read more about it in the GE HYDROWAVE SERVICE MANUAL
Apr 24, 2010 | GE WHRE5260E Top Load Washer
Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine continues to fill when starts
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Oct 01, 2009 | Washing Machines
My Indesit Washer/Dryer repeatedly (but not always) gets stuck on the initial water collection part of the wash cycle. It makes a sound like water is filling (or draining) into the machine, there is water...
Pressure switch is likely clogged/full of sediment.
Change it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 07, 2009 | Washing Machines
Keeps filling up even when full for over 4 hours (never changed cycles)
The timer sends a signal to the water level control valve. This valve serves two primary purposes. 1. Activate the water valve to fill the machine. 2. Shut the water flow down and allow the machine to operate. Try running the machine again. If the water continues to enter the machine after it begins aggitating then shut the water off at the spigot. Now watch and see if the timer moves or not.
If the timer does not move at all then I would replace the timer. If it DOES move then another problem exists and will need to be addressed.
Jan 13, 2008 | Maytag Performa PAV2200
Re EW1200i : drum keeps filling with water
is it overfilling? if so you have a problem with the pressure side of the system and it would need cleaning out.
May 26, 2007 | Electrolux EW1200i Front Load Washer /...
Washing Machines Logo
23 people viewed this question
Sal De
fordexpert
Robert Rankin
