When I try to connect from HDMI output of laptop to Samsung 43" Plasma, the tv shows no signal. I have tried a different cable, tried reinstalling HDMI driver all without results. Any ideas please.
SOURCE: cant get sound via hdmi connection from acer 6920g laptop
go into control pannel and acer hd set it there and also in sound, a wee bit of trial and error but its there. mine was the same, it cost me ouch on the phone! good luck mine works ok
SOURCE: connecting asus notebook via hdmi to LG 42 plasma tv
best option to use s-video lead ...use fn + f-key that has little square printed on it ...hp mostly fn+f4
SOURCE: connecting asus M51V to Panasonic TH-42PX8A plasma via HDMI
Hi
Make sure your TV does indeed support the resolutions you are trying to use. Some low quality HDMI cables can also be troublesome in higher resolution so try one you are sure to work.
Regarding to the desktop only being extended when using the RGB cables, try bringing up the desktop properties window, select the TV as the primary monitor and select "Use this monitor as Primary monitor". You might have to drag the windows Taskbar over to the other monitor, just rightclick the taskbar, uncheck "Lock the Taskbar" and drag it over to the other monitor.
Hope you find this solution helpful, and please rate it if you do so..
best regards,
Karl
SOURCE: Connect Laptop HDMI to Receiver to TV via SVIDEO
you need a different type of cable to connect to your tv.a s-video will fit but not work.can't remember the name but it has to have more pins.besides that port is for projectors and cannot be used for anything else.you need a converter box like the one in the link ::::: http://www.bing.com/images/search?q=laptops+s-video+cords&FORM=BIFD#focal=a85da1a40c404788d7e32f0bf01eab05&furl=http%3A%2F%2Fwww.cvs.k12.mi.us%2Ftiz%2Fimages%2Fsvid-cables.jpg
unless you got a big tv with a very good picture it isn't worth it.and a good graphics card in the comp.most tvs are fuzzy and unreadable.i've did it enough to know
SOURCE: I have an Acer Aspire 8930G trying to connect to my TV with HDMI
After you connected the HDMI Cable to the TV...Did you press the FN + F4 Key on the keyboard... The first screen you will see is the notebook screen is blank and the TV has got the desktop on top of it...The second time you press the FN + F4 then you will see thedesktop on the notebook and as well as the TV...The third time you press the FN+F4 you will see the desktop on the Notebook...
