Question about Singer QuantumLock 14T967DC
On theQuantumLock 14T967DC, for the coverstitch, the machine appears to be threaded right, but the bottom looper threads are not catching the top threads.
  • 192 Answers
SOURCE: Bottom thread will not catch
Unplug the machine and remove the needle plate so that the bobbin case if fully exposed. Lift out the bobbin case and the cup that it sets in will be visible. Locate the "hook" on this cup. It is a finger with a sharp point at the upper edge of the cup. The hook is what grabs the thread from the needle while sewing.
  • Thread the needle.
  • Turn the handwheel by hand.
  • Watch the hook as it approaches the needle from right to left.
If the hook passes by the needle AFTER the eye of the needle is above it, you timing has slipped and the machine must be taken in for repair.
If the hook catches the thread from the needle, put everything back together and try threading again.
Posted on Nov 14, 2007
  • 106 Answers
SOURCE: Singer ProFinish Threading Problem
If you are sure it is threaded correctly, slacken the tension right off and adjust it a bit at a time until you achieve a good stitch. Make sure that the thread comes off the bobbin vertically and does not snag anywhere.
Posted on Apr 24, 2008
  • 323 Answers
SOURCE: Sewing Machine (brother XL 3200)
Your machine is out of time and needs to be serviced by a technician.
sewman7
Posted on Jul 19, 2008
kent581
  • 87 Answers
SOURCE: bottom of stitch is bunched with alot of thread and machine jams
Try these time savers:
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test, then let me know, we can go to step 2. If not, try different spool of thread, same test until you get a smooth pull (tip: always check your thread this way when you thread your machine)
Step 2:
Pull on your threaded bobbin thread while it’s in the machine. Does it pull smooth and even? If so, go to step 3. If not, try a new bobbin (bobbins get bent or distorted if wound too tight).
Clean thoroughly in the hook and bobbin case area and oil 1-2 drop is all.
Posted on Mar 18, 2009
  • 18 Answers
SOURCE: Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
.... http://sewingonline.co.uk/singer-manuals.html
Posted on Aug 16, 2009
Singer 14T967dc serger runs but does not stitch
Hello Laura
Make sure that the lower looper thread is in front of and over the upper looper thread when threading the serger; when threading for overlocking.
Please let me know how this worked out for you
Happy serging
Feb 24, 2017 | Singer Sewing Machines
How do I thread the cover stitch looper on the Elna 744?
On my coverstitch,the lower looper swings out to the right so I can access the thread eyelet, wondering if yours is the same?. And i dont pull the thread up to he top, just leave a tail loose, make sure i swing the looper ack to the left, then close cover and stitch.
Mar 01, 2015 | Elna Sewing Machines
Singer 756u stitches not catching
So this is a serger? Might have been nice to know that. Make sure you have threaded your serger in the correct order. upper looper, lower looper, needles from right to left.
Make sure you do this with the presser foot lever in the UP position. Make sure all the threads are pulled fully into any tension guides.
Sep 01, 2012 | Singer Sewing Machines
Can't thread a consew 694ex
Typically a serger is threaded... upper looper(s) Lower looper(s) Needles from right to left. Anything else will cause you problems. If you break a thread... remove all other threads and begin again at the upper loopers.
Aug 23, 2012 | Sewing Machines
I am trying to do a rolled hem using a singer ultralock 14sh654. Do I disengage the knife? The stitches are uneven and some are quite loose no matter how much I adjust the tension. I am positive I...
no, you need the blade in place and cutting to give an even cut fabric edge. Set up for a three thread using the right hand needle, take out the left hand needle. move blade over to the right so it is cutting wide. Most overlockers there is also a thread finger you need to change on the foot, or a little lever you flick to move this finger forward into the stitching area. Check this on your manual as each make is a bit different.
If you can source it, put wooly nylon thread into the upper looper (knot it onto existing thread and just chain it through, the knot should go through the looper eye fine). Now turn the tension on top looper down so it is looser and tighten up tension on bottom looper, so needle 5, top looper 2 and bottom looper about 7.
Now test serge, the fabric cut edge should be wider than the overlocking seam so the fabric rolls under inside the stitching. Adjust the two looper threads so that this is happening, you want the bottom looper thread to nest right up against the needle stitch and the top looper thread to wrap all the way around too.
Once you've got this happening, turn the stitch length down to 0.5, to close the stitching right up. On some fabrics you'll need to adjust the differential feed too if the fabric is "waving" a bit.
Uneven stitches or sometimes loose when serging could indicate that one of the tension devices is faulting, so if this machine is not new and its doing this, it could need a service. Can you get a regular smooth three or 4 thread seam out if it???
It is always good to just recheck the threading path, make sure the thread aerial is up and that a thread hasn't got caught back on the thread stand somewhere if you're getting something wonky happening, threads stream off overlocker cones through the machine so anything wrong in the thread path will throw off the stitching.
Jun 25, 2011 | Singer 14SH654
Lower looper thread gets stuck in the clip and breaks
does this Serger have a moveable threading part on the lower looper and if so, is it in the correct position? It sounds like the clip is in the wrong place if it is catching the thread, so this could be the cause if so.
If not, then I would suggest that you recheck the threading, and thread in sequence, top looper, bottom looper, then needles, checking all thread loops are being used in the thread path, review carefully using the manual's threading diagram.
If you still can't resolve the issue, then take it in for a service, it is possible to knock the loopers out of time and if so, you'll need a technician to rectify.
May 23, 2011 | Brother Lay-In Thread Serger Mechanical...
Bernina 800d sewing machine
You might take a look on ebay item with bernina 700d/800dl instruction manual
Apr 28, 2010 | Bernina 1008
How to use double needle
That stitch is called a coverhem or a coverstitch. It is made with a coverhem machine which is basically a serger with an orbiting looper. Many upper end home sergers have coverstitch capabilities (Elna 945)
To use a double needle, simply thread two threads the same way that you would thread one. ONLY USE A STRAIGHT STITCH, AS THE NEEDLE WILL STRIKE THE PLATE IF IT ZIG ZAGS TOO WIDE.
Jan 05, 2010 | Bernina Artista 180
Coverstitch tensions to tight
Coverstitch machines are very particular when it comes to thread. Use only MaxiLock cone thread. Do not use TruSew or SureLock thread. This can make the difference between working beautifully or not at all.
Jul 11, 2009 | Sewing Machines
Skipping stitches on coverstitch machine
To avoid skipped stitches on a coverstitch machine you need to use ELs (extra long) or SUK (stretch) needles and good quality thread. Poor quality thread is too fluffy and varies in thickness which can cause stitch problems. Try Maxilock thread from a cone or use maxilock on looper and regular sewing machine thread through needles and see if this improves the stitches. Also loosen off the lower looper tension to zero and see if this helps. If you are hemming around a garment and sewing across an overlocked seam then you need to minimise bulk too. lightly press the seams into the diretion you want them to sit when garment is finished, press the hem up, then force the seam allowance in the hem turnup area to the opposite direction. This spreads the seam bulk in both directions.
There is a knack to coverstitch machines but a good cover finish is quicker than twin needle on SM.
Apr 04, 2009 | Janome 900CP
Sewing Machines Logo
49 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
