Question about Tomtom ONE GPS Receiver
Cant start tom tom
Dont connect to computer
charge it independently until fully charged, then turn it on without plugging to computer
you only plug in to computer when you want to update and down load
  • teslatile Feb 28, 2009
    Hi everyone, My tom tom xl one didnt work for 10 months now.
    I just stopped using it. It wouldnt charge right from the car charger. So it was dead. Now I charged it correctly on the comp. and now it wont turn on. What's going on here? Can anyone help please.
    Thank you, Boyan T. Atlanta, GA.
  • Anonymous Mar 02, 2009
    What is a pin reset? How do I do it? I was able to turn the XL one on, and it worked all day yestarday. But now it doesnt want to turn on and stay on, and if it did. It would give me a blank screen or black and white diagonal lines. I am getting pissed at this peace of *&#@% and ready to give it a proper berial. But Thank you for trying.
  • 24 Answers
Don't forget PIN reset
Posted on Mar 01, 2009
Why does my tom tom keep going the shut down page every 10 seconds I have pressed reset but makes no difference I ride bmw r1200rt
One possible cause is that your battery is low or the battery can no longer hold a (good) charge. In this case, the TomTom is shutting down because there's not enough battery to keep it running, even though it is plugged into a power source.
To determine if the battery is the cause, try to charge the TomTom battery .... using a (USB) connection to your computer, or a direct power source (i.e. while the TomTom is not being used). Let it charge for a few hours until the batter charge indicator shows that it is fully charged (or just leave it charging overnight).
Then, unplug the TomTom from the "charger" and power it up. If the TomTom (battery) doesn't hold a (good) charge, the device will shut down within a few minutes, e.g. 10 mins or much less.
When you (then) plug the device into a power source, and it doesn't stay on (i.e. it keeps shutting down after 10 seconds), you can safely conclude that the battery is the cause of your problem.
Apr 24, 2016 | Tomtom GPS
My Tom Tom XXL won't turn on when plugged in.
The GPS device runs off the battery ... so, you need to charge the battery (fully, or enough to power the GPS) before you start using it again. For clarity, if the battery is not charged, the GPS will not run when plugged into a power source.
Feb 19, 2013 | Tomtom ONE GPS Receiver
My new Tom Tom will not start past the first screen that shows the name Tom Tom.....how do I get it to operate properly. If I depress the start button for about 14 seconds it goes to a green screen or...
It is likely that your battery is low or nearly-dead, particularly if you haven't used your GPS for a while and it has not been plugged in (to be kept charged). That's why it doesn't start (even if it is plugged in when you're trying to start it up again now). Don't try to repeat the startup (too often) as it will mess up your sw / data (when your battery is low or half dead) You'll want to plug it in (e.g. using your USB or wall adapter) for up to 24 hours or so, to charge the battery. Then start it up and keep it plugged in until your battery is fully charged.
Feb 13, 2011 | Tomtom XXL 540S GPS Receiver
When you plug the reader in to recharge is a red light supposed to come on until charged? How do you know when it is fully charged?
Yes, the red light should be turned ON after connecting the Reader to te Computer. That means the Reader is taking charge. After getting it fully charged, the red light will be turned ON. If those things will not happen to your reader, perform the below mentioned stepos::
1. Connect the Reader to a different USB port of the Computer. 2. Connect the Reader directly to the USB port of the Computer; dont use any USB hub or adaptor to connect the Readr to the Comp. 3. Disconnect the Reader and then press the RESET button. 4. Try connecting the Reader to a different Computer to check whether the USB port of the Computer is working properly. 5. If the issue still persists, service may be required. Follow the below link to initiate the repair: http://eservice.sony.com/
Feb 02, 2010 | Sony E-reader Portable E-book MP3 Player
Hi I have tom-tom one XL (no sd card) model, it wont turn on,replaced the battery then ok next time nothing. But if I unplug the battery and connect again ok until I switch if off, I have to unplug battery...
Hi happyivan8 i know tomtoms answer to this problem is to plug it in to the computer for a few hours but thats not really a fix, just an added pain in the rear.
i have 2 of these and one worked good after i updated it but the other still has the same problem and will only start after i charge it via the usb cable or unplug and plug the battery back in.
try updating it through tomtom home but it may or mayneo solve the problem. if you have already tried the update and that didnt help, i dont know what else you can do other then use it for target practice like im going to.
you can get tomtom home HERE if you dont have it already!
bill
Sep 27, 2009 | GPS
My new nuvi 255w will not start displaying info
When using a usb from your computer it is only a trickle
charge to the garmin. Will take a day or two to fully charge. If you use a the cigarette lighter plug that came WITH the garmin, it will fully charge in 4 hours. Stick with garmin approved plugs and all will go smooth. I know, I made the same error.
May 15, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
It won't turn on
I just had the exact problem as you did. On the TomTom website mentions that you can press the Turn-on button for 15 seconds to reset it. I tried that and it worked. Maybe it'll work for you too.
Apr 21, 2009 | Haicom HI-406BT-C GPS Receiver
My 300 Tom-Tom quit on me. No screen or anything. Help!!
Plug it into your computer using a USB cable and press the reset button. Once it resets, keep it plugged in and your computer turned on, until the battery is fully charged. Every so often, charge it. If the battery goes totally dead, it will create problems.
Mar 19, 2009 | Tomtom GO 300 GPS Receiver
How do you charge a Mini notebook PC HP 2133?
Hi Shuvz_miah-
Plug in the AC adapter connector into the right side of the computer with the other end connected to a cable that will be plugged into the wall outlet. Leave the computer connected until the battery is fully charged and the battery light turns off.
Hope that helps,
Take care
Michael
Nov 08, 2008 | HP Computers & Internet
Toshiba satellite A210 11-P crashes when i disconnect the power lead
From Toshiba, try step-charging the battery or Battery conditioning procedures:
Batteries don't last forever. All types of batteries gradually lose their ability to hold an electrical charge as they age. Eventually, the computer's battery charge indicator may show that the battery contains less than a full charge, even though the battery has just been fully charged. The computer will then not run for as long a time from the battery as when the battery was brand new.
You may prefer to simply replace the battery if this happens, but you may also wish to try 'step-charging' the existing battery per the following instructions.
This procedure should work for the battery in any Toshiba notebook. Follow it only when you find that the computer will run from the battery for just a short while.
Check the User's Guide for more specific information about charging the battery in your computer .
Procedure
Step-charging the computer's battery
  1. Unplug the AC adapter from the computer, and turn ithe computer on. Let the computer run from battery power until the computer turns off, indicating that the battery is fully discharged. Time this interval, but not with a software clock running on the same computer.
  2. Remove the battery pack from the computer.
  3. Unplug the AC adapter from the computer.
  4. Wait at least 30 seconds. The first time through this procedure, use a soft cloth to wipe the battery pack's contacts and the AC adapter's plug.
  5. Re-insert the battery pack.
  6. Plug into the AC adapter into the computer again and check the fit of its plug in the wall outlet, making sure the connection is secure.
  7. With the computer turned off, let the battery charge until the battery status light or icon glows green, or otherwise indicates a full charge.
  8. Unplug the AC adapter from the computer.
  9. Remove the battery.
  10. Wait at least 30 seconds, then re-insert the battery.
  11. Plug the AC adapter back into the computer.
  12. Let the battery charge again until the battery status light turns green or otherwise indicates a full charge, again.
Repeat this procedure, starting from step 1, at least three times. Each time, check to see if the computer runs longer from its battery than the previous time.
Battery Conditioning:
IMPORTANT!!
Interruptions in the charging cycle can be responsible for an issue called "memory effect" which may reduce the battery's charging capacity. Whenever you suspect the battery performance is not at it's optimum you should try using the following "Battery Conditioning" procedure.
Before you start: Turn off your battery saving features temporarily.
***IMPORTANT*** Repeat the following steps 2-3 times!
  1. Unplug the power cord from the computer
  2. Turn the computer on and let it run until it shuts itself off.
    Note: Using the CD-ROM to play an Audio CD will speed the discharge.
  3. Plug in the power cord (While the system is off) charge the battery until the battery light changes from flashing green to solid green
  4. Remove the battery for 30 seconds and then replace it.
    Note: If the battery light isn't lit, wait a few moments, if it still does not light check your power connections.
  5. Continue charging the battery until the battery light turns solid green once again.
    **REPEAT THIS PROCEDURE 3 TIMES**
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 04, 2008 | Computers & Internet
Tomtom ONE GPS Receiver Logo
48 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
