Question about Samsonite Tripod
How to set a code on a samsonite 3 number TSA lock?
Just got a new suitcase, but how to set the code?
  • Rob Rainbird Apr 15, 2009
    I have the same problem, its not very well described how to do it all thats there is in the book is pictures but no description on how to set it i have tried loads of times but still wont change the code
3 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: Hi, there. I have purchased
Locate a very small hidden button. Press it with a small stick. Turn digits to new code, and open again.Just locate that button first, close to the zipper.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 06, 2011
SOURCE: Problems to open a Samsonite TSA 007 lock on suitcase
I was having the same problem now... I OPENED THE LOCK !! by inserting a scissor blade into the keyhole and gently turning it !! It worked and the lock opened !! :)
but now my lock is NOT getting LOCKED !! :(
what to do ?/ Please help !
Posted on Sep 28, 2011
SOURCE: I HAVE THE TSA COMBINATION LOCK ON A SAMSONITE GRAVITON G LUX
I can't answer the problem - but am interested as we had an identical failure on holiday in South Africa. We had to force the case open as the lock and the mechanism seemed to have come adrift in that when moving the lever with the correct combination - the case neither opened or closed. I'm sending it back to Samsonite under warranty to hopefully get it repaired/replaced. I rang the UK number listed on the Samsonite website. Bit disappointed as Samsonite should be more reliable - particularly given the price of the case, at £295, isn't exactly cheap.
Posted on Oct 11, 2009
How to change code on master tsa007 lock
That number has nothing to do with the lock. That is the key number for TSA to open it. You will have to contact the maker of that lock or since they are not expensive, purchase another one.
Apr 25, 2014 | Samsonite Tripod
Open samsonite tsa007 lock
That number is the key number that TSA uses to open that lock. There is nothing available except to contact the maker. If you would rather replace it, they are not expensive.
Jan 14, 2014 | Samsonite Photography
Roncato suitcase forgotten my combination and cant open the suitcase
I have a Roncato hard shell with a 3 digit combination lock under the handle. I set the combination YEARS ago, had a young child play "horsey" on it, and turned all the numbers! The suitcase was locked and I had forgotten the combination. I followed the instructions in answer 2 above and it worked! I didn't have to add or subtract 5. I used a small sewing needle and a strong flashlight - the indentations were easy to see.
Feb 11, 2013 | Samsonite Photography
How to change lock code in TSA007 lock?
Nov 30, 2012 | Samsonite Tripod
Hi I have a problem to aopen my luggage I think my niece has change my security code accidentally , but now I cannot open my luggage can you please chelp me out?
Nov 08, 2009 | Samsonite Tripod
TSA locked our TSA002 lock on our samsonite bag when they inspected it. We do not have a key. TSA said we needed to go back to the airport, but is there a way to get a key?
No. That's part of the whole purpose of TSA passkeys; they're held securely and only at ports. If it were easy for anyone else to get hold of them the locks which are TSA approved would become pointless.
You only have three options if you do not want to return to the airport:-
1. Get a locksmith;
2. Cut the lock off/drill it out;
3. If your lock is usually key operated (not a combination) then there will be a number next to the lock barrel (not the TSA number, that just tells the TSA which of their passkeys to use). A Samsonite dealer can order the correct key for you using the number and some even keep them in stock.
Oct 23, 2009 | Samsonite Tripod
I do not know the combination of my samsonite hard case suitcase
I tried working through the series of possible numbers and at the same time gently pressing the lower part of the lock to see if it would open. After a while I used a claw hammer which I gently inserted the claw beneath the lower portion of the lock and again gently prised it and at first go the lock opened and no damage done that I can see. I have not reset the lock yet.
Oct 16, 2009 | Samsonite Tripod
Apr 11, 2009 | Samsonite Tripod
Photography Logo
10,073 people viewed this question
Top Samsonite Photography Experts
Richard Schabler
Are you a Samsonite Photography Expert? Answer questions, earn points and help others
