Question about Samsung HL-R4264W 42" DLP HDTV
GREEN AND BLUE PLAD STYLE PIC. REPLACED 5 LAMPS SO FAR, HELP
REPLACED 5 BULBS SO FAR, EVERYTIME WE LOSE POWER(YES ITS SURGE PROT.) OR UNPLUG THE SET, THESE LINES APPEAR. WE REPLACE THE LAMP IT'S GOOD UNTIL WE MOVE OR UNPLUG THE TV? IS IT THE ballast? THE TV IS A 2006 SAMSUNG 50 DLP
  • 41 Answers
The plad style picture is the digital board.
Posted on Apr 22, 2009
My minkaAire/Delano11 will not turn on. The green light is now blue. What does this mean
OKAY I HAVE A POSSIBLE SOLUTION! THERE SHOULD BE A GREEN LIGHT AT THE TOP OF THE REMOTE AND A BLUE LIGHT AT THE BOTTOM. YOU NEED TO TURN OFF THE BOTTOM SWITCH, WHERE THE BLUE LIGHT IS, FOR 5 SECONDS THEN BACK ON. THEN HOLD THE CENTER STOP BUTTON FOR 5 SECONDS AS WELL. THIS WILL ALLOW FAN AND REMOTE TO RESYNCHRONIZE, IF BLUE AND GREEN LIGHTS BLINK TWICE THEN U HAVE SUCCESSFULLY RESET BOTH FAN AND REMOTE. IF THIS DOESN'T WORK CALL MINKA AIRE TECH SUPPORT 1-800-221-7977. GOOD LUCK!
Nov 19, 2013 | Minka Aire Ceiling Fan
T.V. SHUTS OFF - SCREEN GREEN WHEN TURNED BACK ON!!!!
is it a tv or rear-projector? does it brings out the sound?
on a tv it could be the chromatisation IC that is defectiven when it goes blank. why? because of a power surge in the electrical net the tv got too much voltage to take.
try to desoldeer the EPROM IC and power on the set. does this make the set goes normal blue screen? if YES,you can order a new EPROM IC.
succes and enjoy
Jul 17, 2010 | Sharp 13VT-R100 13 in. TV/VCR Combo
How can you tell if one of the bulbs is burnt?
That color won't work good. On RPTVs, Red bad = blue-green pic; Green bad = purple pic; blue bad = yellow pic.
May 02, 2010 | RCA HD52W58 52" TV
Light bulbs have been replaced but don't light
Hello Binfull,
Since you replaced both bulbs with new ones and they still won't illuminate, there is a high probability that the open door switch is not working or if you have a newer style refridgerator then in some models if the electronic brain for that model sensed the door has been open for too long, it will shut off the lamps.. Try this.. unplug the firge for a minute or two then plug it back in. Check to see if that 'power up clear' cycle got the lights to illuminate. Also, if your model has a freezer that has lights in it check to see if they go on. Hope that helps you.. Good luck...
Nov 29, 2009 | Maytag Refrigerators
Sony - KP61XBR48. I need to know a model of the replacement Lamp
First of all, there are no lamps inside this set, there are CRTs. These are not just replaced as lamps would be. The CRTs themselves will run at leas $80 each. To change these will require replacing the coolant for the CRT as well which is not a DYI type of job. The coolant is dangerous and needs to be handled carefully. Also, once a CRT is replaced, a complete mechanical and electronic convergence adjustment must be made. There is a specific order in which to do this that is outlined in the service manual and it requires a template that would need to be purchased as well.
Unless there is a specific problem that needs to be addressed, it is unlikely that any of the CRTs needs to be replaced.
If you are having a problem with the set, can you please update this with a description of the problem? We should be able to assist in the resulution of the problem with something less drastic than CRT replacement.
Thanks,
Dan
Nov 20, 2009 | Sony KP-61XBR48 61" Rear Projection...
Dimmer turns on/off 3 spotlights but they wont dim
Questions to answer so I can answer/resolve your problem:
1) Is this a rotary style dimmer?
2) Is it a toggle or slider type?
3) Is this on a 3-way circuit (that has 2 or more switches that can turn the lights on or off)
4) Is this on a single switch circuit?
5) Is this a brand new dimmer switch?
6) Is this an old dimmer switch?
7) Are the light bulbs in the spots regular incandesant or halogen bulbs?
8) Are the light bulbs in the spots CFL (compact flouresent lamps)?
With this information, I can tell you what the problem is:
If you answer "YES" to #1, and or #6 then the dimmer is faulty and should be replaced.
If you answer "YES" to #8, then you have the wrong dimmer for the bulb type, as CFL's require a specific dimmer type in order to dim them.
Please provide some more info and maybe we can help you figure out what's wrong.
Hope you find this Very Helpful and best regards!
Aug 22, 2009 | Leviton Electrical Supplies
Power supply shot when 3 weeks on same surge prot. all other eq. ok
YES !! IT CAN DAMAGED THE POWER SUPPLY , WHAT i SUGGEST IS TO USE AN APC BATTERY BACK UP & SURGE PROTECTION , SAME USE FOR COMPUTERS , FOR MORE INFORMATION GO TO:
http://www.apc.com , hope this helps , AJ
May 18, 2009 | Maxent MX-27X1 27 in. HD-Ready LCD...
Phillips 60 in rear projection-- The convergence is off everytime I lose power?
OK, friends. Time to fix it !!. Replace two Ic's Stk 392-110, and get in service menu settings , and adjust point by point. After replaced stk IC's, check if any resistor look brown or born, if yes, replaced it with 6.8 Ohms.SOme time SSB is defective ( small signal board, replaced it ) If you have questions? noetvs@embarqmail.com . Good Luck !!
Jul 14, 2008 | Philips 60PP9202 60" Rear Projection...
Sony kv32fs16 problem
The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Nov 02, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Samsung HL-R4264W 42" DLP HDTV Logo
148 people viewed this question
Henry  Thomas
Henry Thomas
