Question about Yard Machines 158cc Push Lawn Mower #11a 034f200
Lawn mower dies when I take the choke off
I picked up an older model craftsamn mower that would not crank. i disassembled the carb and cleaned it. Now it will crank right up and continue to run on choke. When you take the choke off it dies. Help please.
John
  • 166 Answers
SOURCE: Briggs & Stratton Quattro lawn mower
A lot of time when the small motors on these push mowers surge it is a governing spring that is weak or broke. It does not hold enough tension and causes the valve to fluctuate. I have fixed this many time for a relatively cheap amount (under $5).
Posted on Jun 16, 2009
  • 33 Answers
SOURCE: I can't start my
The carburetor jets are plugged. Complete disassembly & soaking in carburetor cleaner then re install parts after rinsing off & drying them. Make sure all ports are open. Torch tip cleaner is helpful.
Posted on Sep 10, 2009
  • 133 Answers
SOURCE: Runs with choke out.. dies if pushed in. Will only
Try rebuilding the carb. It might be your float is messed up. You can also get some carb and choke cleaner and take the sediment bowl of and clean everything in it. Give extra attention to the float and needle valve. They might have some build up that won't let it work properly.
Also your gas cap might not be venting properly.
Posted on Oct 10, 2009
flyer4play
SOURCE: Yard machine 139cc will only run short time with choke
i have the same problem with my 139cc model, but no leaking gas. it just runs in choke on only.
uuuughhh!!!
Posted on Jun 10, 2010
SOURCE: I have a yard machine
Your carbs main jet is blocked. Using the primer supplements the fuel input and keeps the engine from becoming fuel starved.
You need to remove the main jet and run a strand of fine wire through the jet to clear it.
Posted on Aug 18, 2010
Mower will not start. Seems like it is not getting gas. It will crank, but not run.
you may want to check the fuel pick-up and filter inside the fuel tank... sitting for long periods of time with gas in the system can create a 'shellacing' effect, effectively sealing the filter
Sep 20, 2014 | Garden
Why does my Craftsman lawn mower starts easily, but then just dies
fuel flow problem ??? a simple fix that works sometimes is to over add some simple carb cleaner for automobiles to the gas tank , run the engine in choke if you must to keep it going after several minutes it will smooth out and run normally after u set it to "run" , this id try before disassembling the carb to totally clean it out
I use a 50/50 mix to achieve this
Jun 08, 2014 | Craftsman Garden
Zama RB 142
Maybe the hose or the Bulb has a pin hole in it. It will suck air.
Apr 25, 2013 | Garden
Mower starts for a few seconds and stops
Its the carb 90% of the time. The choke may be sticking causing it to die after starting. Check linkage. In most cases, I've found that removing the carb and disassembleing it, blowing out all the ports and jets with carb cleaner or compressed air, and re-assembleing fixes most issues like this. Good luck and keep me posted!
Oct 09, 2011 | Garden
ONly will run with choke on as soon as i turn choke
at the bottom of your carb there is a bowl with a screw in it, try turning all the way to right till tight then back off about one and a half turns, also make sure your air breather is not clogged and it is choking for air or getting too much as its running try adjusting the air breather nuts and see if this makes a diffference it might not be the choke it might be staving for air or getting too much if not tightened down.
Apr 11, 2010 | Parks Optical 13.5hp Briggs And Stratton...
Lawn mower will not stay cranked unless you keep pouring gas into
common problems to all older lawnmower, lots of dirt and dust the mower goes through and ages. I would first start by taking the carb apart and clean the filter with soap and water, allow it to air dry. also carburetor prob need rebuilding or replacing. Pick up some Carburetor cleaner at any auto part store and spay it down the carb, dont be afraid to spray allot in there and let it dry for 1/2 and hours. carb tend wear and parts need replacing just like any engines. 99% of the time lawn mower carb goes out before the engine will and common problems with all lawn mower. If you not mechanical incline or dont want to rebuilt it, just buy the whole new carb and replace it, fairly cheap easy to replace and will last you another 10 + years or more. www.briggsandstratton.com
Sep 01, 2009 | Omega Rear Drive Wheel Snapper Mowers
Runs for 5 seconds with choke pulled;no crank without choke
check your fuel pump to see if working,, then clean or replace carb,, and do tune up on it,,, hope this help you,, good luck
Aug 12, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Murray 20 hp
probally trash in the carb or fuel filter partially clogged. try replacing the fuel filter if no go the carb will need disassembled and cleaned.
Jul 14, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Starts on choke but dies when moved off choke
If it will start on choke and die when choke is taken off...the carb needs to be taken off and cleaned. The main jet in the carb is probably clogged.
Apr 09, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Yard Machines 158cc Push Lawn Mower #11a 034f200 Logo
550 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
