Question about LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer - White
We have Whirlpool Duet front load machine. Lately
We havea Whirlpool Duet front load machine. Lately it fills with water when not in use. The water is clean and comes right up to the lip inside the door. Anyone have a good solution?
  • 5,911 Answers
Water filling in the tub when not in use can be caused by two things. A leaky inlet valve or back flow from the drain caused by siphoning, or poor drainage. I have a link under my "Tips and Tricks" that explains siphoning, if you wish to refer to it. If the water was coming from the drain, though, it would probably be dirty water. A simple test you can try is to turn both water taps off before going to bed. If the tub is empty in the morning, then you know you have a leaky water inlet valve. If the tub fills with the water shut off, the problem is drainage.
If you determine that the water inlet valve (also called a mixing valve or fill valve) here's some info. The valve has electronically controlled solenoids with a small diaphragm that closes the valve when not in use. If the diaphragm is damaged, corroded, has sediment stuck in it, or if your water pressure is too low, these valves will leak by. If you've never had a problem with water pressure before, I would assume the water inlet valve is the problem. You can attempt to remove it and clean it if you like, or....if you're going to go through the steps to remove it, just replace it.
If you decide to clean it, follow these steps:
1. Unplug the washer and turn the water source off.
2. Disconnect the inlet hoses.
3. Remove the washer top panel by removing the three screws that hold it in place in the rear of the unit. With the screws removed, the panel will slide back, then off.
4. Locate the inlet valve on left-hand side rear of the washer (as viewed from the front.
5. Remove the the dispenser hose and electrical connections.
6. Remove the mounting screw(s) and the valve is out.
Soak the valve in 50/50 mix of distilled white vinegar and hot water, leaving the electrical connections out of the solution. Keep them dry. Allow to soak for 30-40 minutes and flush with water.
If the valve works, great. You just saved yourself the cost of replacing it. If it doesn't, you can order a replacement valve on line at searspartsdirect.com, appliancepartspros.com, or repairclinic.com. If you do not wish to order on line, look up the part number on the Sears website and go to your nearest appliance parts retailer. This is a common part that most retailer will carry in their store inventory.
If you have questions, please let me know. I hope this helps you.
Posted on Feb 27, 2009
My whirlpool front load keeps cycling without the water filling.
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Canyou adjust the water level on a whirlpool duet front loading washing machine model ghw9150pw3?
no and if you fill by hand and attempt to start an wash cyc it should pump out the water first
Aug 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front load washer fills up with water
Jamesbestor,
The water fill selenoid had junk in it holding the valve open or the seat in the valve is damaged.
Turn off the power and water, remove two screws on the back of the machine and remove the lid.
On the back left top corner are the water fill selenoids. Remove these and disassemble by undoing the 6 or 8 screws ( depending upon model ) holding the unit together. Clean and reassemble, it should take care of the problem. If not, replace the selenoid.
Feb 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loader
Washer should fill, remove hoses, check screens in hoses and or valves on machine for clogs. Verify water valves at the source are turned on. If all this checks, you need new valve installed on your washer.
May 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer fills with water by itself
sounds like a faulty water inlet valve, not seating properly after closing the valve.replacing the valve is the only solution to this problem, in the meantime you can turn off your water supply in between doing loads.
not a bad habit to get into!!!!
Mar 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer - White Logo
125 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
