Hi Jayson_weir
If you have forgotten the code or put the wrong code in your ipod, you can unlock the Ipod by doing the following:
Connect your IPod to the primary computer you use it with (the first one Ipod synced with), and open iTunes.
When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock Ipod using either (the code or connecting it to the computer you use to manage its songs). . . you can restore your ipod to factory settings using ipod Updater.
Please note that this will erase all data on your ipod.
Afterwards, you can add your music and data back to your ipod.
If you want to change the primary computer that your Ipod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
All of your songs and files will be deleted.
Always make a backup of your important data.
2. Connect your ipod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
If you can't unlock your ipod and you don't have access to the primary computer, your only option is to restore the Ipod, which will erase all music and data.
Please take time to rate me
Bud
SOURCE: my 8gb ipod is locked and i cant unlock it
cant unlock my ipod touch code i forggot my passcode
SOURCE: my 8GB ipod touch is disabled
You need to put in DFU MODE, and restore your ipod touch.
Easy:
Press The Home Button + power button for 10 seconds. after 10 seconds, press only the Homme button.
And now, connect your ipod touch on itunes and press RESTORE.
SOURCE: my ipod touch won't let me type in the password,
Use the Five Rs to restore the iPod. You will lose the data that is currently on it if you restore but you can always re-sync the data to the iPod.
http://www.apple.com/support/ipod/five_rs/
-=/ Daft Tech /=-
SOURCE: i forgot my password to my 8gb ipod touch
Hello.
Welcome to Fixya Community.
You need to restore it with iTunes, but you can't restore an iPod While its Locked With a password, well in order to Force it to Restore you shud put it on Recovery Mode.
Hold down the power and home keys down for about 10 seconds each while
plugged into iTunes. When the screen goes black, release the power
button but keep holding the home key until itunes says. We have
detected an itouch in recovery mode.
From there you can restore as normal via iTunes.
and that will reset you configuration including Your Password.
Thank you For Using Fixya.
Good Luck.
SOURCE: how do i unock my ipod touch dat my sister
According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following:
Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes.
If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod.
Afterwards, you can add your music and data back to your iPod.
If you want to change the primary computer that your IPod is associated with, do this:
All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data."
Please rate me...
