Question about Kyocera Copystar CS-1820 Black and White Copier
Kyocera 1815 the toner is not adering to the paper properly and comes out flaky with ghosting of images as well. any thoughts about what part needs replacing?
  • Kyocera Expert
  • 1,326 Answers
Are you getting a error code? Most likely you have a problem with the lower fixing roller. That is if you are not getting a error code. With out a code you are looking to see if the LFR has poped out of place or that one of the tension releasers is broken in the up postion or one of the bushing is broken. You may have to replace the whole fixing unit.... Good Luck
Posted on Feb 27, 2009
How to insert bond paper in the machine
Dear Jonna
You can use any bond paper from casset tray up to 105 GSM and that of from MP tray you can choose up to 160GSM. Also setting to be made from the device driver for the type of paper as it require more heat energy to fix the image to the paper.
Thanks.
Jan 12, 2015 | Kyocera Ite-Tk-18-1 Tk-18H Toner Kit 7200...
Ghost image on a hp CM1415
Two reasons for ghost image
1. Toner cartridge faulty.
There is a part in toner cartridge called Drum cleaner (also called as tractor blade), if this part not clean the drum surface properly ghost image will form on drum & it will transfers on paper..
2. Fuser assm faulty.
There is a part in fuser assembly called Teflon sleeve. If toner particles deposited on teflon sleeve you may get ghost image..
May 08, 2014 | HEWLETT-PACKARD CM1415fnw AllInOne Laser...
Ricoh sp c830dn running transfer paper for tshirt transfer. the toner is not adhering properly. poor transfer and ghosting. have tried various paper settings such as thick and special. no help have heard...
If it works fine for paper but not this application the machine is not designed for what you are using it for. You will damage the fusing unit. When it does not properly fuse the image the heat is insufficient and thus it does not transfer the image properly. Use the thickest paper type for best results.
Oct 09, 2013 | Ricoh Aficio Office Equipment & Supplies
My kyocera copystar CS-1815 shows in the message screen "Waste toner near full." How do I empty the waste toner?
Hi there just open it up and inside there will be a small plass bottle that hold the waste toner you can clean out and put back.
Mar 04, 2010 | Copystar CS-1815 Printer
Kyocera mita km-1820 not printing clear copies
you have to check the duplex unit on the machine itself.
May 01, 2009 | Kyocera Mita KM-1815 All-In-One Laser...
Print smudges and ghosts down the page
Usually ghosting is caused by the fusing unit, which usually means that it needs replaced to be honest. You could try getting into the fuser and giving the rollers a wipe, they may have dry toner on them which could also cause the fault. but i'd say the fuser could need changed!!!
Hope that helps  (",)
Dec 11, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
Laser Printer Problem
Do a panic stop while the machine is in the middle of processing copy. Remove the imaging unit and lift the drum cover to view the surface of the drum. If the image produced on the drum is OK (ie.no ghost image) then focus your attention on the hot rollers just before the paper exit. Otherwise your problem is the imaging unit.
Dec 31, 2007 | Office Equipment & Supplies
Black smudges on copies
Hi, try to pull out complete process unit(cartridge) with toner box .You have cleaner(blue or green color) move this cleaner from right to left side 4 or 5 times.Note that cleaner MUST be in home position-right side when you finish.Check print.
If problem still persists, you must do following:take away small grey plastic cap on left side of cartridge,then push complete charge corona(part with cleaner on top of it) to left side just enough to lift right side of corona from cartridge.Pull out that corona and you can see drum and developer roller. Turn the gear on drum,and look for smudges on black developer roller.Try to clean smudges with brush or with dry cloth.Toner will again attract to that area,but regular.
Dec 11, 2007 | Kyocera Mita KM-1815 All-In-One Laser...
Kyocera Copystar CS-1820 Black and White Copier Logo
118 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
