Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
Tv shuts off, when I turn tv on it will shut itself off, this hap
This happens 4 or 5 times before the tv will stay on for while., I have been told this was a power supply problem, help!
  • Anonymous Feb 27, 2009
    when i turn the tv on, it automatically shuts off. it happened just the other day. i checked the stand by light and it flashes 6 time in repeated pattern. what can i do to fix this?
  • 4,234 Answers
When it shuts don, the standby light should be blinking a repeated pattern. PLease update this with the count of blinks. That will indicate the circuit that caused the shutdown.
Thanks,
Dan
Posted on Feb 26, 2009
Tv continuely shuts off
When it shuts down notice what light is lit , what color and is it solid or blinking. Respond to this same post for assistance and I will assist you with the issue.
Jan 01, 2013 | Mitsubishi WD-60737 60 in. HDTV
Sylvania LD320SSX turns off by itself.
your powersupply is dying in the set.. have it checked..
Apr 10, 2010 | Sylvania LD320SSX LCD TV
My Magnavox digital converter box shuts itself off every 5 minute
Check that you have not got an auto power off setting on. Check that the aerial connections are good. That the signal is strong from the stations it is picking up. Weak signals can cause the box to shut down.
It the box is very hot when it shuts down, you might have a fault on it.
Apr 04, 2017 | Philips Magnavox M61117 (DBM61117)
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Pioneer SD-P62A3 62" shuts off - won't stay on
If this TV turns back only when it is cooled down than it has cold solder joints tha have to be resolderd.
Jul 07, 2009 | Mitsubishi VS-6055 60" Rear Projection...
Sony kdf60655 green light blinking 37 times and pic goes off/on
I am having the same problem and we purchased the tv new in April of 2005 had the four yr warranty also. That's obviously passed and now we don't know what to do? What did you find out?
May 04, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Feb 20, 2008 | Toshiba 28N33 28" TV
Assistant
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
TV LED Flashes then TV shuts itself off
capacitor problems in power supply or a regulater isolate the power suppley by disconecting the line output stage/unplug scan coils for example and run a 60w bulb as a dummy load one wire to earth and the other to rail voltage colecter of line output transister if the bulb glows steady the power supplys fine
Jun 25, 2007 | Philips 27PT81S 27" TV
Pioneer sd532hd5/kuxc/ca powers down on its own
Could be a few things.First check your sleep timer.Sounds like a fail safe mode that when the tvs left on accidentally it shuts itself down so it wont overheat and die prematurely.The last resort is to remove the circuit board and carefully inspect the solder joints near the power supply with a magnifying glass and a bright light.Then resolder those.
Nov 09, 2006 | Pioneer PRO-100 TV
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
161 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
