Question about Ricoh Aficio 1013F Copier
Ricoh 1013F no dial tone
I moved it and now I get no dial tone, the line is good. this happened once before a couple of years ago and there was a reset in the service program but I cant remember what.
  • Ricoh Expert
  • 1,326 Answers
On the back of the copier, look to see if you have two phone jack inputs. Did you try both of them. One is for a handset & the other is for the phone line....
Posted on Feb 27, 2009
HP Officejet 6500 no longer hears the dialtone. The line works fine with a regular phone, but not the printer. Up until a couple of days ago, it worked fine. The printer says the line is in use (wh
Usually on hook telephone line voltage around 40V DC +/- depends on exchange, voltage will drops below 12VDC if its half hook..You will get engage tone/usage tone if voltage drops less than 12V, in this condition you wont get any incoming calls.
You need to open the printer formatter to locate the modem where telephone line inserted..
Let understand why this malfunction happens..
The ring voltage between the line is +120V AC, but it should not exceed more than 200V.. To protect the circuit, line will guarded by component called "VARISTOR". The Varistor will burns if voltage reaches specified or more voltage across it.. Once varistor burns U will get engage tone always... Basic multimeter is enough to check the varistor, put multimeter in diode mode, test both ends of varistor, it should not show zero value or beeping. Some times it may burn, blast or bulge. Remove the faulty component from the circuit with the help of soldering iron, connect the line & verify, if line is good replace with same rating of component.. Chk for the ring & dial tone...
Req tools: Multimeeter, soldering iron, little paste & Led, screw driver set for opening the printer..
Depends on design varistor may fix accordingly which we need to find out the location.. But its always fixed between line in path. pl see the attached sample diagram.
if you are non technical pl don,t try it...Best of luck.. 6f4a7950-5cc9-42c6-bb47-b2ba2007add0.jpg 21aa8d50-de72-49d9-a692-6c813c2c0768.jpgEx: Varistor ac224650-2c77-4de1-934f-929cbd6f0d15.jpg Damaged/burnt varistor
Apr 01, 2014 | HP Officejet 6500A Plus Wireless...
Richo 1013f copier problems-grey lines on copies
Most often this problem is coming fro the PCU or Photoconductor Unit. If you open the right side door just look for the long greenish colored cylinder. It should be clean. If you see a toner film or more specifically the same "lines" on the surface of the drum that you see on the copies then you will know. If this is the case you will need a new PCU. Installation is a piece of cake.
Here is a link with pictures, part numbers etc.
http://www.precisionroller.com/search.php?q=ricoh+1013+drum
Good Luck and Thank You for using Fixya.
Sep 03, 2010 | Ricoh Aficio 1013F Copier
My Ricoh Aficio 1013f has 16,000 copies on it. It
Ask the service agent, what the maintance cycle of the model is. Sound like it needs a periodic service.
This being the drum and some rollers. this will resolve the squeak as well
Good Luck
Mar 03, 2010 | Ricoh Aficio 1013F Copier
Error message -using handset (no handset on the machine. mfd - 1515
If this appear for the first time see the follow, if this started to appear after a time of usage you will need to call a Ricoh technician, sorry but i cannot gain some help in this type of problems.
see do you use a cord with two wires or four for Ricoh when using some telephone centrals like a Panasonic it's better to use a two wired cord for the line, if this still do not help, you will need to call the telephone central technician to set the line for the Ricoh fax.
Nov 17, 2009 | Ricoh Aficio 1515F Plain Paper Laser Fax
No dial tone in home. I have checked the cords
unplug all phones and cords check each phoneindividually until u find the phone causing the problem, i had this problem a couple years ago and came to be one of the cord plugs..good luck..floyd
Jul 24, 2009 | Panasonic KX-TG2357 Cordless Phone
Ricoh 1013F Fax Line answering phone calls
Not quite sure the Ricoh has what is commonly none as a fax switch. This actually catches the call and looks for the fax tone from the sending fax to determine if it is a fax or not. The Ricoh can not determeine what number is dialing in. It only knows a call is incoming.
You can ourchase a fax switch online or Radio shack had them.
Mar 09, 2009 | Ricoh Aficio 1013F Copier
Phone has a dial tone but will not dial
I would first verify that the line is good. Take a known good corded phone. YES corded phone !!! and try dialing with it and make sure it dials on the line every time. Also make sure that the Pulse/Tone setting is set for your service( there is still a few area without Touch Tone belive it or not)
Once you verify that the line is ok check each phone and take the defective ones back to where you bought them.
Dec 26, 2008 | Lands Phones
Dell AIO 962 can't get a dial tone
There are 2 phone jack ports on the back of the 962.
One for line, one for phone.
You want to plug the phone line into the port that says "line" or "Fax".
If it's plugged into the wrong one, your fax machine will not get a dial tone.
Jul 31, 2008 | Dell 962 Photo All-In-One InkJet Printer
SF-515 does not dial anymore
Hi there try this press menu then using the arrow keys go into machine settings I think if not you are looking for line type. Once in the make sure it is set to tone.
Once you have done this come out and try if this doesn't work then the control panel maybe faulty and you could take it apart and clean the number pad keys and make sure that the buttons move freely.
If they do cleanup and put back together and check machine if it still doesn't work then the panel will more than likely need replacing.
Thanks J
Nov 14, 2007 | Samsung SF-515 Plain Paper Laser Fax
96 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
