Question about Toshiba 43A62 43" Rear Projection Television
Convergence in Toshiba 43a62 projection tv
I would like to know if some one out there can tell me where to check the soldering on my convergence board or what ever it is called on my toshiba model 43a62 projection tv i want to check the soldering we moved the tv and now the convergence is off and i was told to check that first before buying new parts for it but am not quite sure where to find this? any help so i can check this out first?? thanks any one ever check this it was a repair man that told me this may be the problem and he would check that first where we have moved it it could have come un soldered?
  • theritchi991 Mar 01, 2009
    Thanks for the help, this site is awesome the tv is working now,
    our son inlaw cleaned every thing and it is working not sure what really was wrong but it is working great once again and the grandkids are enjoying it. The guys kinda thought that maybe in the move some condesation may have been in there.
    once again thanks for all comments and help it was apprciated.
    Genius:
  • 2,920 Answers
Its not likely to have come un soldered or loose, a lot of times when you move a big screen they have to be reconverged. not because of damage but because of the move in general...i would call a shop and have them come out and re converge it. that what it will take to get it done right
Posted on Feb 26, 2009
Hi in the convergence to adjust the color the red is above the plus sign in 3 spots and will not come down and they are not straight
does the blue convergence crosshairs move up and down left and right? Does the red move left or right. does the red move up at all. this might indicate a faullty resistor, bad ic or just bad convergence data. let me know i am here to help
Nov 04, 2010 | Toshiba 43A62 43" Rear Projection...
Toshiba 50HX81 TV looks kind of old school 3D with red and green hue. Bad bulb? How involved is this to fix and where do I find parts?
No,not the bulb problems.Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look like.The Toshiba tv have a "HYPER BOARD"known as a convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the convergence board,must be replaced to solved the tv convergence pictures problems.U have tools like a soldering iron,desoldering pump or desoldering braids,solders?Can u do basic soldering?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop,will cost u $300-350 for parts and labors.
Oct 21, 2010 | Toshiba 50HX81 50" Rear Projection...
My toshiba 57" tv is always fuzzy looking and i do not know how to fix it. any suggestions?
This tv have a problems call CONVERGENCE,it dead.The tv convergence board have the 2 STK convergence ICS and some or all it resistors are dead.These parts on the convergence board must be replaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 16, 2010 | Toshiba 57H82 57" Rear Projection...
The video on ours keeps distorting by 'crunching in' from the sides randomly. Any thoughts??
Ur tv have a problem call convergence,it dead.The convergence board require 2 STK convergence ICS and some or all it resistors to be replaced to solved convergence problems.U know how to do soldering?Have soldering iron,tools and solders?Tries Websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 28, 2010 | Toshiba TN55X81 55" Rear Projection...
Convergence problem w/55h70. red is ok but can't fix blue. Is there a component or board that is easily replaced?
Yes,U have some basic machanicals skills?The Toshiba Tv convergence board,it call a Hyper board.Try website Ebay.com to buy a refurbish board.This board no longer produced by Toshiba,if can't find it.The Convergence 2 STK ICS,and some or all it resistors,must replaced manually.Must have tools,and knowing how to do basic soldering,to do this.
Apr 06, 2010 | Toshiba 55H70 55" Rear Projection...
I have a toshiba big screen tv we believe both convergents need to be replaced we do not have 300-365.00 to repair it . I know how to solder can I do it myself???? model#57H81
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 24, 2009 | Toshiba 57H81 57" Rear Projection...
Convergence issue, replaced convergence chips, now blinking red power light and no picture
Recheck all of your solder connections for bridging and cold solder joints. Check the large output resistors under the heat sink and the smaller ones to the left of them. Check all of the fuses on the power board. And make sure that you check all of your connectors carefully. Also check that you didn't pinch a wire somewhere.
I am not being mean by saying that if you could power up before then more than likely the power up issue was caused by something you did.
Jun 03, 2009 | Toshiba 50H81 50" Rear Projection...
Tv won't come on
Mine is Toshiba 55 TZ, have it since 98', shutdown and red light blinking problem, search the ned and found out, generally a Convergence IC (stk392-110) problem. bought 2 for $15 at suburban-elect.com (ebay). replaced following direction from http://www.casiasfamily.com/repairlog/tp50h15.html
Open back cover, 9 screws and wirings (pls mark), removed(soldered) a electronic board infront of convergence ic. removed IC (stk392-110) (screwed and soldered).
Replaced everything and voila...! it is now working again..
no more shutsdown and red blinking light. Saves mo $400 for a repariman. of course just be careful with static and stuff.
Feb 29, 2008 | Toshiba 50H81 50" Rear Projection...
Convergence fuse Toshiba rear projection tv
Wire jumpers need re-soldering....Locations 008,010,017 etc
on inside edge of signal board near convergence IC's.....research
my Toshiba " H " Model rear projection " blows fuses" solutions.
...................................T.
Jan 27, 2008 | Toshiba 55H70 55" Rear Projection...
Toshiba 43A62 43" Rear Projection Television Logo
142 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
