Question about Whirlpool GS470LEM Gas Kitchen Range
How do you change the oven's light bulb? How do yu get the cover off? no clip won"t turn counter clock wise. Whirlpool Gold accubake duo system
  • 3 more comments
  • Soaper Mar 11, 2009
    Same problem, but in my case the light works intermittently. Therefore suspect the bulb is loose in the socket and just needs to be tightened. Wiring connections are solid. Can't get the cover off to change the bulb. Cover won't unscrew or pop off. Can't find any lit from Whirlpool. Frustrating to go through all this for something that should be so simple. Thanks Whirlpool.
  • ladybird98 Apr 13, 2009
    pls advise, same question
  • riemerjj Apr 17, 2009
    Whirlpool Gas Range SF379LEK Light's out in oven... can't find any info on how to replace (or get the cover off)... I need help too!
  • Karla Marsh Dec 27, 2011
    Turn the glass cover to the left ("lefty-loosy). If you break it, you can order a new one here:http://www.appliancepartspros.com/Applia... I just now ordered the lens cover and gasket, just over $30.
  • Anonymous Mar 26, 2014
    Just change the bulb and now it won't turn off
I couldn't get my cover off either. My solution was to use a pipe strap wrench, very carefully. Rotate the cap counter clockwise to remove it.
Posted on Oct 06, 2010
My light cover broke. I thought the bulb was burnt out, so I reached in to unscrew it and saw that it was cracked. Came off quite easily. ;-) Now I need to find a replacement for that. (The bulb was just loose, not burnt out. Those things seem to last forever, unless you forget to shut it off.)
Posted on Dec 27, 2011
Change light in whirlpool gold accubake system upper microwave oven
If you need to replace the bulb for the interior cabinet, you'll need to remove the two screws that holds the upper grille in place with a Philips screwdriver.
Access to these screws are from on top of the microwave.
Once you remove the grille, you should see a white plastic cover with a release tab; pop the open and you'll have access to the bulb compartment:
Watch the following youtube video- the instruction phase of removing the grille and access to the bulb compartment starts at 2:40
http://youtu.be/RQM302PShKw
Mar 04, 2015 | Whirlpool Ovens
Oven is 75 degrees off temperature setting. what do I do?
Are you sure that no one has been taking the control nob off of the dial and turning it as a prank?
Feb 08, 2012 | Whirlpool Accubake RF362LXTS Electric...
How to change oven light
Which model Whirlpool range do you have? For most Whirlpool ranges that I have used , the oven light is covered by a screw-on glass cover. When the oven is cool, unplug the range, open the door and turn the cover counter-clockwise (to the left). Then remove the 40W bulb (again counter-clockwise rotation). Replace the bulb with another 40W appliance bulb. Then replace the cover by turning it clockwise until it is tight. Do not over-tighten either the bulb or the cover. Then plug in the power cord for the range. (Unplugging the unit makes sure that you will not get shocked if anything goes wrong. Sometimes the bulb may break in the socket - in that case, use pliers to unscrew the base of the bulb before replacing it with a new bulb.)
Whirlpool has the manuals for most of their appliances on their support site: https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView .
I hope this helps.
Jan 11, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool Gold Accubake Duo. ''E4 - F3'' or ''E0 - F3''
HI. These codes are an indication of oven temperature sensor failure. The sensor is damaged. This will not allow for proper operations. The affected part must be replaced, asap.
The sensor is, generally, located inside the oven, mounted on the back wall, on the top right, or left corner.It will look like a 4 inch long slender probe. There will be two screws holding the housing on the back of the oven wall. Once the screws are removed, the sensor will need to be extracted from the back side of the unit.
Dec 28, 2009 | Kitchen Ranges
We tried using the self clean on our Whirlpool Gold Accubake Duo system range. It locked the oven door and gave code e1 f5. We disconnected the power and turned back on to the same codes. HELP!!!!!!
take the trim peices off. take the screws that hold it to the wall out slidee unit out a little to remove the 2 screws from the consol lift the consol up and off. make sure that you have turned the power off inside the unit you will see a tech sheet that will tell you what that error code means. let me know how it goes the tech sheet is usually on the left side.
Jun 16, 2009 | Whirlpool GBD307PDS Electric Double Oven
Changing headlight on ford focus 2003
It is very hard to get to but you need to turn the bulb housing counter clock wise and it should pull out far enough to replace the bulb. Be sure not to touch the new bulb glass with your hands. grab it by it's housing. then reverse the process.
Mar 03, 2009 | 2000 Ford Focus
Oven light
I had the same problem and worked on it for HOURS! Spray a tiny bit of WD40 on the glass fixture near the back of the oven. Wait a couple minutes and it will finally "give" and turn counter-clock wise. This part was clearly OVERLY tightened by the manufacturer.
Jan 06, 2009 | Kitchen Ranges
Whirlpool gold accubake GJP84802
If you can gain access to the clock you could find the wires that goes to the bake element - if you can measure and confirm the resistance of the element chances you may have also fried the relay of the board - check it out
Regards
Sep 06, 2008 | Whirlpool RBS275PD Electric Single Oven
Whirlpool GS470LEM Gas Kitchen Range Logo
1,740 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
