PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
BLUE SCREEN
By socksy on Feb 26, 2009
EVERY NOW AND THEN I GET A BLUE SCREEN
Best Solution
posted on Feb 26, 2009
Helpful)
Spoem
Rank: Guru
Rating: 86%, 96 votes
A Blue Screen of Death, or BSOD, is Windows way of letting you know it has a problem. They will appear after new hardware is installed or some times after Windows installs an update. There will be a STOP CODE and an associated file list about 3/4 down the screen. Write that information down. Shut the computer off and let it set for a minute or so. Start it and see if it will come up normally. If it want to run check disk because it shutdown improperly last time, let it run. The computer should start in a few minutes. If there are no other errors, do a web search for the filename you wrote down. The results of the search will help you identify which device is causing the problem. Once you know that, download the latest drivers and patches for the device and then uninstall the software and shutdown the PC and remove the device. Restart the PC briefly and then shut it down again. Install the device and start the PC again. Install the new software for the device, including patches, if any, and restart the PC.
Good luck and please let k=me know how it works out for you.
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
gymowner
Rank: Wiz
Rating: 85%, 233 votes
The hard drive will usually make a clicking or humming noise as it starts to go, usually getting louder as tim e goes on, it could just be a video driver or driver for the monitor. I would check to make sure I had the latest ones, good luck, and if you think your drive is going, it might be a good time to back up your data, as you will wish you had if you didn't do it allready. I picked up a terabite 1000 gig drive for a hundred bucks at Tiger direct, it will hold like everything I have on one small drive, good luck
Was this helpful?
Yes
No
Solution #3
Not Rated)
blackberries
Rank: Wiz
Rating: 78%, 51 votes
seems to me hard drive is faling! check windows event log and back up regulary! usually the blue screen issue!
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
No message.
Answer
the best site i have ever visited,,, thanks fixya guys
Answer
I have a toshiba A205-S5083. I can't reboot even when I use the recovery disk.It loads Windows then... (More)
Answer
I have a HP Pavilion dv6225us laptop, and cannot get the battery compartment out. The release latch... (More)
Answer
Toshiba Tecra 8200 mini wifi won't connect. Device manager says OK. Updated latest driver. Toshiba... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptops Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(168) 454-4153
QABastards
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
