Question about Garden
Campbell Hausfeld 1750 Pressure Washer Won't Start
This is an electric unit that has worked fine for me in the past, although only used on average once or twice per year for the past 2 years. Today, when I got it out to use it, it started briefly, for not even two seconds and went right back off. I checked the GFI plug in, tested and pushed the reset button. It never came back on. I noticed that the light on the GFI was out. I called Campbell Hausfeld and they were no help (other than to send me instructions to clean the pump with vinegar and vegetable oil) which is quite a tedious process and I don't think it will work because I cannot turn the unit on. Do you have any possible suggestions as to why the unit won't turn on?
  • Anonymous Mar 21, 2009
    I have the exact same problem. Unit came on yesterday for about 10 minutes. I quit for a little bit, then it would not run at all.
  • 3 Answers
Throw it away seems to be the only solution since no one has a clue in what there talking about, nothing froze always cleaned out system and still wont start, campbell hausfeld does not have a clue neither, they told me you got to check this one out, drop unit about a foot off the ground and yea i tried it about 8 times then almost threw it across the yard, oh well i hate being negative and love to fix whats broke but the hours spent i could be making money and just buy another, thank you
Posted on Apr 19, 2011
What is average going price for a new or used wobble pump for a Campbell Hausfeld PW2200V1LE. My 6.0 Briggs & Straton engine is in very good condition Reason I ask is a brand new pressure washer in my...
keep the briggs if your just gonna use it for yourself get the sjv axial pump 239.00 put it on your briggs.many retail stores use s disposable pump no sightglass or drainplug sjv has forged brass head no pot metal.
Jul 30, 2013 | Campbell Hausfeld Garden
Hookup
For the Campbell Hausfeld 1800 PSI model (PW182500AV), the garden hose connects to the pump inlet on the lower back of the pressure washer. The high pressure hose connects to the high pressure outlet on the lower front of the pressure washer. Here is the operator's manual that will show both connections. http://www.mowersatjacks.com/images/campbell-hausfeld/manuals/pw1825.pdf
May 18, 2013 | Campbell Hausfeld 1800 PSI Electric...
I have a Campbell Hausfeld RBPW1810 pressure washer, It has two detergent tanks. I cann't get either to work. I just purchased the unit in June if this year and this is the frist time I am useing the unit....
Sometimes thinning the solution will help, but in any case make sure the line from detergent tank to pump is sealed, otherwise it just sucks air. I use a small hose clamp at pump. let us know
Sep 22, 2010 | Campbell Hausfeld 1800 PSI Electric...
Gun
Replace the wand (Gun) The valve is not repairable.
Jun 16, 2010 | Campbell Hausfeld PW1750 Electric Pressure...
Pulsing Campbell Hausfeld 1300 psi 1.6 gallon electric
the unloader valve is deffective , this has a small metal rod which activates a microswitch to turn the machine off , replace the unloader valve
Nov 18, 2009 | Campbell Hausfeld 1,350 Psi Electric...
C/H 1750 Washer will not start with water connected. Electric motor will start without water connected.
HI I would think that your pressure switch has stuck.
You will need to remove the covers etc and check the internal pressure switch that will be situated on the outlet of the pump. It maybe stuck and just want greasing etc or may need replaceing.
Oct 30, 2009 | Campbell Hausfeld PW1750 Electric Pressure...
Stops running after a few min. of spraying and won't start up . campbell hausfeld 1300 pressure washer
hi sounds like the rong nozzel in the lance and it's pulling to many amps so it overloading the motor and tripping out, take the lance off then try regards
Oct 25, 2009 | Campbell Hausfeld Tools 1300 Psi X 1.4 Gpm...
Garden Logo
1,099 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
