Coffee Makers & Espresso Machines Logo
A
Anonymous Posted on Mar 18, 2013
DELONGHI BCO 410 - Coffee Makers & Espresso Machines
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 24, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
90
Points
0
Why is the bco410 more value for money compare to bco130 ?
1 Related Answer
Anonymous
  • Posted on Apr 08, 2011
SOURCE: coffee maker wont start
I had the exact same problem with my DeLonghi Caffe Verona Expresso Machine (very old) and I replaced the thermal fuse and Bingo....it works fine! I did call DeLonghi and the tech told me the Thermal Fuse is the most common problem of no power. (providing your unit is plugged in and the receptacle works) In my unit the fuse is on top (only one) and it did have a plastic sleeve over it. The fuse was bought at Radio Shack for 1.99 and I had to solder it on because I forgot to get the little crimp ends from the Radio Shack guy. oops If I can do it...anybody can. (55 year old Grandma)
How do I change the time from military time to back regular time on my Delonghi COM530m coffee maker?
It has always been Military time.
https://www.manualslib.com/manual/2073018/Delonghi-Com53-Series.html?page=7#manual
and from DeLonghi direct
The clock on my BCO combination machine is military time. How can I change it? All BCO's units are designed with a military standard and it is not possible to change it.https://www.delonghi.com/en-us/faqs/search?q=%20Delonghi%20COM530m%20military%20time..
How obtained A download a manual?
Go to this site to get a manual. It is listed under CUSTOMER SUPPORT. :-) Here is the link to the website. http://www.delonghi.com/en-us/products/coffee-and-espresso/coffee-makers/nespresso-system/lattissima-pro-en-750mb-0132192224?gclid=Cj0KEQjwrqieBRCln82Rgufz7I0BEiQAPNjAIwPVQ5e68guS8rRE8O_Lry_tcDMQOapRV2KTlEHJuIkaAqS_8P8HAQ Lattissima Pro EN 750 MB
Lifetime of BCO 130
when did you last descale the unit?
also running Milton fluid to the correct strength through with out heating may kill any bugs
My DeLonghi BCO 130 Machine is not frothing the milk, i turn the steaming button all the way but nothing happens.. please help, thanks Colleen
Our friend is right. Two holes ( very small holes ) of the screw nob were blocked ! These holes were responsible for drawing the milk upward by vacuum. I used a needle to unblock these two holes . Bingo the problem was solved and now the steam can produce creamy milk
2answers
We havn't had our Delonghi BCO-120T but for 3 months & the coffee side stopped working all together. My husband is a great handyman & after taking that side apart. the tubing & tank looks...
In uk delonghi spares by agents of kenwood.co.uk. there is a directory of local agents. before ordering element check thermal fuse attached to the element it may be open circuit.
2helpful
2answers
The coffee pot won't turn on anymore
burnt thermal fuse or heater does heater work under coffee pot? :)
My water tank is leking
Use M-Seal paste, this will stop all leking ( it should be apply in dry mode)
Top Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
