Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
How to setup my VCR to record programs from my Panasonic 42 Inch HDTV Plasma TV?
  • georgellopez Feb 27, 2009
    I should refrase my question, I have satellite dish and a Panasonic Plasma "42" HDTV, I installed my DVD and VCR however my Panasonic VCR is not able to record off my TV like it used to do when I had a regular TV. How do I record what I'm watching?
    President:
  • Panasonic Master
  • 1,779 Answers
You will take the video out and audio out from the tv, plug those into video in and audio in on the vcr, then put the channel on the vcr to line in, if your using the front, it will say front. Don't forget, DO NOT change the channel on the tv nor shut it off while recording this way or you won't have a recording.
Posted on Feb 26, 2009
  • 44 Answers
TV doesnt matter, you need to list what kind of VCR your trying to program with.
if you are programming from cable, the cable box, box or not, should be ran thru VCR then VCR to TV.
to record. easiest.
if you are doing cable to tv to vcr. make sure that tv is in one of the AV spots, so when you select input on vcr itll show your tv again. program as accordingly.
SOURCE:
4 inch horizontal gray bars left and right in hd mode, normal channel pic is fine
Please enter the TV's Setup menu and choose the "Other adjust" option. Then choose the "Side bar" option and use the right arrow to change the color of the side bars.
May 05, 2014 | Panasonic VIERA TH-42PX60U 42 in. Plasma...
How to reset a viera panasonic model#tc-p42x5
A tutorial on how to reset your TV at http://shop.panasonic.com/docs/how-to/2013/tv/reset-procedure/How_to_Reset_your_Panasonic_Viera.html
Sep 20, 2013 | Panasonic Viera Tc-p42x5 42" Inch Flat...
How do you test panasonic buffer boards TNPA4784 and TNPA4785
There is no check with these boards. Replace them with new one and make confirm the fault.
Aug 28, 2012 | Panasonic VIERA S1 Series TC-P42S1 42-Inch...
How to hook sound bar to panasonic viera 42 inch model TC-P42X5
The aftermarket audio/video cannot allow you hook your Tv and Dolbys stereos becauses of incompatibility issues.
Jul 24, 2012 | Panasonic Viera Tc-p42x5 42" Inch Flat...
How to connect a dvd recorder ( & player ) a VCR & Foxtel to a plasma THP46G10A do you have diagramatic sketch of connections
samsung 42" plasma hooked up to LG vcr/dvd combo and foxtel IQ box. all working but only by plugging vcr cable into video camera sockets on side of plasma tv?? reason only place with a yellow plug socket? on rear of tv colours are only red,green.blue? and white. nothing for the yellow can you give any advice on correct hookup proccedure please.
Dec 18, 2009 | Panasonic Televison & Video
How to hookup vcr to TV to tape from satelitte
have a look at ur install bock it will tell u how to do it...connect antenna to ur vcr then use cable from ur vcr output to ur tv antenna ,,,,,after u have done this read instruction .....to connect ur dvd ....just plug ur cables from ur dvd to the back or ur tv....marked as dvd input....
cheers and good luck......very simple.....
Mar 06, 2009 | Panasonic TH-42PX500U 42 in. Plasma...
I should refrase my question, I have satellite dish and a Panasonic Plasma "42" HDTV, I installed my DVD and VCR however my Panasonic VCR is not able to record off my TV like it used to do when I had a...
The VCR needs to be connected between your Satellite box and your TV. If you can specify the all of the components in your system and how you currently have them connected I can easily help you with the proper wiring strategy.
Feb 27, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Black line in a 42 inch panasonic plasma tv
I have a 2 black lines. One goes horizontal and one runs vertical. Is this something I can fix?
Jan 22, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
190 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
