Question about Kenmore Kitchen Ranges
Oven light remains on when door is closed.
My Kenmore free standing range oven door has always felt like it did not completely close. Now the light stays on when the door is closed. Is there an adjustment that a do-it-yourselfer can make?
  • Kenmore Master
  • 5,568 Answers
This range was probably made by Whirlpool or one of its dozen divisions so it probably has some slop in the hinge mounting to correct for their so-so manufacturing. You may have to somewhat disassemble it to get to the hinge screws though.
Posted on Feb 26, 2009
Kenmore 790 Oven Locking mechanism problem
hold down the stop/clear button for 3+ seconds
Jan 13, 2009 | Kitchen Ranges
Kenmore Oven Door Lock Stuck Out
We had this same problem. We found that pushing the censor button/switch on the upper left rim of the oven's inside moved the lock and made it capable to unlock, or purchase a pizza pizzaz.
Oct 05, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I had the same problem. Open the oven door. Press and hold the light switch. You will hear the door lock move back into the correct position. Hope this fixes your problem. This has happened to me twice and holding the light switch always works.
Jul 14, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
F0 display error
ok fo is a communications error and can be in three places the manuel says replace the eoc but ive found that's not always accurate if this is a free standing or slide in range you can pull it out and remove the back top and bottom when the oven goes in self clean the door switch has two functions when the door is open it tell the clock that the door is open and the door latch motor and it turns on the oven light when the door is closed it turns off the oven off and tells the clock and latch motor the door is closed it does this by two micro switches on the latch motor one for closed one for open by means of a plastic cam on the latch motor now if you have self cleaned the range lately then the door locked micro switch may have stuck when the cam rotated back to the unlocked position and with both switches closed the eoc wont let the oven work because it thinks that its in self clean also ive seen mice build nests on the platform that the motor is mounted on and pile insulation on the closed switch and close it that way so you got the door switch the latch motor switches or the mylar ribbon that goes into the eoc its self could be dirty now on the clock or eoc there is a little lock tab at the bottom of the ribbon that you pull up and release the ribbon and gently clean the ribbon and replace it now when testing the switches with a ohm meter you must remove one wires from the switches to prevent getting a false Reading if all this fails then replace the clock now you can call a repairman but most like they will replace the clock without checking the other stuff now is this a free standing range also some where on the range will be a tech sheet with wiring diagram ans stuff it will help you is this a freestanding range or a slide in as componets are located in different places if you need more help reply to me
May 21, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven light
Heat causes metal to expand. Expanding metal can make contact with other objects, like a ground that completes a circuit. Take the lamp assembly apart and check for exposed conductors. Also, check the door switch. If it is heating up and something within the switch is expanding then the switch may be closing due to heat. With the door open puch the switch all the way in and see if the light goes off. If it does then replace the switch.
Deepwater
Apr 14, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven door just barely closes- light stays on
put a tea towel on both sides of the door [folded] down by the hinges then close door. gently push the door close try a few times with a little pressure.
Nov 12, 2007 | Kenmore 96422 / 96424 / 96429 Electric...
Kitchen Ranges Logo
198 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
