Question about Dell 962 Photo All-In-One InkJet Printer
I have a Dell A920 printer. Carriage stall error
There is a loud clunking noise. It is the carriage stall hitting the end of the printer.
the ribbon cable where it feeds into the inner part of the printer has popped out on both ends. Can not get in to re-connect them nor can I see how they get connected.......please help
Thanks,
Robin
  • 49 Answers
Try this trick. Turn off the printer, reach in and manually move the carriage to the other side of the printer. Then, unplug it, plug er in and try again. If that doesn't work then it's most likely a dead unit.
Posted on Feb 27, 2009
When printing a job halfway through the printer makes a loud clunk then stops and throws 2F26 error
Chad, for future reference, if it costs more than 50% to repair an item than it does to buy a new one, deep six it.
I don't know how long you've had this printer for; or how much you paid for it, but at this point, you certainly made quite an investment in an attempt to repair it, with little headway.
Sounds like you went about this using the guess and check method...anyway, you went this far and invested a small fortune, and you pretty much replaced all the parts other than the belt and ribbon cable, it sounds like you want outside support to convince you to replace them...so go ahead, permission granted! :)
Mar 18, 2015 | Canon imagePROGRAF® iPF8100 InkJet Printer
How to fix carriage jammed to the right
For as I know, most HP carriages are driven by a belt. The detection when the end is near, is measured using a light sensor and a transparent ribbon with small vertical lines on it. When this ribbon get smudgy these errors might occur. Try to clean this ribbon with a dry cloth. When you disconnect the power when the carriage is somewhere in the middle of the printer, you can gently move the carriage to clean the complete ribbon.
Oct 19, 2014 | HP OfficeJet Pro K8600 Printer
Hp officejet j4580/ repairs
do u have checked carriage sensor strip may be strip is broken that s not senses carriage unit and moving UN control and hit at the left right end
Jul 15, 2014 | HP OfficeJet J4580 All-In-One InkJet...
My Dell A920 black Ink holder broken
call DELL technical support number and ask if there is available spare parts for broken cover replacement, you might end up replacing the whole ink carriage.
Jan 13, 2013 | Dell A920 All-In-One USB Color Inkjet...
Weird noise from printer carriage
The loud clicking noise is probably the carriage trying to move and something is keeping it from doing so. Check to see there are no foriegn objects obstructing the carriage head from moving across the paper. If nothing is found, then likely a hardware error exists.
hope this helps!
Aug 31, 2009 | HP Photosmart 3180 All-In-One Printer
HP 1610 Carriage Jam
Remove the ink jet, make sure you removed any pckg. material and the contacts cover on it.
Nov 10, 2017 | HP PSC 1610 All-In-One InkJet Printer
Carriage stalled on hp psc 1200 all in one printer
I suppose never use a refilled catridge need to check the catridge for any damage and also check the sensor of the printer , incase the sensor is damaged you hear a loud noise.
Dec 16, 2008 | HP PSC 1210 All-In-One InkJet Printer
Stalled printer cartridges
Sounds like an issue with the print carriage. When it's out of alignment and tries to print, it can make awful noises. HP.com has a web page that describes a number of troubleshooting steps when you have print carriage issues:
Carriage Jam Errors
There's also a related web page having to do with the noise coming from the printer:
Noisy Print Carriage
Hope this helps. Good luck.
Oct 07, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Calibrate the carriage
Printers are finely tuned machines. Unplug it from the wall for a couple of minutes. Let it forget about the pain. Turn it back on see if it realigns itself. You may get lucky. otherwise, You may need to unscrew the same screws and make sure the cartridge holder is pushed securely on the track. Good thing new printers aren't too expensive. Buy a model that takes the same kind of ink. That is where their money is made. Good Luck, Tim
Feb 08, 2007 | Dell A920 InkJet Printer
Dell 962 Photo All-In-One InkJet Printer Logo
127 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
