Bread pan paddle does not turn.
Your drive
belt is probably broken or has slipped off. Unplug your machine and turn it on
its side (remove the pan and paddle first) and remove the bottom panel with a
screwdriver. Most bread machines have a removable panel. Hopefully yours is one of those. You will
then be able to see if the belt is broken or has slipped off. You can reach me
at breadmachineshelp.com for reinstall or replacement of your belt. If your belt has a number code on it I will
need that. It will look something like
this: STS 60 S3M471 If it has no code on it I still may be
able to figure out the belt you need.
Again, reach me at my website: breadmachineshelp.com
SOURCE: pan is stuck in my cuisinart cbk-200 breadmaker.
Just pull it.
I had the same problem few moments ago until I read someone's answer.
It really worked and it won't brake.
SOURCE: does CBK-100 bread pan work
Hi ok2rydbo,
I see that you are having issues with the Pan replacement that you bought is bigger than that of the original that came with your CBK-200.
You are asking if the CBK-100 Pan will work on your CBK-200 yes that Pan will work from the CBK-100 to the CBK-200, there really isn't any different with the size of the Pan from the CBK-100 from the Pan of the CBK-200 it is Identically the same.
Also regarding the Pan replacement you got, try calling where you bought it maybe they just sent the wrong Pan to you and most probably you may have it replaced as long as its the wrong Pan then they will replace it.
Have a nice day.
Thank you for choosing Fixya,
mvincentc
reach in with your fingers and bend the two little clips out a little until they grip your pan snugly. Start with 1/4 " and try that. If it doesn't feel snug go another 1/4 inch.... and so on....
