Question about Kenmore 46462 Front Load Washer
Bleach & Softner not emptying
The bleach & softener portions of the drawer are not emptying.
  • mlea99 Feb 27, 2009
    We have been using liquids.
What "form" are you using? liquid, gel, powder? try using a different type and lean towards the more liquid forms if your washer can handle them, ie move from powder to gel or liquid, and from gel to liquid. Hope this helps.
Posted on Feb 26, 2009
Water fills up in the bleach and softner side of the drawer
Here is a tip that I wrote about what I found out about the fabric softener notdispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going intowasher
heatman101
Oct 25, 2010 | Frigidaire ATF6000ES Front Load Washer
Bleach and Fabric Softner Dispenser
Hi
This is a result of the siphoning action and is part of the normal operation of the washer. Water
may be removed by removing the dispenser drawer and draining
water into the empty drum or sink.
Outside
• When washing is completed, wipe top and sides of washer with a damp cloth. Turn water
faucets off to prevent pressure build-up in the hoses.
• As needed, clean the cabinet with mild soap and water. Never use harsh, gritty or
abrasive cleansers. If door or console becomes stained, clean with diluted chlorine bleach
[1/2 cup (120 ml) in 1 quart (.95 L) water]. Rinse several times with clear water.
• Remove glue residue from tape or labels with a mixture of warm water and mild detergent.
Or, touch residue with the sticky side of the tape or label.
• Before moving the washer, place a strip of cardboard or thin fiberboard under the front
leveling legs to prevent floor damage.
Cleaning the Dispenser Drawer Area
Detergent and fabric softener may build up in the dispenser drawer. Residue should be removed
once or twice a month.
• Remove the drawer by pulling the drawer out until it stops. (Figure 1)
• Reach back into the left rear corner of the drawer cavity and press down firmly on the lock
tab (left rear portion of the drawer). Pull out the drawer. (Figure 2)
• Remove the insert from the bleach and fabric softener compartments. (Figure 3)
• Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders
and liquids. Large amounts of fabric softener residue may indicate improper dilution or
more frequent cleaning is required.
• To clean the drawer opening, use a small brush to clean the recess. Remove all residue
from the upper and lower parts of the recess. (Figure 4)
• Replace the insert pressing the "X" to lock it in place. Return the dispenser drawer.
Inside
• Remove items from the washer as soon as the cycle ends. Excess wrinkling, color transfer,
and odors may develop in items left in the washer.
• Before cleaning the washer interior, unplug the electrical power cord to avoid electrical
shock hazards.
• Dry around the washer door opening, flexible gasket, and door glass. These areas should
always be clean to ensure a water tight seal.
• When extremely soiled items have been washed, a dirty residue may remain on the drum.
Remove this by wiping the drum with a nonabrasive household cleanser. Rinse thoroughly
with water.
• Periodically, wipe dry the bottom of the flexible gasket to remove lint and other debris.
• The plastic drum vanes may become stained from fabric dye. Clean these parts with a
nonabrasive household cleanser. This prevents dye transfer to future loads.
try this out for more ref check the operations mannual page 7
Dec 07, 2007 | Frigidaire Affinity ATF7000ES Front Load...
GE WSXH208AWW doesn't dispense detergent, softner or bleach. Dispenser is totally dry after wash cycle.Appears no water gets to tray.
I'm having almost the same problem - the bleach & softener both will NOT dispense, but (LUCKILY) the detergent does dispense on mine, for now.
In order to get the solutions (bleach, softener, detergent) to go into the washer, the water needs to pour through the dispenser somehow. Dry means NOT working (mothmanmeg).
I need help, too!! We tried taking the drawer out & cleaning, no luck.
Apr 17, 2010 | GE WSXH208A Front Load Washer
Help My front loading washer is not dispending
have you pulled the drawer from the machine and cleaned it thoroughly. break it down into individual pieces and clean the hell out of it. Fabric softener can build up over time and clog every crack and crevice. check also the hole the drawer goes into, water flows into the drawer mixes with f.s., bleach, etc. dilutes it and sends out the bottom.
Jun 16, 2009 | Washing Machines
Dispenser drawer and tub
softner dispenser has pushed down into the dasher. How to take off top of dasher to replace the small softner dispenser cup that was pushed down.
Apr 13, 2009 | Washing Machines
Bleach & Softener not emptying
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 26, 2009 | Kenmore 46462 Front Load Washer
Dispenser tray removal
hi, nikoltheis! i'm not sure if we have exactly the same model, but it should be pretty close. here's what my user's manual says:
Detergent and fabric softner may build up in the dispenser drawer. Residue should be removed once or twice a month
- Remove the drawer by first sliding the safety latch to the right, then pulling the drawer out until it stops.
- Reach back into the left rear corner or the drawer cavity and press down firmly on the lock tab (left rear portion of the drawer). Pull out the drawer.
- Remove the insert from the bleach and fabric softner compartments.
- Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders and liquids. Large amounts of fabric softner residue may indicate improper dilution or that more frequent cleaning is required.
- To clean the drawer opening (the empty area left behind when you remove the drawer) use a small brush to clean the recess. Remove all the residue from the upper and lower parts of the recess. (The picture shows this being done with a tooth brush.)
- Replace the insert pressing "X" to lock it in place. Return the dispenser drawer.
Jan 18, 2009 | Frigidaire GLTF2940ES Front Load Washer
Kenmore front load washer will not dispense fabric softner
I've had this same problem and solved it by removing the detergent/bleach/softener dispenser drawer from the machine and seriously cleaning out all of the "gunk" from the drawer and from inside the drawer area on washer. Sometimes I have had to repeat the cleaning and then the fabric softener begins dispensing again. I have model # 417.43042200 but it may work on all the Kenmore front loading washers.
Oct 28, 2008 | Washing Machines
Bleach leaking on floor
hiya was a bit puzzled at this one ? but will try to help not certain re your machine about bleach in dispensor but consulted the wife about bleach in our machine and no where in the manual does it mention use of bleach only softeners ? however you mention dispensor does not dispense ? try this? remove/pull out drawer and clean out the machine where drawer fits of any residue powder alsi the softener dispensor remove from drawer and ensure the cap is good fit on the dispensor tube ? if loose? then the dispensor will not work as it is emptied of softener//bleach by syphon effect ie as like toilet flush? as water enters rises to tor of tube then the fluid in compartment is syphoned along with water that is entering on rinse? cycle so if no syphon? water will o/flow/fill the drawer on l/h side and may o/flow leak from drawer ?? hope this helps? and you understand the syphon effect for using softeners ? ps i may be mistaken about use of bleach but prior apologies if iam wrong
Oct 20, 2008 | LG WM-2277HW Front Load Washer
Fabric Sofner won't dispense
hi there remove the soap drawer then remove the cover over the softener compartment you will more than likely find a blockage in the cover siphon or the down tube on the drawer
Feb 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 46462 Front Load Washer Logo
79 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
