Question about Sunbeam 2774 Blender
My Sunbeam Kitchen Assist doesn't work
My Sumbeam Kitchen Assist is less than 6 months old, however, it has stopped working. The blender (motor) doesn't operate when I fix the lid/container. I don't believe, I misused it by over heating or putting in water.
I think, the motor is the problem. I will appreicate if you can provide me suggestion to fix the motor.
  • Anonymous May 02, 2009
    My sunbeam assist doesn't work either. I do not believe it was misused, I also think it is the motor. Nothing happens when I plug it in.
Hi there, you might want to check the swithing mechanism that turns the motor ON. I don't think the motor will fail, specially if it doesn't smell like it's burnt.
Just an idea...
Chino
Posted on Apr 07, 2009
Not working
How to Fix a Blender ' DoItYourself.com
www.doityourself.com/stry/how-to-fix-a-blender
A food blender is a far less complex machine than most people might imagine. Because of this simplicity, you can easily determine the cause of a non-working ...
The Ninja Ultima Blender: What To Do When Power Light Is ...
? 0:36
https://www.youtube.com/watch?v=LfY_-VA5m8A
Oct 16, 2013 - Uploaded by Ninja Kitchen
... Blender start flashing. If the light on your Ninja Ultima Blenderis flashing, check the following... ... Still not working. Read more Show less.
Dec 09, 2015 | Blenders
When I turn my blender on, it runs for only a few seconds, then stops and all the lights on the panel flash on and off.
More often than not it will need the motor to be replaced, only Kitchen Aid parts will do, motors are usually unique to brands and models. Sometimes it can be the control/button panel but normally the motor.
Mar 21, 2011 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Where can I find a gasket for Sunbeam 2774 blender???
If you cannot find one, well in the "Old" days we used to make gaskets out of Thick Brown Paper Bags. Using the OLD gasket as a template simply trace around it & cut it out. Lightly Oil it and use it as normal. Usually works great, sometimes you need two, to get the thickness.
Feb 03, 2010 | Sunbeam 2774 Blender
The blades stopped turning in the middle of blending a batch of hummus Its is a Kitchen Aid blender about 10 years old
Does the motor still work if you take the pitcher off of the base? If so, the rod that's in the blade assembly is probably corroded. The blades are connected to a metal rod that passes through a brass tube through to the piece that makes contact with the motor when you put the pitcher on the base. The grease wears down eventually and if you don't pulse and run the motor for a long time at once, the heat can corrode the bar and cause the blade to stop spinning. You can either disassemble the blade unit, or buy a new blade unit online. google blender parts and you can get one for $10
Dec 22, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Jeff Gordon Blender blew up
Sorry to say we do not repair. You will have to contact sunbeam here at this link for service.
http://www.sunbeam.com/index.aspx?section=kitchen
Good luck and Please Rate FixYa1!
Dec 28, 2008 | Sunbeam Jeff Gordon NASCAR 12 Speed...
My rarely used Sunbeam Blender Model #4181 stopped working
It sounds like one of a number of things...
* The contacts in the switches fried
* The motor itself fried
* The controller section fried
If you saw smoke, something fried... probably cheaper to simply replace the unit. Even if it still worked, it's a 120V electric appliance used with liquids, and I wouldn't trust it... I'd hate to hear that your blender started a kitchen fire.
Mar 22, 2008 | Oster 4134 / 4126 Classic Beehive Work Top...
5 speed ...steel
i had the same problem after only one month, took in back to walmart and they would do nothing. i love the big heavy glass jar on this model so i baught another on thinking i broke it some how and guess what, the second one stopped after one and a half months. called around and no one would do anything for me, company sucks, i took the bottom cover off the blender to expose the problem and there is a problem with the curcuit board and built in breaker. i ripped out all the speed buttons and curcuit board and just wired in a on/off switch to the motor. works great again. i still had a extra broken blender so i took a old chain saw i had and turned that one into a gas powered blender. problem solved, any questions please feel free to ask, strawsj1234@hotmail.com
Sep 11, 2007 | Black & Decker BL5000 ProBlend Work Top...
Stopped working
i had the same problem after only one month, took in back to walmart and they would do nothing. i love the big heavy glass jar on this model so i baught another on thinking i broke it some how and guess what, the second one stopped after one and a half months. called around and no one would do anything for me, company sucks, i took the bottom cover off the blender to expose the problem and there is a problem with the curcuit board and built in breaker. i ripped out all the speed buttons and curcuit board and just wired in a on/off switch to the motor. works great again. i still had a extra broken blender so i took a old chain saw i had and turned that one into a gas powered blender. problem solved, any questions please feel free to ask.
Sep 01, 2007 | Black & Decker BL5000 ProBlend Work Top...
Lights blink, but Cuisinart Smartpower 7-speed wont turn.
The thermal fuse is blown. You can buy a replacement from RadioShack for $1.69 You have to remove the old one and solder in the new one. If youre "handy" its very easy. Take it to a repair shop, you pay about the same as a new one. Its too bad that most electronics made today are cheaper to throw away and buy a new one rather than fix them when they break.
Aug 14, 2007 | Cuisinart SPB-7 SmartPower Work Top...
Sunbeam 2774 Blender Logo
304 people viewed this question
Top Sunbeam Blenders Experts
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sunbeam Blender Expert? Answer questions, earn points and help others
