Question about eMachines W4620 Notebook
Having problems starting my laptop. it starts fine but freezes within a minute or so. i try it again numerous times and it freezes around the same time each time. what can the problem be?
  • 679 Answers
Try booting into "safe mode". by taping the f8 key while it is booting. If it runs ok there it may just be a video driver, as this is what it sounds like. If you have the same problem in safe mode, you have either a virus or spyware program that's in one or more files. If that's the case go back to sae mose, and run a good virus cleaner and spyware sweeper, Avg makes a free version, and Spyware search and destroy , and run that also. Try the video driver first, it may be a combination of both, that's one of the problems of doing a blind repair like this, we sometimes have to try a few things before nailing the correct problem. But it is more than likelly one of those two, good luck
Posted on Feb 26, 2009
  • 80 Answers
Seems to me you have some kind of virus or spyware ! 2 solutions do bios hard drive check to make sure not hard ware falure! or do virus boot scan!
Tried almost everything, please help
It is because It is because fat partitions dont suupport manupulation of files bigger than 4 gb. Convert it to ntfs and it will work. And you might wonder that it worked for 15 min. ISo when you play a game lots of cache is generated and size of game is nearly doubled so this causes problem on a fat partition. And on
Jan 07, 2014 | Sony Playstation 3 (PS3) Console
Ice maker freezes up
It's likely you have your freezer to cold, Try reducing the setting on that. If that doesn't work you might wanna check your freezer and make sure it's not thawing and then freezing again, you might have a problem with your fridges thermostat.
Oct 12, 2009 | LG LSC26905TT Side by Side Refrigerator
Intermittantly the car won't start
Main Fuel injector relay is probably the culprit. Buy a second hand one for about 50 bucks and replace it yourself within 30 minutes.
Mar 07, 2009 | 1991 Honda Accord
My dell Crashes within minutes of turning it on!
This could be a multitude of things, but the first thing that comes to mind is an overheating problem.
To rule out other things, remove and reseat the RAM, HDD, CD/HDD drive, Battery, Wi-Fi/BlueTooth mini adapters, etc.
Also, for further clarification, is there any error indicated on the screen prior to the machine turning off?
Thanks,
Rob
Mar 06, 2009 | Dell Inspiron 1525 Notebook
96 Jeep Cherokee stall then hard/no start
change fule filter if nothing changes do fule pressure test
Feb 11, 2009 | 1996 Jeep Cherokee Country
Xbox 360 Freezing Problems
Shutting off the Xbox corrupted the Hard Drive... Have you ever got a Live System Update? You can also reset your Xbox without shutting it off using the controller. You probably have the Three Red Rings of Death... Go to this...
http://www.fix3redlights.com/?p=bfy&m=1&gclid=CKTS1MGEmpcCFRlRagodpD9H-A
Nov 29, 2008 | Microsoft Xbox 360 Console
Inspiron B130
Well start a bit slower then.
go into the bios at startup F2, and navigate around does it freeze there. if no then
start windows in safe mode F8 when windows logo shows.
freezing ?
If its not freezing then turn off the startup programs.
Start/run/msconfig and then uncheck load startup items
and start normally, click the dont show me this again /ok
any freezing.
If its freezing you may have a hardware issue.
if you have 2 sticks of memory remove on and or /reseat them
boot the dell diagnostics cd and check the cpu and memory.
report back
Jan 30, 2008 | Dell Inspiron B130 Notebook
Compaq Presario V2000 keeps freezing up
It could be something as simple as a corrupt graphics driver. If you have currently run a Windows update for hardware, there is a chance that a generic Windows driver has been installed and is not working correctly. Go to your task bar, as there is normally a graphics programme running enabling you to set the external monitor etc. If it's there and you have lost all the usual tabs for changing different properties, then the driver will need to be downloaded from your notebook manufacturer. If all in that looks ok then click Start>Run then type 'dxdiag' and hit enter and let windows do a diagnostic test on sound and video. If it's an intermitent problem, this is normally down to overheating, so check the vents around your fan and gently give them a hoover out. Failing all; keep an eye on your processor temperature, you can download allsorts of different free programmes that will run in your taskbar.
Jan 02, 2007 | HP Compaq Presario V2000 Notebook
eMachines W4620 Notebook Logo
173 people viewed this question
Top eMachines Computers & Internet Experts
Michael Vincent Cruz
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
