Question about Kenmore 46462 Front Load Washer
Bleach & Softener not emptying
The Bleach & Softener portions of the the drawer do not empty. We have changed the electrical parts that let the water into these portions and have thoroughly cleaned the compartment.
  • 15,935 Answers
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
How do i remove the drawer to clean it out the bleach, softener, detergent dispensers?
The dispenser slides out . There are plastic slideson both sides of the outer dispenser tray which run into grooves internally . be careful not to force its removal as you will damage the tray
Feb 10, 2015 | Kenmore Washing Machines
Bleach and Fabric Softner Dispenser
Hi
This is a result of the siphoning action and is part of the normal operation of the washer. Water
may be removed by removing the dispenser drawer and draining
water into the empty drum or sink.
Outside
• When washing is completed, wipe top and sides of washer with a damp cloth. Turn water
faucets off to prevent pressure build-up in the hoses.
• As needed, clean the cabinet with mild soap and water. Never use harsh, gritty or
abrasive cleansers. If door or console becomes stained, clean with diluted chlorine bleach
[1/2 cup (120 ml) in 1 quart (.95 L) water]. Rinse several times with clear water.
• Remove glue residue from tape or labels with a mixture of warm water and mild detergent.
Or, touch residue with the sticky side of the tape or label.
• Before moving the washer, place a strip of cardboard or thin fiberboard under the front
leveling legs to prevent floor damage.
Cleaning the Dispenser Drawer Area
Detergent and fabric softener may build up in the dispenser drawer. Residue should be removed
once or twice a month.
• Remove the drawer by pulling the drawer out until it stops. (Figure 1)
• Reach back into the left rear corner of the drawer cavity and press down firmly on the lock
tab (left rear portion of the drawer). Pull out the drawer. (Figure 2)
• Remove the insert from the bleach and fabric softener compartments. (Figure 3)
• Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders
and liquids. Large amounts of fabric softener residue may indicate improper dilution or
more frequent cleaning is required.
• To clean the drawer opening, use a small brush to clean the recess. Remove all residue
from the upper and lower parts of the recess. (Figure 4)
• Replace the insert pressing the "X" to lock it in place. Return the dispenser drawer.
Inside
• Remove items from the washer as soon as the cycle ends. Excess wrinkling, color transfer,
and odors may develop in items left in the washer.
• Before cleaning the washer interior, unplug the electrical power cord to avoid electrical
shock hazards.
• Dry around the washer door opening, flexible gasket, and door glass. These areas should
always be clean to ensure a water tight seal.
• When extremely soiled items have been washed, a dirty residue may remain on the drum.
Remove this by wiping the drum with a nonabrasive household cleanser. Rinse thoroughly
with water.
• Periodically, wipe dry the bottom of the flexible gasket to remove lint and other debris.
• The plastic drum vanes may become stained from fabric dye. Clean these parts with a
nonabrasive household cleanser. This prevents dye transfer to future loads.
try this out for more ref check the operations mannual page 7
Dec 07, 2007 | Frigidaire Affinity ATF7000ES Front Load...
The detergent, bleach and fabric softener cups are left full of water.
You need to remove the detergent drawer and clean properly with boiling water and put some boiling water down the the supply pipe to the drum
Dec 25, 2014 | Washing Machines
Why does water collect in bleach and fabric softener drawer?
Hello friend, thank you for your post!
This is a normal part of the siphoning action of your drawer. You would just remove the dispenser and discard the water. Hopefully this is helpful. -Matt
Sep 08, 2014 | Electrolux Washing Machines
Fabric softener drains out, but pumps water back into dispenser after draining?
Hello friend, thank you for allowing me to assist you!
It is a normal operation to receive water inside the dispenser after draining. This is part of the siphoning action of the drawer. You would just remove the drawer and empty the water out, then reattach the dispenser drawer. I hope this is helpful. -Matt
Sep 01, 2014 | Frigidaire Affinity ATF6000F Front Load...
When i put in the fabric softener and run a load there is water filling the bleach and fabric softener compartments when the wash is completed. That did not happen in the first few years I owned the...
That same thing happens to mine. You can take the whole little drawer out and empty the water. I don't know why it does this to begin with, but obviously you don't want to leave the water in it so there is a button behind the back end of the "detergent" holder spot, push down on it and pull out the drawer. Then just empty it and slide it back in.
Jan 01, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Softener won't empty in Bosch Classixx 1000
take out the soap drawer clean in hot water inside the machine where you took the soap drawer out at the top look for the hole where the water runs out it may be blocked with mildew dettox mildew spray is very good at breaking all that down spray in leave for a while put soap draw back in and do a wash without clothing as spray contains bleach
Mar 30, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Detergent drawer filled with water
remove the drawer and clean the siphon it sounds as if it is blocked up either with powder or concentrated fabric softener. this should fill up with water and then empty itself due to gravity. the siphon should look like an upside down cup on a cylinder.
Jul 23, 2009 | Kenmore Elite 45986 Front Load Washer
Bleach & Softner not emptying
What "form" are you using? liquid, gel, powder? try using a different type and lean towards the more liquid forms if your washer can handle them, ie move from powder to gel or liquid, and from gel to liquid. Hope this helps.
Feb 26, 2009 | Kenmore 46462 Front Load Washer
Bleach leaking on floor
hiya was a bit puzzled at this one ? but will try to help not certain re your machine about bleach in dispensor but consulted the wife about bleach in our machine and no where in the manual does it mention use of bleach only softeners ? however you mention dispensor does not dispense ? try this? remove/pull out drawer and clean out the machine where drawer fits of any residue powder alsi the softener dispensor remove from drawer and ensure the cap is good fit on the dispensor tube ? if loose? then the dispensor will not work as it is emptied of softener//bleach by syphon effect ie as like toilet flush? as water enters rises to tor of tube then the fluid in compartment is syphoned along with water that is entering on rinse? cycle so if no syphon? water will o/flow/fill the drawer on l/h side and may o/flow leak from drawer ?? hope this helps? and you understand the syphon effect for using softeners ? ps i may be mistaken about use of bleach but prior apologies if iam wrong
Oct 20, 2008 | LG WM-2277HW Front Load Washer
Kenmore 46462 Front Load Washer Logo
49 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
