Question about Toshiba 55H70 55" Rear Projection Television
Toshiba rear projection menu pops up
The reset button was hit now the menu pops up and continues to cycle through everything over and over.
    President:
  • Toshiba Master
  • 1,779 Answers
Try un-pluging the set for about 3 minutes then back in then on- (Hard Reset) Let me know?
Posted on Feb 26, 2009
HOW DO YOU RESET THE LAMP USE TIME ON THE JVC HD 56 G787 REAR PROJECTION
u need the real remote rm-18g hit menu till u get to lamp reset hit enter a screen will come up that says press ok to reset lamp timmer hit ok button than another screen will come up that says the lamp timmer was reset successfully
Sep 08, 2013 | JVC HD-52Z575 52" Rear Projection...
Toshiba 62hx94 cant shut off closed caption have comcast cable How do I turn off closed caption on my TV. It suddenly turned on.
if the tv is not hd then the control is on your tv.
However if the comcast box is an hd box do the following;
Press cable, then power and then with 2 seconds press the red menu button to get the hidden hd user setup menu. You may have to hit the menu button multiple times to get the menu to stay up on the tv.
Next go down to closed captions which is probably enabled, and hit the left or right arrow key to change it to disabled.
Then press the power button twice to turn the box off and back on.
Dale
Dec 26, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
Reseting lamp counter (LG)
Make sure the TV is on and:
1) Press and hold the Menu button on your TV SET
2) Press and hold the Menu button on your REMOTE CONTROL (at the same time)
3) Continue holding BOTH buttons down for 5 secconds or until the Service Menu pops up
4) Release the MENU button from your REMOTE CONTROL, then release the MENU button from the TV Set.
5) Press and hold ENTER (or OK) on the TV Set, then:
6) Press and hold MUTE on the REMOTE CONTROL (while still holding down the ENTER button on the TV SET
7) Holding both buttons down should lead to the Lamp Life Hours screen to pop up.
Release the MUTE button the REMOTE CONTROL, then release the ENTER (or OK) button on the TV Set.
9) Come back to this blog and post your HOURS on our site
10) Now press SELECT, then SELECT again to confirm the reset of the counter
** If the procedure above does not work swap steps 5 & 6.
** For a few special models (including 44SZ8D), you might have to change step 5 to:
5a) Press Enter on the TV Set to enter the Position Adjustment Screen
5b) Press and hold Enter on the TV Set (the TV should go back to the main Service Menu, continue holding Enter) and now also hold down the MUTE button on your REMOTE CONTROL. After about 5 seconds, your Lamp Life Counter should pop up.
Jun 30, 2008 | Televison & Video
Need to reset lamp life indicator on lg rear projection tv model no 525sz812-tb
9) To Check if it was a success
Jun 21, 2008 | LG Televison & Video
Replacing lamp in rear projection tv
To do this, press the ENTER button on the TV and the MUTE button on the remote at the same time. After 5 seconds the screen should come up and it will read "Lamp use time...Total lamp use time ....lamp reset" Press the center button on your remote (the circle button right in the middle of the four directional buttons) and you will be reset to -0- again. Your orange light should now be off.
May 09, 2008 | LG RU-52SZ30 52" Rear Projection...
ZENITH D52WLCD
I just found the solution on another model of Zenith TV. Hold the enter button down on the TV and the MUTE button on the remote. In approx. 5-7 seconds a screen will pop up asking if you want to reset the lamp timer. Hit the bullseye button in the middle of the arrows and it will reset. Worked perfectly.
Apr 15, 2008 | Zenith D52WLCD 52" Rear Projection...
Toshiba tp50h50
replace the power supply deflexion module sounds like a cap proplem on the board
Mar 11, 2008 | Toshiba TP50H50 50" Rear Projection...
Lg rear projection model: RT52SZ60db
You need to use the original LG RT52SZ60DB remote.
  1. Press MENU buttons on the REMOTE and on the TV at exactly the same time and hold for about 3 seconds (TV buttons are just below lower left of screen)
  2. Scroll down the SERVICE MENU to No. 14 LAMP REPLACE
  3. Press VOL |> button to enter lamp hours
  4. Press OK button to RESET hours, or CANCEL/EXIT to Exit menu
Hope this helps.
Cheerz ;^)
Feb 29, 2008 | Zenith E44W48LCD 44" Rear Projection HDTV
Accessing sevice menu
i tell people all the time if you get into the service menu and hit the wrong buttons i wont know what you did to it again if you post here to ask how to get into the service mode you dont have the desire to find the codes on the internet which are readily available as are service manuals turn on the tv push mute on the remote till mute goes out hold down mute button and push menu on front of tv hit menu again when the s comes up hit 7 on remote and watch out you just figured how to reconverge your tv maybe not
Dec 06, 2006 | Toshiba 55H70 55" Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
54 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
