Question about IBM ThinkPad R50e Notebook
Computer freezes after startup. cannot start in normal mode
  • 80 Answers
Usually virus could be hard drive faliure!
Posted on Feb 26, 2009
4 Suggested Answers
  • 52 Answers
SOURCE: will not start up normally (freezes )
it sounds like the operating system has gone corupt so have you got a disc to reinstall windows and all the drivers!if you have i would format the harddrive and reinstall the copy of windows
Posted on Nov 02, 2007
leighblue31
  • 77 Answers
SOURCE: scrambled screen at startup
have you tried to run system restore?
Posted on Sep 12, 2009
samaddar07
  • 639 Answers
SOURCE: Acer Aspire 5532 freezes on
Go to 'Start' and then Run
write "msconfig" inside Run tab and press 'enter'
inside the 'System configuration utility' window click on 'startup' tab then uncheck all the applications except your current antivirus and press apply then 'ok' and then 'exit without restart' option.
Now right click My Computer and go to properties tab.
click 'Advanced' tab then under performance menu click on 'settings'
go to 'Advanced' click on 'change' and increase your virtual memory to 2048 in both spaces.
Now restart windows.
After restart login to windows and do the following
1) Delete all unwanted data from Drive C.
2) Delete all data that you have copied from Drive C to External HDD
3) Open My computer and go to Tools---> Folder Options---->Click on View Tab----> Check 'Show hidden files and folders' and select OK.
4) Go to C:\Documents and Settings\Administrator\Local Settings\Temp and Delete everything that you see inside Temp Folder
5) Go to C:\WINDOWS\ here you will find folders like $hf_mig$, here you will have to Delete all the folders starting and ending with $ sign.
6) Empty Recycle bin and restart the PC
There are many things that might cause your PC to run slowly. It could be a fragmented disk; fragmented registry; a virus, Trojan, or spy ware; high CPU and/or utilization due to too many programs running; high disk I/O; or something else.
To check your CPU and memory utilization, run Task Manager. You can start Task Manager by pressing CTRL+ALT+DEL and then clicking on the Task Manager Button. In Task manager, click on the Performance tab and check CPU Usage and PF Usage. PF Usage is an indicator of memory usage. If one or both of these is high, click on the Processes tab, and sort the columns by CPU or Memory to see what processes are consuming the resource. If you are not sure what the process "Image name" is for, Google the name and you should find what the process is for.
If your CPU and memory usage are reasonable, then you may have a different issue. Even if you running anti-virus software, it may be beneficial to scan your PC with another scanner to check for viruses. No anti-virus software is 100% perfect at catching everything. Here are a few good free online virus scanners that you can run to check your PC:
http://security.symantec.com/sscv6/home.asp?langid=ie&venid=sym&plfid= 23&pkj=RRJEDTKJBTVISBYWWYP
http://www.eset.com/us/online-scanner
An excellent free utility for overall system maintenance is Advanced System Care Free ( http://download.cnet.com/advanced-systemcare-free/3000-2086_4-10407614 .html ). I use this utility on a regular basis.
You should always run anti-virus software. There are several very good, free, anti-virus products available. One good source to read editor and user reviews, and safely download anti-virus software, is http://download.cnet.com -- search for free antivirus software. In addition to the reviews, you can see how many people are downloading the software, which is another good indicator of how popular it is.
I have used AVG Free ( http://download.cnet.com/avg-anti-virus-free/3000-2239_4-10320142.html ) , and Avast Free ( http://download.cnet.com/avast-free-antivirus/3000-2239_4-10019223.htm l ). Both are very good, and completely free. At present I am using Avast on all of my home computers.
In addition to Avast or one of the other free anti-virus software packages, I also run Ad-Aware ( http://download.cnet.com/ad-aware-free-internet/3000-8022_4-10045910.h tml ). Ad-Aware is a free anti-malware, anti-spyware package.
If you feel that my answers have helped you getting solution to your problems then please give a vote.
Thanks.
Posted on Jul 26, 2011
Freezing at startup
try running your machine on safemode and if it starts up normally,dissable startup apps which may be causing the freeze.restart on normal mode and it should start up fine.
Jan 10, 2016 | Computers & Internet
Aspire 5475 freezes on startup
It is most certainly a driver, but if you cant access the safe mode also that could be a hardware issue.. Try to troubleshoot with a windows installation cd. Put it in and boot the pc. It will start the windows instalation, you choose repair computer and not install windows. The command prompt will open, try to troubleshoot from there.. Thanks!
Mar 19, 2013 | Computers & Internet
Toshiba satellite L675 freezes after startup. Windows &
Boot the computer into "Safe Mode".
To boot PC into Safe Mode follow these steps:
1. Turn the computer on or Restart the computer
2. Start tapping the F8 key. The Windows Advanced Boot Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
3. Ensure that the Safe mode option is selected, not Repair Your Computer
4. Press Enter. The computer then begins to start in Safe mode.
5. When you are finished with troubleshooting, close all programs and restart the computer as you normally would
If the computer boots into Safe Mode you can try disabling Startup Programs, one of these might be causing your computer to freeze. To do this follow these steps:
1 Press Start. Type msconfig into the search bar and press Enter. For XP, click on Run and type msconfig there.
Mar 30, 2011 | Toshiba Satellite L675-S7062 Notebook PC
My Dell Inspiron 1525 freezes randomly after starting up. I can't use the mouse or keys to change the screen. The computer freezes around 5 minutes after starting up. I booted up in safe mode and have...
If you had no issue in safe mode the only thing I've seen like that is a virus that cuts of your use of I/O ports. boot into safe mode and try doing a system restore to a time before this problem occurred. IF that doesn't solve the problem try doing a clean install of the OS
Feb 28, 2011 | Dell Inspiron 1525 Notebook
My sons acer kav60 is stuck on the windows start up screen and will not reboot.
If it's still under warranty, take it into the shop for repairs.
Jan 14, 2011 | Acer Aspire One PC Notebook
My computer runs window 7 and it keeps shutting down for no reason and also it keeps freezes for sometime.
Reboot the computer in "Safe" mode and run it for a while and see if the same problems occur. If it doesn't, then I would suspect it is a software and not a hardware problem.
If you think it is a software problem, reboot the computer into safe mode again. Now click the start button and in the search box type MSCONFIG
When the window pops up click the "Selective Startup" button and then on the startup tab. Deselect all the checked boxes, click apply and ok, reboot the computer normally.
Now only the essential services will load and no programs will automatically load. If the computer continues to run normally, then you can go back into MSCONFIG go to the strat tab and start checking a few boxes to start again, like antivirus and malware first. Reboot the computer and see if it freezes with those programs running....if it does then you know one of those is the culprit, if not click a few more on and reboot until you find the trouble software.
Jul 01, 2010 | Computers & Internet
IBM Laptop
Try going to Safe Mode. Normally you press F8 when you start the computer. When in Safe Mode, click Start -> Run then type msconfig. On the first tab, click on Diagnostic Startup. Apply, close and reboot the computer to Normal Mode. Lockups during startup are caused by startup programs.
Please rate this if you think this is helpful.
Dec 09, 2008 | IBM ThinkPad T30 2366 Notebook
Will not start up normally (freezes )
shift prees then mouse buten click for startup freezes icon then uninstaLL
Jun 24, 2008 | HP Media Center m7060n PC Desktop
Inspiron B130
Well start a bit slower then.
go into the bios at startup F2, and navigate around does it freeze there. if no then
start windows in safe mode F8 when windows logo shows.
freezing ?
If its not freezing then turn off the startup programs.
Start/run/msconfig and then uncheck load startup items
and start normally, click the dont show me this again /ok
any freezing.
If its freezing you may have a hardware issue.
if you have 2 sticks of memory remove on and or /reseat them
boot the dell diagnostics cd and check the cpu and memory.
report back
Jan 30, 2008 | Dell Inspiron B130 Notebook
Oct 30, 2007 | Sony VAIO PCG-K25 Notebook
IBM ThinkPad R50e Notebook Logo
203 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
