Question about Kenmore 22422 Top Load Washer
Can't find the overfill switch to reset i looked everywhere (in the manuel n parts list) can't locate
  • Nikki Nicholson May 11, 2010
    If this is a top load washer there is no reset for it and you have to replace it. Can I ask why you are trying to reset the overflow?
  • 15,935 Answers
This advice is for a washer that fills and will not shut off, resulting in an overflow. Or, water is leaking from the washer while filling. The symptoms can apply to either a TOP LOADER or FRONT LOADER washer. This may be able to save you from an expensive service call by making these simple visual checks.
Water Does Not Shut Off and Overflows: The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
Water Leaking While Filling: The other end of this hose runs to the air dome fitting on the side of the wash tub. If the lower end of the hose comes off, the water will begin to spill onto the floor under the washer, but the tub will not fill.
What to Look For: Check for the obvious. Make sure the air hose is still attached to the pressure switch and air dome. Then, inspect the entire length of the hose, paying particular attention to areas where chaffing may occur and at the points where the hose connects to the pressure switch and air dome. Vibrations from the washer can cause some wear if the hose is rubbing against anything, and the ends of the hose can stretch over time and not seal properly.
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the “Load Level”, “Load Size” or “Water Level”. On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½” off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful and saves many of you a future service call.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
Car will crank, but won't start
One of the usual problems with Ford products is the Inertia switch. It has a reset button and is made to cut power to your fuel pump in case of a wreck. A bump, jarring motion will falsely trip this switch. Closing a door or cargo lid can occasionally create the right frequency to do just that.
You have a switch that has several locations listed. You can try under the dash to the right of the transmission hump. Another potential location is the Drivers lower rear cargo area, close to the Air-ride switch. A third place is the front kick panel area.
I would advise looking up this part under your Year and Model and get pictures of what you are looking for. Cannot say why many locations are listed. You will see when you read the search results.
Jan 15, 2014 | 2005 Mercury Mountaineer
Frigidaire side-by-side model GHSC39EJPWO. Light in frig don't work, tried changing bulbs; didn't help. I cannot find the light switch - where is it located? I have examined everywhere!
I too am very perplexed by that i have looked at the parts breakdown and see a switch for the freezer in the side wall but no switch for the fresh food section. I have included the link for the parts breakdown i was looking at, the freezer light switch is item# 14A
http://c.searspartsdirect.com/lis_png/PLDM/R0804082-00003.png
Good luck
Gene
Aug 02, 2011 | Frigidaire Side by Side Refrigerator 26...
The washer overfills. the front of the washer says" Frigidaire Heavy Duty 1-18 Automatic washer" when I start a load it doesnt stop filling. I can empty the water by turning the dial to spin but if I leave...
the most common problem is the pressure switch is bad and needs to be replaced.sometimes there is a reset on the switch.the switch can be acces from the back of the control panel and occasionally tapping on the switch can fix this problem but it is rare best thing to do is replaced the switch.good luck i hope this has helped with your problem.let me know how things work out
Jan 23, 2010 | Frigidaire Washing Machines
FL code constantly flashes, how do I reset?
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
May 23, 2009 | Kenmore Washing Machines
Shut off switch need to be reset on a ford f150 truck
F-150 or Expedition, Look at the passenger foot area and passenger kick panel.
Mar 02, 2009 | 2000 Ford Expedition
Where is my Oil Filter on my 2007 Hyundai Sonata
Hi, I'm not at all familiar with your vehicle, however I had a similar stressful experience with a Smart car. I looked everywhere for a cannister filter when it is in fact a paper insert. Try looking for possibly a largish black plastic domed top with a huge 24mmish sized bolt head on its top.
Ask your local parts supplier what type of filter is listed for your model?
Hope this helped? if yes please press the blue button for my FREE effort!
Paul 'W' U.K.
Jan 29, 2009 | 2007 Hyundai Sonata Limited Sedan
Flasher/2002 saturn l300
youturn signal flasher is part of the hazzard switch located in the center of the dash above the radio. the trim piece around the radio and the climate controls pops off using a small flat bladed scewdriver.
Jan 04, 2009 | 2002 Saturn L-Series
Maytag washer model # LAT8714A over fills
An overfill caused by a failed valve will occur even if the machine is unplugged. Trace amounts of debris from your plumbing etc or even a deterioration of valve parts themselves can cause it to pass water while off. This can be as slow as a drip but given time it will overflow. Water level switches are by necessity highly reliable parts and when they do fail they usually "fail safe" in other words not allow any current to the water valve. Overfills that are not due to a bad water inlet valve are usually traceable to a pinched, plugged or disconnected air hose. The location of the switch varies. Sometimes it's right behind the water level knob. On others like front loaders it's inside the machine, usually above the tub and at the end of a length of clear plastic tubing.
Jan 28, 2008 | Maytag PAV2300 Top Load Washer
WASHING MACHINE OVERFILLING
Suspecting the water level switch is the first step since this device controls starting operations. There is also a possiblity that the water level pressure hose has come off the tub. Make sure this plastic line is attached before replacing the level switch.
Jan 13, 2008 | Washing Machines
Kenmore 22422 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
