Question about Dell Photo 964 All-In-One InkJet Printer
Dell 964 All in one printer
I remove my SD flash card from my camera and install it in the SD flash card reader on the printer and it will not read it. Shows as if there is no card installed. Compact flash cards out of my other camera read on it. Dell says the reader is defective but they no longer supply them as they have been out of production for a year. This printer is two years old and seen very little use. Do you know where I might get a new reader for it or send it to be fixed? If it is too expensive I suppose it might be like many things these days and be disposable?
Thank you
Stephen Armstrong
sarmstrong@allsportinc.com
    Problem Solver:
  • 9 Answers
The cost of getting the reader repaired would far outweigh the cost of replacing the printer. Your best bet would be to get a card reader that can hook up to your computer and print it out like you would any document.
Posted on Feb 26, 2009
Camera is not recognized by pc
any card over 4gb will not be read by older computers. If you don't have a newer computer the SD card reader, avliable at walmrt under $10.00 will work.
Jan 24, 2014 | Nikon COOLPIX L810
Hp Photosmart 8150 can't read sdhc memory card
Unless the SD slot is specifically designated that it can read the new SDHC (Secure Digital High Capacity) memory card it will not read even though it plugs intop the standard SD slot.. I checked and this printer can't read the SDHC card only the standard SD card. You can buy a SDHC USB reader on ebay for a few dollars.
Nov 24, 2010 | HP Photosmart 8150 InkJet Printer
My computer is not recognizing my PNY SD 1GB memory card. I can still take pictures and my camera saves them to the memory card, but when I try to transfer the pictures to my computer, it does not...
In this instance, you might want to consider either borrowing, or, purchasing and card sd reader. Some computers just don't read these cards from their built-in slots, so, using an sd card reader often fixes the problem.
Hope this helps. :)
Oct 06, 2010 | PNY 1GB microSD Memory Card
SanDisk ULTRA II 8GB won't read when installed in a laptop. Works fine in the Digital camcorder. Trying to import the footage on to a Fujitsu tablet laptop (12 months old). Reads the standard 2Gb memory...
No, it's a hardware issue. Your 8GB card is an SDHC card (the HC stands for High Capacity), but the card reader in your machine is clearly only compatible with the older type SD cards. SDHC devices will accept SD cards, but devices designed solely for SD cards cannot read or format SDHC cards.
There is no firmware update for this, your only fix is to buy an external reader compatible with SDHC cards for connection via a USB socket. Most new readers are fully SDHC compliant, but check the specs for shelling out your hard-earned...
May 14, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
How do i upload images from my memory card through my printer to my computer? I've inserted it into the correct spot, I've selected upload to computer, it says its uploading is finished and directions to...
Another way is to purchase a USB memory card reader, then remove the memory card from the camera and insert it into the USB card reader. Then connect the USB card reader into the USB port of your computer, the computer will see it as an external memory card. You can view the contents of the memory card and copy the photo files to the computer.
Nov 08, 2009 | Dell Photo 964 All-In-One InkJet Printer
Dell e1505 SD card reader issue
You installed the driver for your card reader for the laptop. If its not recognizing any cards you put in there then that means the reader is bad and since that is integrated onto the motherboard, replacing the motherboard would be the only option in order to fix that problem.
May 04, 2009 | Dell Inspiron E1505 Notebook
2gb micro sd From Sandisk printer won't read.
From what info I have gathered is that my card reader on my printer is old and will not read that big of card. so off to the computer store to buy a new card reader.
Jan 19, 2009 | SanDisk 2GB microSD Memory Card
Sd memory card cannot be used
This happenes when you remove the card while read/write process is still going on. Try some professional service who will retive the data for you from the mem card. Hope this helps.
Dec 27, 2008 | Nikon Coolpix L11 Digital Camera
Camera not reading SD card after being removed from my reader
Put the SD card back into the card reader. Are you files still there when the computer tries to read them?
If they are not, then it is very likely the card is corrupt. This happens when the card is removed before the computer is done reading/writing to the card.
There is also a SLIM chance the card is just bad.
Nov 06, 2008 | SanDisk MobileMate SD+ 5-in-1 USB 2.0 Card...
Can not read SD card, game pad
You need to install your camera's drivers from the disk that came with it.
Unplug your camera from the computer >> insert the camera's driver CD >> install drivers >> restart the computer >> connect your camera via USB >> a windows pop up will let you know that it has found a new device. If you don't see the pop up this means your USB port is malfunctioning and it's normally from a malfunctionnig motherboard.
If you want to connect it through your card reader I'm affraid you need to buy a new card reader that supports 2G SD card. your current card reader does not supports 2G cards.
Kind Regards
Parkook
Oct 26, 2007 | Acer Aspire 5002WLMi Notebook
Dell Photo 964 All-In-One InkJet Printer Logo
90 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
