Question about Ryobi Factory Reconditioned 18" 40cc 2-Cycle Gas Powered Chain Saw #ZRRY10532
Chainsaw wont oil the chain and bar it is a poulan 2000 woodsman
The poulan chainsaw wont oil it is a 2000 woodsman no oil going to bar and chain
It's probably the oiler check valve located on the crankcase just in front of the clutch. You will probably need to remove the clutch and sprocket to get at it.
Posted on Mar 06, 2009
  • 3 Answers
Did you check the oil hole on the bar to see if it clogged?
Posted on Feb 27, 2009
What type of oil is used for my 2055 2.O CI woodsman chain saw?
This engine is certified to operate on unleaded gasoline.Before operation,gasoline must be mixed with a good quality synthetic
2-cycle air-cooled engine oil designed to be mixed at a ratio of 40:1.Poulan/Weed Eater brand synthetic oil is recommended.Mix
gasoline and oil at a ratio of40:1.A 40:1ratio is obtained by mixing 3.2 ounces of oil with 1 gallon of unleaded gasoline.
As far as bar and chain oil:
Genuine Poulan R bar and chain oil is recommended to protect your unit against excessive wear from heat and friction.Poulan R oil resists high temperature thinning.If Poulan R is not available,use a
good grade SAE30 oil. Never use waste oil for bar and chain lubrication.
Oct 20, 2014 | Garden
Poulan pro troubleshooting
CHAIN STRETCHS AS IT HEATS - KEEP CHAIN TIGHTENED CORRECTLY AND ALWAYS KEEP OIL IN OILER AND MAKE SURE IT OILS THE CHAIN. IF THIS DOESN'T FIX - REPLACE THE CHAIN. IF IT STILL HAPPENS THEN REPLACE BAR. WILL FAIL AGAIN WITHOUT OIL. POULAN WILL NOT HOLD UP WITHOUT CHAIN LUBRICATION. WORSE THAN OTHERS. IF CHAIN OR BAR OVERHEATED YOU'LL WORK ON IT MORE THAN YOU CUT. OIL IS THE KEY TO CUT WITH A POULAN!
Aug 10, 2014 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
What oil do we put into the poulan 3.0 peak hp
I assume you are referring to the Bar/Chain oil?
That would be Almost any Available brand chainsaw Bar and Chain oil, If that is not available you can use New uncontaminated SAE 30 motor oil.
May 15, 2014 | Poulan 16Inch 30 HP Electric Chain Saw...
I need a manual for a new Poulan 3.5 electric chainsaw, or, failing that, I need instructions on what kind of oil to use on it, and whether I need separate oil for the chain.
You shouldn't need any other oil than the oil to keep the chain and bar guide oiled (pressing down on the button adds more oil to the chain/bar). You can use standard Bar and Chain Oil, or probably pay a little more and use the Poulan brand oil, but in my experience, any bar oil for chainsaws will work, and the larger the container you buy, the less per ounce you will pay. Remember this is NOT an automatic oiling system, so it will be cheaper in the long run to remember to press that button than to replace the chain/saw if it overheats.
Aug 29, 2011 | Poulan 14" Electric Chainsaw
Chainsaw starts but chain doesn't move
Probable very oily clutch internals. Remove the bar and chain, then spray the clutch internals with spray carburetor cleaner, let dry and reassemble bar and chain. Hope this helps!
Jul 03, 2010 | Poulan 14" Chainsaw
Poulan 2 cycle gas chainsaw 18 inch. Was real
no bar oil should just hurt your chain and bar. remove them and try to start saw. if it still won't start you have other problems you may have to buy a new bar and chain
Feb 02, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a poulan wild thing 18" bar and I have had a problem with the bars wearing out quickly. I use regular poulan bar and chain oil. Did this saw have a specific problem with the oiling system?
If the oil level in the chain oil tank goes down normally then you may be running the chain too tight. Also make sure the oil ports in the bar are clear so the oil can get to the chain. hope this helps you
Nov 03, 2009 | Poulan Pro Chain Saw 46cc 20"
Bar wont oil
ok the port the oil flos thru is most likely clogged. drain oil pull bar cover off put an airhose in the oil tank and cover around the hose so air cant escape and blow it out it should unstop
Sep 18, 2009 | Poulan PP4218AV 18" Chain Saw
I am trying to put the chain on my poulan saw and the teeth wont go in the groove on the bar
the chain on these saws will only go in one direction ~ when you re-move the sheild to fit the chain a small diagram will be shown to what direction is required.
if this is not the problem and the teeth won't fit any where on bar then check for damage to bar or dirt stuck in it.clean out with soapy water and use spay oil to prevent rust.
Aug 07, 2009 | Poulan Pro Chain Saw 46cc 20"
No oil for the chain
you can take the bar off and use a wire clothes hanger to clean out the holes behind the cover
Jul 12, 2009 | Poulan PP4218AV 18" Chain Saw
Ryobi Factory Reconditioned 18" 40cc 2-Cycle Gas Powered Chain Saw #ZRRY10532 Logo
1,006 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
