Question about Frigidaire Refrigerators
Ice maker on frigidaire not working, changed filter still nothing. Model is PHSC39EESS5.
  • 3 Answers
How cold is the freezer?
Posted on Feb 27, 2009
How to get ice maker to work after changing water filter?
Tell me the model number but most Frigidaire licenses can be advanced by pulling the cover off the front you'll see a gear that has a rotation arrow on it turn it about a half turn it should start the cycle
Apr 06, 2016 | Frigidaire Refrigerators
It making a noise and the ice maker stop working
Thank you for your inquiry, Joann siefert!
I see that your Frigidaire refrigerator is making noises and no longer producing ice. Have you attempted to replace your water filter? If your filter is bad that could cause ice to stop producing. I would recommend changing your water filter to see if that would help correct your issue. The noise could be a normal operating noise. If you have your manual you can look inside for normal operating noises. If you need your manual could you please provide me with your model number? You can locate the serial tag (which lists your model number) on the inside wall of your refrigerator. With that information I can further assist you. -Matt
Jan 23, 2015 | Frigidaire Refrigerators
Does the refrigerator filter filter the ice maker too
Hey friend, that's a great question!
For our Frigidaire refrigerators the water filter does in fact filter the ice maker too. The water enters your refrigerator from the water valve and then goes into your filter. It is then distributed between your ice maker and water tank. Hope this information has been helpful. -Matt
Jul 26, 2014 | Frigidaire Refrigerators
Frigidaire Gallery French Door Refrigerator ice maker not making ice
You can search with your model number to see if a filter is available or not. Secondly unless the ice maker was damaged for sure it's likely that the fan is not running in that compartment or air is leaking into the refrigerator and making the ice maker think its not cold enough to make ice.
Apr 13, 2013 | Frigidaire Gallery 25.8 Cu. Ft. French...
Changing ice maker for fridadire part # FrS26zrg
Can you add water to the ice maker from tap water, Allow the water to freeze and if the ice maker drops the ice into the ice bin and then does not refill with water will point to your as the problem=> 218658000 Water Inlet Valve
If the ice maker sits there with ice and does nothing the problem will be the ice maker=> 5303918277 Ice Maker Assembly
I will be here should you have questions, Thanks Sea Breeze
Dec 08, 2012 | Frigidaire FRS26ZSG
Ice maker not working
pour water in your ice maker. when it dumps ice cubes, keep filling it up again.after 5 or 6 times it should start working on its own
Oct 21, 2012 | Frigidaire Refrigerators
Not making ice
Hi: Change or just remove the water filter first. As your water dispensing slowed that is a clue. If the water filter is that clogged it will cause a problem with the ice maker. Plus the water you drink is not filtered anymore. City water is being run through 2 years of crud. If you don't replace it just remove it. I hope this helps, Jeff
Jun 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
10 yr old Frigidaire ice maker stopped making ice
check to make sure the fill tube is not plugged with ice if it is not then i would guess the valve is shot
Oct 30, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
269 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
