Question about Maytag Washing Machines
I have a model a211 Maytag top loader. I have a replacement belt kit. What are the two springs and 4 nylon washers included for and how are they installed
    Sergeant:
  • 326 Answers
  • 13,433 Answers
I would suggest getting a repair or a service manual, didn't they come with documents?
Posted on Feb 26, 2009
Maytag washeing machine, Below belts, are they available in Saudi arabia
The belts in a Maytag washer
www.do-it-yourself-washing-machine-and-dryer-repair-help.com/belts-...
To check and replace the belts in your Maytag washer do the following ... With RepairClinic's 365 Days return policy you could try any parts, if the new part ... Belt Kit - Part # 402507 Mfg Part # 12112425 · Motor Mount Spring Kit - Part ... Copyrighted 2011 Do-it-yourself-washing-machine-and-dryer-repair-help.com All rights ...
Sep 13, 2015 | Maytag Washing Machines
Can't find where the clutch goes on a Maytag Performa PAV 3300, is it in the transmission?
This washer is a single belt driven model that uses a thrust washer system to release the brake when the motor reverses. In wash mode a 200# spring locks the tub place while the transmission agitates the clothes. The pump cannot remove the water in this direction. In spin mode the the brake is released and the water gets pumped out. Here is a great pictorial that shows how to replace the kit along with a Maytag single belt washer service manual.
Oct 08, 2011 | Maytag PAV2300 Top Load Washer
I hear the belt floping around in my front loader washier,how do i fix it??
Get the service panel off. Then remove 4 large bolts and the washer motor and pump will come out. Put that on a work table and remove the pump.
Service Manual Amana/Speed Queen/Maytag washer
Jul 29, 2010 | Maytag SAV5710 Top Load Washer
I have the MAYTAG top loader washer, Model #MAV6451AWW, it will not spin in the rinse cycle, how to fix / take apart?
Usually when this unit washes but will not spin the thrust bearing kit is damaged.This is easy to repair with little cost.
Completly empty the unit, clothes and water ,unplug the power cord, lie the unit on its back, remove the belt,the c clip from the pully. Take the thrust bearing,the pully the washers off the unit . Grease the new bearing and install new parts. I would also replaced the belt.
Feb 06, 2010 | Washing Machines
Grease blobs appear in wash, Maytag washer A211. How do I fix?
Searched for the model on the web and didn't find it. I am assuming that it is an older top load model. Front loaders I don't know about.
Is the grease appearing just in the drum or is there some on the floor underneath. Either way I would say you need to replace the transmission. If you have an old 12-15 yrs washer I would get a new one. The replacement trannys only last a couple of years at best and aren't worth the money to replace $200-300 if your machine is ready to **** out. The only places on a washer that have grease are the clothes you're washing and the transmission. The tranny will mostly leak onto the floor but can sometimes get into the drum.
Dec 30, 2009 | Maytag Washing Machines
I have a maytag top loader washer and when it is on the spin cycle the whole drum shakes hitting the walls of the washer
Without having the model number, it is difficult to diagnose.
Most Maytag / Whirlpool top loaders use a set of balance springs and friction pads to buffer the shaking.
Here is a Whirlpool site with a number of PDF files on their products including troubleshooting sections.
Find your washer under laundry products and open the PDF, it will probably take a few minutes to load.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6?OpenView&Start=1
Sep 27, 2009 | Washing Machines
Put dryer belt on maytag dryer
generic maytag dryer belt replacement
type 1:older models by Maytag with lintscreen under door
  • unplug dryer
  • remove 2 screws from under front panel
  • tilt front panel up from the bottom and unclip top
  • remove door switch wires
  • set front panel aside
  • remove front drum retainer 2 screws each side
type 2:newer models by whirlpool lint screen in top cover
  • unplug dryer
  • remove lint screen
  • remove 2 screws under lint screen
  • with putty knife or other blunt blade
    unclip spring clips at front corners of top panel
  • remove 1 screw each side of front panel 1/2 way from top
  • remopve door switch wires
  • tilt front panel down and unclip
all
  • withdraw drum forward
  • examine drum rollers for wear
    if worn or locked replace in pairs
  • examine felts and nylon glides(if fitted) for wear
    if worn replace
  • examin case floor for tensioner
    (sometimes broken belt ends pull the tensioner out of place its easy to see the slots on the case floor for the 2 feet and spring, looks like a power socket)
  • loop new belt around drum at wear mark of old belt
  • insert drum
  • loop belt around motor pulley
  • pull tensioner to end of travel against spring
  • loop belt around tensioner
  • relax tensioner
  • rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
Oct 29, 2008 | Maytag Dryers
I have Maytag Model#PAV1000AWW which is a Top Loader.At this time the washer makes sounds in the spin cycle,but does not spin or drain the water.HELP!!!!!
  • it sounds like it could be a bad belt. tilt the machine over and look at the very bottom, you will see the belts. they are spring loaded and can be changed without any tools.
  • or you may need a transmission pulley and bearing repair kit ($30). this will fix the center pulley (spinning problem, not he draining issue) if it is stripped out. as you will see, the center pulley is made of plastic and does have frequent problems. but the good thing is that the parts are cheap and easy to change.
Jul 01, 2008 | Maytag Washing Machines
Maytag top loader washer
The brakes are probably stuck or the cam that releases them is damaged
Sep 27, 2007 | Washing Machines
Maytag Pav2300 top loader balance problem
bigmur, you need the snubber kit for this washer. There was a service flash out on this model, SF-26-756. The kit includes the snubber and 6 new springs. Condition was, excessive vibration during spin, basket leans to one side. Kit number, 12002357. Check with your retailer...this repair may be covered. Catriver..post back
Sep 25, 2006 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
52 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
