Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
My return vent keeps freezing up in my side by side whirlpool gold refrigerator and the refrigerator does not stay cold. What can I do to get it to quit freezing up.
  • 2 more comments
  • kids3_husban Feb 28, 2009
    Whirlpool Gold Model #GD5RHAXSS01 manufactured 6/06
  • bcagno Mar 19, 2009
    I did the hair dryer thing and it worked for 1 week and now it has frozen up again. What is causing it and how do I get it to defrost? Is there a defrost timer that I can reset or replace?
  • Anonymous Apr 27, 2009
    we did as suggested, removed frosts from the coils. ran ok for a few days and now vents are freezing again with fridge compartment not as cold as it should be. whirlpool model 106.57022601
  • antoniobande Apr 28, 2009
    MY EVERY 4 MONTHS STOP FREEZING,THE VENTS ARE STUCK AND LOST MY FOOD
    Novelist:
  • 117 Answers
Got a brand and Model number so we can see your machine as you do? Eric Campion
Posted on Feb 27, 2009
  • Affordable Appliance Parts
    Thanks for the model number....For testing purpose, set both controls to the middle setting and leave them there regardless of the temperature fluctuation. The return vent normally freezes up when there is an airflow problem. This could be the ice door flapper in the fountain assembly not closing all the way or a door left open just a tad overnight. What we want to do is grab a hair dryer and then blow air into the vent until you feel air coming out of the other end of the vent. To do this, you will have to unplug the unit, remove the food from the freezer section and then remove the rear inside panel. Take a look at the coils behind the panel and tell me if they are really frosted front to back..top to bottom. Once you have all the frost removed, reassemble and leave the controls in the middle settings. Wait 24 hours and then let me know how things are.....Eric Campion
Can you tell me why please?
All the big cooling happens inside freezer compartment. Freezer gives little cool air to fridge compartment. Now when the vent blocks that little cold air cannot go into fridge compartment. Thus your freezer works good but not fridge compartment. Milk goes bad but frozen meet keeps good.....
Vent freeze up either due to defrost problemt, defrost drain line problem, Evaporator fan problem or even can be your damper motor not opening due to unit failure or frozen damper door.
Sep 19, 2014 | Whirlpool GX2FHDXVY Gold Stainless Steel...
Whirlpool freezer on top is cold but not freezing everything in freezer. i want to reset the unit but i don't know where the rest switch is. how do i find it or what can i do.
open ref. door look up two knobs one numbers one letters.. set the number higher makes comp. run longer and should freeze everything. the letters is a vent the higher the letter more cold air stays in freezer. ok
Feb 13, 2011 | Whirlpool GS5SHAXN Side by Side...
Whirlpool gold gd5rhaxnq00
Couple of reasons
a) Excess humidity in the refrigerator due uncovered food items.
B) freezer door not closing fully( look for any visible damage or hardness of the seal. The seal is made of multiple layers so even a few cracked edges will cause leakage.
c) the returning air if not circulated properly by blower which also gas a heating coil for humidification could have failed causing formation of ice.................sodeep
May 17, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Hollow ice cubes and refrigerator freezer drip pan is freezing
The drain at the bottom of the evaporator on the freezer rear wall is blocked up. Ice may have gotten so far up the side of the evaporator that it is blocking a return air duct which is located there. You need to completely deice the freezer and then **** out and purge the drain hole on the bottom of the evapotrator with hot water and a turkey baster.
Apr 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirpool gold
I did some research online, and read that the Start Relay is most commonly the problem. My husband bought the part, (about $50) and reattached it to the side of the compressor....and was cold immediately! apparently a very common problem on these fridges.
Jan 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Vegetable draw is freezing the vegetables
if you pull out the vegetable drawer, you will notice a vent on the left side in the back. get some tape ( I use aluminum tape ) and cover the bottom half of the vent, that will help keep your vegetables from freezing. that should solve your problem. Joe
Dec 12, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold conquest refridgerator
if u find out let me know. when we turn both frig/freez switches off the frig light comes back on flashes to number 6. it still seems cold be like this 2-3 days the food still seems cold. good luck. jax, fl
Mar 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
1,358 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
