Question about Lexmark X3480 All-In-One Printer
X3480 printer message says;cover is open
X3480 printer massage say;cover is open.id tried to tap all the sides but its still the same problem
  • Erik Anthonsen
    Erik Anthonsen May 11, 2010
    make sure paper is not blocking the door sensor!
  • 80 Answers
Seems to me a peice of paper is blocking sensor examine all parts of printer thourly!
Posted on Feb 26, 2009
After changing cartridge the message "cover open"
raise the cover and see if u can see a switch of some kind puss it down and see if it will print or restart ur computer and see what happens
Jan 23, 2011 | Lexmark X3480 All-In-One Printer
Message says lid is open when it is closed
Please try out the blow mentioned 2 options. I am sure the problem will be sorted out:
  1. When you lift the cover up along the back end of the gray plastic bottom cover, you'll see a square opening close to the right side hinge.
    There should be a little white plastic piece sticking out of there. If not, it fell into the guts of the printer. You have to remove the gray plastic and find the white lever and replace it onto a micro-switch along the back where the square opening is/was.
    You'll see a PCB (printed circuit board) there and the micro-switch will be located on that...
Hope this helps
2. Remove the screws on the front of the cover when it is open. Once removed At the back of the unit 2/3 rd from the left there is a small switch if this is pushed in ( and held by whatever means sellotape etc it will opperate normally (to change cartridge you may have to re do)
Sep 10, 2009 | Lexmark X3480 All-In-One Printer
Printer says the cover is open none of the funcutions work.
Hello sir;I'm not sure this model is there have rear side door if do have close it if don't have, then check the door actuator isn't broken, either on the side of cover or on cover hinge.
May 09, 2009 | Lexmark X3480 All-In-One Printer
X3480 printer.message is saying;cover is open
the meaning of cover is open means --------the cover means.the thing which you lift to remove or install the cartridges.just keep that cover closed.if that cover is closed still its showing the same error.then the sensor which detects the cover closed is got moved from its orignal position.to reset the sensor just tap all the sides of the printer for couple of minutes.mostly the top side and front side of the printer.and then check out the error must go away.if still the same error then its quite possible that sensor is broked as it very very delicate .so it needs a technician to replace the broken sensor.the cost to replace the sensor must not exceed then $5.
Feb 26, 2009 | Lexmark X3480 All-In-One Printer
Lexmark x3480
This is the problem the cover switch in the printer you need to replace the switch this switch is very difficult to find in the printer is usually hidden ,you need to check the cover there will be a projection in the cover which will go into a slot thats where the switch is located
Sep 24, 2008 | Lexmark X3480 All-In-One Printer
"cover open" messagge when cover is closed
Sep 16, 2008 | Lexmark X3480 All-In-One Printer
Cover open message
Jul 20, 2008 | Lexmark X3480 All-In-One Printer
Lexmark 3480 cover open
Hi I have 30+ printers and each differs but sorry I do not have your printer. But generally you will find a corresponding female recess somewhere around where the lid closes on the main frame of the printer.
Hope it helps
Tinteiros (Ebay)
Jun 02, 2008 | Lexmark X3480 All-In-One Printer
Cover open error
There is a latch that preses a small switch when you close the cover (look for this) to indicate that it it close if it is broken you can tweek it using a toothpick or anything that may press the switch temporarily this may alow it to work as long as the switch stays down.
May 28, 2008 | Lexmark X3480 All-In-One Printer
X3480 cover open message
Ajkill is right, although his description isn`t very exact. Take off the complete scanner part: (back hinges first, then the blue arresting lever at the front), disconnect the flat band cable and the power supply for the scanner part and take off the complete scanner part. You´ll see a triangular part that goes in a slot of the dark grey cover which covers the rest. It should press againt a white lever which itself presses a little black switch sitting on the printed circuit board. If this white lever has fallen off the switch is always in "Cover open" position. To get it and reposition it (if it isn`t broken) you have to take off the dark grey cover which covers all the rest: take off the front screws and carefully lever out the sides with a small screw driver. Good luck with the repositioning, it is very fiddely and to see how and where it has to go you best use a magnifying glass!  But I could manage it and my printer is working now again. And good luck with fitting it all together again without breaking anything!
Mar 19, 2008 | Lexmark X3480 All-In-One Printer
Lexmark X3480 All-In-One Printer Logo
102 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
