Question about Cuisinart Grind and Brew, 10 cup, black
I have a cuisinart Grind and Brew with a glass carafe - not pictured above. The self clean button keeps lighting up and I don't know how to run the clean cycle.
  • 8,596 Answers
Fill the water reservoir with 2 cups distilled white vinegar and 2 cups water - then press the self-clean button. If the water doesn't start going through after a minute or two, just turn the machine on like you were brewing coffee. After the vinegar/water soultion has gone through the machine, brew one cycle of plain water to flush out the vinegar. If the self-clean light stays on, just unplug the machine for longer than 20 minutes, and the light should not come back on when you replug the machine. Good luck!
-Tha Mp3 Doctor
Posted on Feb 27, 2009
Clean light stays on,help me trouble shoot
Fill water reservoir with 1/3 carafe distilled white vinegar, 2/3 carafe water and hit the self-clean button - it will take about 35 mins to complete. When it is done, it will beep like it normally does when brewing regular coffee. Self-clean light should go off after this. If it doesn't, simply unplug the machine for 20 minutes or longer. The manual is available for your inspection on the Cuisinart website.
If your Cuisinart is one that is missing the Self-Clean function, just brew the vinegar and water like it is coffee by using the brew function.
Sep 19, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Not brewing. Add water and coffee, switch to the brew selection and the water/coffee does not flow. The machine heat ups and starts processing noise.
Make sure the lid is on the carafe.
Make sure you are not using a paper filter and a gold tone filter at the same time.
Make sure the carafe lid is down all the way and that the center knob of the carafe lid is making contact with the spring at the bottom of the filter basket.
If the above conditions have been met, then decalcify your coffeemaker by running 1/3 carafe worth of vinegar and 2/3 carafe worth of water through your coffeemaker - use the self-clean button to do this - will take about 35 minutes.
Aug 30, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Slow to brew
Aug 23, 2009 | Cuisinart DCC-1200 Coffee Maker
Coffee pot.
Aug 23, 2009 | Cuisinart Coffeemakers
Cuisinart Grind and Brew will not emply all the water
The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Aug 18, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart burr grind and brew coffee maker
The hopper between the burr grinder and where coffee chutes into the filter is jammed with coffee powder...
First, take out the filter holder and carafe, and place a freash empty filter on the pot base to catch stuff.
Next, take out the beans holder and look for the release lever in the lower left section. Sliding it to the left slides open the door, where you'll probably find loads of powder. You can poke your finger through to get the majority, then use the cleaning brush to get it really clean.
Thanks what fixed mine! (I notice I have to do this about once every few months.)
Sep 09, 2008 | Cuisinart Supreme Grind DBM-8 Electric...
Keeps flashing 12:00
I just kept plugging and unplugging the coffee pot. Eventually, the clock stopped blinking, the buttons worked, and all was well.
Jul 19, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Leaking cuisinart grind and brew
Our Cuisinart grind and brew was leaving a puddle under it after making a pot of coffee. I called Cuisinart this week and it turns out the handle of the carafe has to be lined up in the middle of the opening for the carafe. It will be under the word Cuisinart, in the middle.
We have now made several pots with NO residual puddle of water or coffee. It also seems to be making the pots quicker.
Before trying this I had run 2 pots of water with 1/2 cup white vinegar in it also. But it still puddled until we lined up the carafe as noted above.
Nov 30, 2007 | Cuisinart Coffeemakers
Cuisinart Grind and Brew, 10 cup, black Logo
164 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
