Question about Polycom Viewstation FX H.323
Mute Button on Mike
The Mike just stays in the mute and will not turn on. I have checked the wiring and it is a straight wire map and is correct. I took the mikes and connected to another unit and they work fine, How can I fix this problem? I haven't opened the unit up yet. Any help is greatly appreciated.
Thank You in advance
  • euthenics Feb 27, 2009
    Thanx for telling me what I already know. I am looking for technical assistance in fixing this problem. Thanx
    The mikes are only stay muted on the unit I am having the problem with. I tried the mikes on another unit to see if it was the mikes. The mikes work fine on another unit. So it is something with the unit and not the mikes. Do you know if resetting the unit to the factory defaults have anything to do with it?
  • 80 Answers
Its your unit is defective if you took a mic that doent work in yours on another unit just like yours and it works then its definatly your unit defective!
Posted on Feb 26, 2009
  • Erik Anthonsen
    Erik Anthonsen Feb 27, 2009
    sorry i didnt mean to mark as solutions i was asking a follow up i need to know did you try you mic on the exact same unit as the one you have sorry for the confusion!
Mute button on probook 6450b
sounds to me like the indicator light is stuck in the on could be something touching the wires and causing a bad connections
Nov 06, 2013 | HEWLETT-PACKARD ProBook 6450b Notebook
On a audiovox vm9312 I lost remote and can't turn
The VM9312 has a volume knob on the unit's faceplate. Just rotate the knob on the left (a little below the optical disc D slot) clockwise to increase the volume. Turn it the opposite way to lower the volume. (If you have the knob set to the maximum volume and then lowered the volume with the remote, you may need to reset the unit; see below.) If you push in and release on this button, you press Enter or confirm a setting when you are in any audio settings menu.
If the volume control isn't working, check if the mute is on. Press once to toggle the Mute. The mute button is just below and near the right side of the optical drive slot.
If you still can't change the volume, check if you have the wiring correct and no shorted wires. Look for damage at the speakers (or evidence of mice chewing on the wires). Also check your audio balance. See the manual page 12 here: . You may also want to try a system reset. (Press and hold the reset button for a few seconds by using the tip of a ballpoint pen in the little opening at the lower right hand side of the faceplate.)
I hope this helps.
May 24, 2013 | Car Audio & Video
My jvc kw-av60bt is stuck on telephone and av wont work
I know the correct answer! mmm just disconnect the brown mute wires on the wire harness if you read the brown wire it will say mute! that wire is for cars that have an integrated telephone so if you car doesn't have an integrated telephone then just disconnect the brown wires (mute) and tape them off and Voila! Walla! the Double din will work , I hope this helps!
Aug 18, 2012 | JVC KW-AV60BT
Corner of the radio is flashing ATT
ATT is like a mute option, hit mute or ATT button to return to normal operation.
May 15, 2012 | Kenwood KDCX895
1996 Ford Explorer factory Radio works but when i install the aftermarket radio no sound comes out from it what do i do ..??
Does it light up? Does it have a mute button? Does it have a mute wire for in vehicle phone systems? If so, it may need to be grounded to take it out of mute, or it may need to go to 12 volts + It depends on how the circuit was designed.
If those check out, or it lights up but no muting make sure the speakers are connected to the correct wires. Also check to make sure the speakers are not grounded. Two wires should go to each speaker. you can check the condition of the speakers with a 9 volt battery touched across the leads, you will hear a pop sound. make sure those two wires for each speaker are connected to the radio correctly.
Jan 23, 2012 | 1996 Ford Explorer
I have an audi a3 2005 but my CK3100 wont mute when taking calls??
Has your 3100 ever worked correctly since being installed? Can you give me more information about how it was installed (professionally or by your self)? Often times when these are installed the mute wires get connected (Mute 1, 2, and 3). These are unnecessary and will often cause problems because many stock radios don't have a dedicated mute wire. If you are able to get to the wiring disconnect and tape up the mute wires. Did that solve the problem? If not and if this also came on after a time where the Parrot worked correctly, it could be the blue box or the mute cable (the one with the wires that go to and from all the speakers with the black box on it) have gone bad. I've installed many of these without issues. I've also had to replace brand new ones after people installed them and connected the mute1, 2 or 3 wires. If those mute wires are connected to the wrong wire in the vehicle it can allow current to flow into the device causing it to damage itself damaging itself.
Let me know if this has been helpful
Mar 01, 2011 | Parrot SA Parrot Ck3100 Lcd Handsfree...
As I'm driving the volume will decrease and the screen at the bottom right would say att. What can I do?
Att is the quite mode, Press the volume button down it will turn off att Mode, That is for when your on phone or something, Then you can mute it kind of.
Aug 14, 2010 | Pioneer AVIC-Z2 Car DVD Player
How do i make my pioneer super tuner 3d 2 unmute? if i try 2 turn the volume up it just keeps sayin mute and i havent been able 2 find a mute button on it any where?
My Pioneer Super Tuner 3 D was working just fine. The face plate was removed by accident while it was operating. Once it was reinstalled the displays all still work but there is no audio any longer.
Sep 25, 2009 | Pioneer Car Audio & Video
How to mute my Uniden phone
You have to use the menu on the handset. Press Menu/Clear, then Mute, then push the Select button. Repeat the same to turn mute off.
Mar 31, 2008 | Lands Phones
Stuck mute
I had the same problem. Deatache the mute wire. That is for cell phones. I think it is the brown wire but I cant be sure. Look over the wiring diagram and it will say Mute. Don't wire this wire in.
Feb 06, 2008 | Jensen VM9510 Car DVD Player
Lands Phones Logo
176 people viewed this question
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
David Burbee
David Burbee
Shehu Pro
Shehu Pro
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
