Question about Kenwood KAC-9102D Car Audio Amplifier
Amp powers on no sound out of sub tested sub on sterio and it works tested rcas fine
  • Erik Anthonsen
    Erik Anthonsen May 11, 2010
    Check the ohm's or resistance on the speakes to make sure they match what you want to ensure the speakers arent blown !
  • 80 Answers
Test ohms on speakers with volt meter and make sure they match what you bought! subs are blown!
Posted on Feb 26, 2009
Power to amp no sound
Test your subs on another amp....If they are fine then try running different rcas in your car from the stereo to see if they are the culprit. If still no sound probably your output on your amp is gone.
Mar 04, 2012 | Alpine MRP-F300 Car Audio Amplifier
The one terminal on my volfenhag 1000wat amp does not work what could be the problem
It sounds like your amp has lost a channel, based on the testing you have done so far.
Feb 14, 2012 | Volfenhag ZX-8200 Car Audio Amplifier
Everything is hooked up fine. the amp has power but no sound. I opened the amp and nothing looks burnt out.
Try you sub(s) on another amp...if they play off of it then its either your speaker outputs off of the amp or your rcas or wire from your radio are bad.
Nov 15, 2010 | JVC KS-AR7501D Car Amp
Amp has no sound?
Yeah, u are probably right. If u are good enough with electronics it is a pretty easy fix
Feb 07, 2010 | Power Acoustik OVN1-4000D Car Amp
Ok I just bought a used fosgate amp belive its a T10001b could be wrong its big has fan 3 led lights and some pioneer premier 10 flat subs think there 4ohm. I bought a brand new amp install kit 6gauge...
eyp, most of the time speaker connections blow and fuses wont stop that from happening. They are there to stop the mainboard from frying and not working at all. try running rca splitters to the operational side of the amp. run the sub on 1 channel. you will start hearing a difference but both sides will work. if not, run the splitters from the head unit and bridging it. these are the cheapest solution i could provide
Jul 27, 2009 | Rockford Fosgate Punch P5002 Car Audio...
4 subs and two amps
I'm not that familiar with the insignia line but If the amps have an "input" and an "output" for the RCAs then run the RCAs in one, Then hook the output of that one to the input of the other. I did this with my 2 memphis 500Ds and it worked great. It also looks better than a couple of splitters, but yes You would just get two splitters with all female connections on them so you can plug 2 sets of RCAs into the one set. Also it doesn't really matter how you hook the RCAs up unless you are going for stereo sound then you would need to make sure the rights are hooked up together and the lefts are hooked up together. I hope I could help.
-Andrew Hawkins
Jul 22, 2008 | Car Audio & Video
SUBS
Hi , you need to replace with thick wire , if possible attache fuse or circuit trip overload protection you may ask to thew radio store .
May 07, 2008 | Polk Audio EX12 Car Speaker
Kenwood KAC-9102D Car Audio Amplifier Logo
99 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
