Question about Cannon Canon i960 Photo Printer
I get error 5100 & cannot print at all
I've tried turning on & off, also tried tech support, but nothing yet works.
Any suggestions.
thanks, tom
  • 412 Answers
This helps you --
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 09, 2009
Hello, I bought a printer a few months ago but it doesn't seem to work. I've installed the proper drivers but every time I try printing sth a got a message ''Service error 5100, cancel printing and then...
Hello.
I could make several suggestion to "fix" the problem, such as clean the timing strip, etc., but since your printer is still under warranty, I'd suggest contacting Canon for a repair / replacement due to a potential hardware problem. You shouldn't be getting a "Service error 5100" after a few months.
Hope this helps.
Nov 24, 2009 | Canon Pixma iP4500 InkJet Printer
Printer canon1700 shown message ''service 5100 error''
Call your dealer or servicing agent. The device has a hardware problem that needs to be addressed by a trained service tech.
May 05, 2009 | Canon Office Equipment & Supplies
Canon IP4000 Error Code 5100
It is a carriage error.
Most times this is a serious error that requires a Canon tech to fix it.
Look at the carriage and see if there is something obstructing it's movement. If you recently had a paper jam, there may be some paper stuck in the path.
You should be able to move the carriage freely with the power off.
Let me know.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 20, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
SERVICE ERROR 5100
please suggest me service error 5100, when i start to print it appear service error 5100. what happen ?
Jul 05, 2008 | Canon PIXMA iP1600 Printer
I850 printer error message 5100
GO ONLINE AND TYPE IN
CANON 850i PRINTER ERROR MESSAGE 5100
ENTER
ROD
Jun 19, 2008 | Canon i850 InkJet Photo Printer
CANON PIXMA IP1200 resetting
My converted iP1200 is currently blinking green, yellow, green, yellow on the power lights after start up and print request. The pop-up prompt suggests turning off the printer and turning it back on. Error 5100 is always seen.
Please Help Me...
rakibfuture
Mar 30, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Service error 5100. Cancel printing and Press OK button. If this doesn't clear the error, see the printer manual for more detail.
Had a same problem, here is what i ve received from canon support:
"Dear Customer,
Thank you for your recent enquiry regarding your Canon product.
Please be advised that error 5100 indicates a carriage error and the machine will require service."
However I managed to solve it by myself by perform few paper path tests as there was a paper jam inside.
Nov 20, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Canon ip2000 service error 5100
I have been facing same error and this was the solution.
Canon Error 5100
Sep 08, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Cannon Canon i960 Photo Printer Logo
108 people viewed this question
Top Cannon Office Equipment & Supplies Experts
Cosma Papouis
Cosma Papouis
Victorman
Victorman
Greg Cann
Greg Cann
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
