Question about Kenmore 24032\24036 Top Load Washer
Need instructions on replaceing drive belt on kenmore top load model 72981800 ser #c840065
    President:
  • 2,976 Answers
First-DISCONNECT THE ELECTRIC
From the rear of the machine, take off the back. Remove the old belt any way you can. A tin snips works well. Next, put the new belt through the tensioner and then feed it onto the motor. Next, feed the belt around the main transmission pulley. It's the largest so it will be the easiest to get to stay in place. When it gets real tight, a little more than 1/2 way on, turn the basket to feed it on the rest of the way. If you got it through the tensioner in the right direction, it will be very tight. If it's loose, remove it and put it through the tensioner the other direction.
Posted on Feb 27, 2009
On final spin my Kenmore front load washer does not increase speed just before end of cycle resulting in wash that is damper than it should be. Thank you
This is caused by the clutch being worn in these newer direct drive washers. Order a complete clutch assembly from an online store for that make and model and you will receive instructions with it. Get some tools and Fix it yourself. You can get case removal instructions by typing the question "How to remove the case of..........".Really, there's nothing hard or heavy in the procedures.
May 02, 2017 | Kenmore Washing Machines
Replace kenmore dryer drive belt
Go to www.repairclinic.com and enter 110.76902693. Be sure to enter the model exactly as I have shown. You will be presented with a list of common replacement parts and may be able to view a generic Sears video showing disassembly with identification of major parts.
Dec 07, 2016 | Kenmore Dryers
Instructions on how to install a belt on a kenmore top load washing machine model #: 110.24622300
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Next, see the following illustrated description of how to replace a belt on top load washers:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=144&osCsid=2d35143b9424efb2825c26899392c2e1
Sep 08, 2010 | Kenmore 22422 Top Load Washer
Belt is loose or needs replaced. on a 70 series kenmore washer machine
Can you provide the exact Make, Model and Kenmore model number? ..........
Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines.........
The model number on top load washers is usually found by lifting the lid and looking above the tub.
The Fixya numbers are Stock Numbers.
Since basic top load direct drive, top load electronic and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem.
Slipping on direct drive washers is usually caused by a damaged / broken Motor Coupler or clutch.
If yours is a direct drive machine, see the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135&osCsid=5666a1d539401da8aec3c1514f2bc0f9
Jul 09, 2010 | Kenmore 24032\24036 Top Load Washer
What all do I have to take off to get to the belt on bottom of washer, because my washer will not spin?
Motor/Carbon Brushes
If the washine machine motor runs, but refuses to go into spin mode, a good possibility is that the carbon brushes have worn
Mar 09, 2010 | Kenmore 22422 Top Load Washer
Why won't the Kenmore top loading washing machine agitate?
There are two types of Kenmore top loading washing machines. The direct drive models and the belt drive models. Direct drive models do not have a back access panel and the water inlet valve is located on the left side viewed from the rear while belt drive models do have back access panel and the water inlet valve is located on the right side viewed from the rear.
The most common problem causing a top loading machine not to agitate, particularly when the motor seems running, is a broken motor coupler for direct drive models and a broken or worn out drive belt for belt drive models.
The best way to exactly determine the cause is to access the drive motor. Open the back access panel for belt drive models and check the drive belt. Check the drive motor if it is running, humming or stuck.
Please indicate the model number of the washing machine if it is a direct drive model for the procedure in accessing drive motor.
Jan 15, 2010 | Washing Machines
Kenmore washer model 110.20872290. basket spins when MT but won't with a heavy load in it.
If this a belt drive from the motor, the belt may be worn or mis-adjusted. If it is a direct drive type, it may be a bad motor coupling. There is a complete instruction for replacing this coupling by going to: Replacing a Motor Coupling on Whirlpool Top Loader by jsrock516 on FixYa. Give him a pat on the back if it helps.
Aug 25, 2009 | Washing Machines
Agitator moves slowly
* Inspect the agitator
* Inspect the motor coupler
* Inspect the drive belt (belt drive only)
* Inspect under the washer for soot (clutch)
* Test the motor
* Inspect the pulley
* Test the transmission
* Inspect the pump coupling
Dec 13, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
66 people viewed this question
Sal De
fordexpert
Robert Rankin
